12-22-2019, 03:33 PM | #1 |
Rep 2
Bimmertech Audiotec Fischer Premium Audio System Amp
This came out of my 2016 328i F30. Easy installation, see video link at the bottom of description. From Manuf. website: BimmerTech Premium Audio System features: Exclusively for your BMW Pre-programming and optimization specifically for BMWs Higher Signal-to-noise ratio and a much higher output power than regular PP86DSP unit Plug and Play installation for most BMWs with factory SA676 Hi-Fi systems Installation in other BMW models using custom mounts and brackets 2-year limited warranty Technology Proprietary Class HD Technology for peerless sensitivity and minimal heat generation 8 separate configurable amplifier channels for maximum flexibility PExtremely powerful DSP with virtually limitless sound adjustment options freely configurable via PC- Tool software (Windows) 56-bit DSP technology and 24-bit AD/DA converter from BurrBrown Design Start/stop capable down to 6 volts supply voltage The latest D/A converter-controlled P3S power supply technology with "ECO Mode" State-of-the-art SMD technology for a more compact design and maximum reliability Six-layer printed circuit boards in multilayer technology for the best possible power and signal transmission Inputs/Outputs Optical S/PDIF input 6 – 192 kHz with an integrated sample rate converter USB-on-board for direct connection to a PC Freely configurable 2-channel PreOut for the connection of additional amplifiers Plug jack for optional cable remote control, functionality configurable via PC software BimmerTech Premium Audio System specifications: Output Power RMS/Max at 4 Ohms 8 x 55 Watts / 110 Watts at 2 Ohms 8 x 70 Watts / 140 Watts Frequency response 20 Hz - 22.000 Hz DSP processing power 295 MHz Number of inputs 6 x Highlevel, 1 x Optical, 1 x Remote In DSP resolution 64 Bit Total harmonic distortion (THD) < 0.015 % Customize your sound in so many ways with high-end audio features such as Digital Signal Processing (DSP), a 30-band graphic EQ, and numerous sound-shaping filters. The experienced DIYer can access and adjust it all using a laptop and the provided USB cable. PP 86DSP manual DSP Tool software manual DSP Tool software Version 4 https://www.bimmer-tech.net/speakers...caApRtEALw_wcB Install video: https://losangeles.craigslist.org/ws...043092173.html https://www.ebay.com/itm/124019964785 Last edited by gigah; 01-01-2020 at 06:24 PM.. Reason: Lowering price |
02-18-2020, 09:43 PM | #3 |
Rep 130
Drives: 2016 bmw 328i xdrive
still available? would you do $500 shipped to 06811?
