02-05-2017, 07:54 AM | #45 |
Rep 123
Add me to the ProClip camp. They are great quality and lots of different mount and holder options.
I've had one in my past 4 cars. I prefer the vent clip even though it partially blocks my passenger's vent the 0.5% of the time I have a passenger in my car. |
02-21-2017, 09:49 PM | #46 |
Rep 943
Drives: 2012 328i Modern Line
Have any of you that use the iOAuto Pro mount had an issue with the steel disc glue not holding to the back of your phone? The magnet on the dome is so strong that when pulling phone off the mount the disc that is supposed to stay attached to back of phone is peeling off and staying connected to the magnet. I've ordered a couple replacement discs & stickers but this seems like an ongoing issue. I'm wondering what glue to try and use because these replacement discs are not cheap relatively speaking.
:wave:
02-23-2017, 11:26 PM | #47 |
Rep 135
Drives: F30 Black Saphire
spigen vent mount ... works best for me
05-07-2017, 03:38 PM | #48 |
Rep 248
but if you have the heat on in the car doesnt the heat blow right onto the back of your phone?
05-07-2017, 04:28 PM | #49 |
Rep 4,446
Drives: '23 X1 28i xDrive
05-07-2017, 04:31 PM | #50 |
Rep 248
07-27-2017, 01:41 PM | #51 |
Rep 109
Found this thread when searching for a clean solution for mounting my iPhone. I've used vent mounts in other cars, but in the f30 I don't like how much it blocks my access to other controls/the main screen.
I have used ProClip in the past and they make a good product, but again I don't care for their position options in the f30. Have you guys seen this cupholder dock at https://www.joli.design/ ? Has anyone used it? I think I could run a charge cable into the bottom of the cupholder and into this dock. The phone would be mounted a little lower than is ideal, but at least it wouldn't be blocking other controls. |
MoabRat0.00 |
07-27-2017, 03:06 PM | #53 |
Rep 14,108
Drives: G82 M4C X-Drive
I can't stand vent clips. Why block a functioning vent for a phone? Ditto on cup holders.
Looks tacky to me. I also don't like loose wires hanging around, so anything that mounts on the top of the dash that leaves dangling wires is also a no-no. Kuda mount is the only one I have found that looks OEM, is in a good place, and doesn't get in the way of anything. Couple that with a proclip swivel mount with a built in plug and its also the most painless way to get in and out of your car. Just drop it in and it's powered. Plus the wire is easily hidden under the trim and plugs into the lighter under your glovebox. Pretty much the most invisible mount I've come across. I've used it in my 340i and my M3: Glamour shot: 20170201 - Interior - IMG_8787_100 by JMG, on Flickr Dirty shot: IMG_2592_100 by JMG, on Flickr
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
07-27-2017, 07:23 PM | #55 |
Rep 14,108
Yes, but I honestly don't remember if it was pre-drilled or not if that is what you are asking. I was very easy to install the proclip into it and the Kuda is very, very solid.
07-29-2017, 04:23 AM | #56 |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
This - no use for a CD drive in a car anymore when you can plug in your phone for all the music you could ever listen in a car. I'll take a pic of how the mount looks in my car when I get back from vacation
https://www.amazon.ca/Spigen-A230-Pr...igen+car+mount
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
07-29-2017, 10:29 AM | #57 | |
Rep 14,108
08-03-2017, 11:13 AM | #58 |
Rep 1,509
Anybody have the approximate dimensions of the flat front area of the Kuda mount? I'm thinking about getting one to hold the display and controller for my Beltronics STiR+ integrated radar detector.
08-03-2017, 12:29 PM | #59 |
Rep 14,108
I'll measure it next time I'm in the car.
08-03-2017, 12:31 PM | #60 | |
Rep 2,442
Drives: 2022 M3 6MT
2022 M3 6MT - Portimao Blue Metallic
2022 X3 M40i - Tanzanite Blue Metallic |
08-03-2017, 01:16 PM | #61 | |
Rep 689
08-03-2017, 01:49 PM | #62 | |
Rep 14,108
Here are the instructions: http://www.kudausa.com/manuals/092585_kuda_mount.pdf Basically, pull back the trim a bit, insert the mount, bend this metal plate attached to the mount to lock it in, and push the trim back into place.
BMW11279.00 |
08-03-2017, 02:02 PM | #63 | |
Rep 689
08-03-2017, 10:19 PM | #65 |
Rep 177
I started using this.
https://www.amazon.com/dp/B01MR4AO9D..._hB-Gzb0900F0R You use the 2 sided 3M tape (included), stick it somewhere on the dash and you're good to go. You don't have to worry about taking up a vent or having it too low and away from your view. It's magnetic, so be careful with pulling your phone off too hard which can pull the sticky part.
///437m wheels///Depo Headlights ///3M 1080 Carbon Fiber Interior Wrap///M-Sport Bumper Conversion///Dinan Suspension///M-Style Kidney Grilles
"If we knew what it was we were doing, it would not be called research, would it?" |
08-04-2017, 10:34 AM | #66 | |
Rep 14,108
