05-25-2020, 01:09 PM | #1 |
Rep 1,107
Drives: 2015 BMW 435i Xdrive MSport
What's With All The Spun Rods On Tuned N55's?
I see a lot of guys on the N55 group pages on FB spinning rods on tuned N55's. I'm starting to question whether these engines can handle a tune or even PS2. Some guys spin them on 5w-40, but it really makes no sense at the end of the day. Thoughts anyone? Just want to hear some thoughts.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
05-25-2020, 01:24 PM | #2 | |
Rep 1,105
Have you reached out to those individuals your taking about? I feel they would give you better insight since it happened to them. Ask them what mods they have and how aggressive they drive etc.. |
Boostedphil698432.00 |
05-25-2020, 03:37 PM | #5 |
Luxury at the redline :)
9103
Rep 7,563
Please humor us and just share some info on just one guy, with a spun crank hub, specifically on an N55 motor..
I would like to meet him; I'm sure he also has the original photos of Bigfoot riding a unicorn.. |
05-25-2020, 03:49 PM | #6 |
Rep 1,105
the only mention upon some light research on "N55 spun rods" is with the E9x model years.
Post some links to what you consider "a lot" of spun rods or screenshots of the posts you're referring to |
05-25-2020, 04:01 PM | #8 | |
Rep 462
There have been a few posts/threads on N55 road bearings over the last few years, but considering the amount of stock/tuned cars that have passed through, they are few and far between. Apparently the 2014+ cars have the same bearings as the S55 and those guys are pushing 500whp+ with a simple "stage 1" tune, and we haven't heard anything on the rod bearings from them. Last edited by theEZV; 05-25-2020 at 04:07 PM.. |
05-26-2020, 06:28 AM | #9 |
Rep 1,107
I'm not going to list every person who has spun a rod in the N55 group on fb but it's at least 1 post a day.
05-26-2020, 07:47 AM | #11 |
Rep 316
First off I don't think you can spin a rod. You either "throw a rod" or spin a rod bearing. Also, I'm on FB n55/tuned n55/bmw groups/racing bmw groups pretty regularly (many times per day), and there really aren't guys/gals posting that spin motor components every single day. It seems more common on there because of yahoos that buy a shit car and shit maintenance and don't change oil, tune it and send it that usually spin a bearing or throw a rod. Having said that, it isn't very common on the N55 and is much less common than other bmw motors (s65 or N20).
05-26-2020, 09:59 AM | #12 | ||
Modder of everything I own
147
Rep 491
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
05-26-2020, 11:10 AM | #13 | |
Rep 7,591
05-26-2020, 01:06 PM | #14 |
Rep 1,107
I was really just asking for people's thoughts. I wasn't trying to post "clickbait."
05-26-2020, 02:12 PM | #15 |
Rep 785
Been reading this forum regularly for 2 years. I consider it a fantastic repository of information about our platform. Many members are experienced mechanics and/or tuners and I can't say I recall any discussions that involved the issue you are referring that didn’t involve some high mileage, multi-owner car that's being pushed too far above stock and has a sketchy maintenance history. In other words there was more to the story than the poster cared to acknowledge. If this 'spun rod' was a common issue on property maintained f30s I think you'd be seeing more threads about it.
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
05-26-2020, 02:36 PM | #16 | |
Rep 7,591
I have really only heard of spun bearings on N55 when people oil starve, money shift, etc. |
05-26-2020, 03:40 PM | #17 | ||
Rep 1,107
05-26-2020, 04:08 PM | #18 | |
9103
Rep 7,563
On the other hand, it literally happens every other day, on the S55, since it contains the identical part(s), as the lower output motors but pushing higher level of power. Your typical N55, even tuned, doesn't overwhelm the crank hub bolt and plates to be an issue, as it is on the S55. |
johnung4525.00 QuarterMileJoe9.00 |
05-26-2020, 05:51 PM | #19 |
Rep 4,129
I think crank and block harmonics play a role. The Forged crank my flex less, transmitting more of those harmonics to the block and crank hub.
Just a guess. |
05-27-2020, 12:22 PM | #20 |
Rep 75
So Im on about every N55 group on FB and I dont recall seeing the last one? In fact in two years I can think of two and those were grenade motors that probably had different issues... LMAO .. one a day...
2014 F30 N55 EWG - BigBoost 3.3 Turbo Kit - N52 Exhaust Cam - BPC MILV - ER FBO - AFE Momentum CAI - XDI-35 - MPE w Carbon tips - MHD Custom Tune by efi_bob at Stage Fabrication - 19" Apex Arc 8 w 255/35 square - Bilstien B14 Coil-overs - GC Camber plates - Solid Sub-frame bushings - Powerflex Diff Bushings - BMW L/S Diff - XHP Trans tune -600whp 511wtq on pump 93 with Meth PI
johnung4525.00 |
05-27-2020, 02:45 PM | #21 |
Rep 5,364
There are many cases of earlier N55s spinning rod bearings.
Beginning in the 2014 model year, BMW introduced the S55. In that same model year, BMW also started using the S55's rod bearings and forged rods in all N55s. It's pretty rare to hear of a 2014+ N55 spin a rod bearing. I've had read of a few cases, but it seems no more common than any motor and most of those cases are in more modified N55s. When you play with fire, expect to get burned. I'm speculating here, but the S55 rod bearings are likely more robust given the stock power levels of the S55 and it's ability to rev to 7700 rpms. Also, all F3X series 2014+ N55s began running superior electronic wastegates (EWGs) and larger turbos. Rod bearings often spin because the piston gets hammered really hard during a predetonation event and that hammering drives the piston and rod hammer straight through the oil film between the rod bearing and crank. It could possibly be that since EWG's are better at controlling over-boost, which can lead to predetonation under high load situations, this improved over-boost control reduces the chances of a spun rod bearing. Of course in modified cars, that control and threshold narrows. Just my theories.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
johnung4525.00 1bad14-F3029.50 |
05-27-2020, 03:51 PM | #22 | |
Rep 1,107
