09-25-2021, 05:03 PM | #1 |
Rep 166
Stage 2 93 log
Does everything look good in this log. https://www.bootmod3.net/log?id=614f...0b4356468f7cd6
09-26-2021, 07:38 AM | #2 |
Rep 263
Looks good except for timing on Cylinder 6. Lagging behind the rest by several degrees across the board. I'd check the plug on that one. 4 is a bit off too, but not as much as 6.
2018 340i F30 Xdrive
09-27-2021, 02:42 PM | #5 |
Rep 166
Because I'm going to a e30 tune down the road so I'm getting 1 step colder ngk plugs. I'll do another log today and see if the results are the same
09-27-2021, 03:33 PM | #6 |
Rep 7,597
That's not a reason to change plugs though. I run OEM bosch OEM gap, as do many others, on both upgraded turbo and stock turbo, pump gas and ethanol maps, with or without meth, etc... no reason to change unless you have problems with OEM as you can just cause other issues... Even my 45k mile OEM plugs that were never changed worked on MHD stage 2+ E20 map with E30.
10-11-2021, 05:36 PM | #9 |
Rep 166
10-11-2021, 06:19 PM | #10 | |
Rep 7,597
Looks pretty solid. I wouldn't rev above 6400 though. It's unnecessary, and that's where you start to get timing corrections and the "wavy" WGDC and boost ive seen in other logs as well. |
10-11-2021, 07:13 PM | #11 | |
Rep 2,357
(A Dane in China) |
10-11-2021, 07:41 PM | #12 |
Rep 263
What gas are you running now? I'm thinking it's not the same as the previous log.
And I'm also on the stock plugs are better side. After several N55's and big turbo Audis, chasing timing drops was a nightmare. But I always ended up with the best results on stock plugs, with stock gap. Even with the big turbo - and dozens of plug changes :/. Best way to know is by running 3 or 4 logs and see if the drops are consistent. 1-4 plugs are simple to check quickly if desired, but really not necessary without seeing a pattern. |
10-11-2021, 09:29 PM | #13 | |
Rep 166
10-12-2021, 10:07 AM | #14 |
@_sunbish
282
Rep 609
10-12-2021, 12:48 PM | #15 |
Rep 166
Now my bad 😭
10-12-2021, 05:26 PM | #19 |
1296
Rep 3,532
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
