03-11-2024, 04:51 AM | #1 |
Rep 20
MHD Stage 2 > 2+ - Burbles act strange
Hello!
I installed the B58 TU HPFP last weekend and adjusted my MHD tune from Stage 2 to Stage 2+ Because I already had stage 2, I didn't expect much from stage 2 to stage 2+, but I have to admit that the car drives and reacts very differently (In a positive way). I only have 1 thing I don't understand: With the old map (stage 2) I had the burbles (only on sport) at 0.8 seconds and sound at aggressive. This always gave 1 or 2 hard loud bangs when downshifting. Now in the stage 2+ HPFP map I notice that the burble does not always work when downshifting. Only when you give a lot of gas at high revs do you get those hard bangs, but not always at lower speeds. Do people recognize this with the HPFP map? Anyone have any recommendations for the settings? When my tank is empty i will try the 102ron(95oct) map to test it. I don't use the exhaust burbles often. I also turned it off in comfort mode. But sometimes in a tunnel or a garage it's just fun to turn it on... but with the normal stage 2 map I could just trust that it always worked. Now it is quite irregular and does not always work. Pity. Any tips are welcome! Setup & Mods: B58 Gen1 Osprey Custom turbo heatshield Osprey 5" Downpipe HPFP Tu1 pump Straightpipe with only mid resonator and M-performance end muffler. MST Cold air intake
BMW E39 - 520i
BMW E60 - 530i BMW F31 - 328i BMW G31 - 540i |
03-11-2024, 05:41 AM | #2 |
Rep 3,990
I never noticed any difference in behaviour between Stage 2 and Stage 2+. Not even in power/performance, but that was sort of expected on RON 98, since it officially has the same max power, just slightly higher torque mid-range.
But burbles - no difference. Mine are set to stock (MPPSK) though.
03-11-2024, 08:58 AM | #3 |
Rep 810
How long have you been driving it after the latest flash? I’ve noticed burbles don’t sound the same until I’ve driven the car a bit after a new flash. After a while though, it sounds the same.
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
03-11-2024, 10:02 AM | #4 |
Rep 20
I haven't ridden extremely much yet. Always small trips. Of course I warmed up properly before I started testing. But what bothers me most is that it is not consistent. Sometimes it pops and other times it doesn't (only in low speeds).
BMW E39 - 520i
