07-05-2018, 10:58 PM | #23 |
Rep 537
Tomorrow
About 12 hours away from the first dyno run. So excited!
'14 F30 328i M Sport // FBO // bm3 Stage 2+ DME Tune // Stage 1 TCU Tune // Apex EC-7s on Conti DWS06+s // 1 of 6 ever made of this spec (3C13 US-SULEV German-built //
07-06-2018, 05:01 AM | #24 |
Rep 361
Dyno Day!!
Present: 2014 f30 328xi MSport, 1992 VW GTi VR6 swapped
Past: 2010 335i 6 speed; 2008 VW GTi stage 2, 2004 Subie WRX FBO, 2003 20th Anny VW GTi FBO |
07-06-2018, 11:00 AM | #25 |
Rep 537
Heading to the shop
Appt is in 30 mins, just grabbed coffee and then heading over.
07-06-2018, 01:39 PM | #26 |
Rep 537
Baseline Results are in...
Atmospherics:
81 degrees F 48% humidity Testing: Sport+ in manual mode These three runs were done in 4th gear Best run (was the first of the three and represents what peak performance is without heat soak) resulted in 212.30 whp and 257.60 lb-ft. Accounting for the conservative driveline parasitic loss I referred to above (15.9%) the crank numbers calculate out to 252.44 hp and 306.30 lb-ft. This seems a bit high, however, though the graph said (uncorrected) I confirmed with the dynographer that the numbers were indeed accounting for temperature, humidity, altitude and barometric pressure. The only mod I left on the car the K&N drop-in filter. This is higher than I expected, so rather than cherry pick, let's take the average of the three runs...212.53 whp and 237.13 lb-ft. Accounting for losses, that is 252.71 hp and 281.96 lb-ft. Though I am still skeptical about the mathematics due to the number of variables being considered, at the very least, once we get the next round of data, we can extrapolate a pretty accurate accounting of the benefits of the JB+. Stay tuned. Video of a 6th gear pull: https://youtu.be/syhwiILDM8M Last edited by N26Ghost; 07-06-2018 at 02:26 PM.. |
07-06-2018, 03:06 PM | #28 | |
Rep 2,382
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
07-06-2018, 03:07 PM | #29 |
Rep 2,382
Okay, great. I misread the first time, so I cleared it and reset lol.
07-06-2018, 03:12 PM | #31 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
My car hit 228rwhp/257tq bone stock in triple digit temps and heat soaked. Shocked it's showing lower.
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
07-06-2018, 03:17 PM | #32 |
Rep 537
No two engines...
I don't know if I am shocked. Dyno numbers are horrifically subjective and cannot be compared across mutliple dynos. What this number represents is the baseline for my engine on this particular dyno. If I took my car to your location and tested on that dyno, the outcome would be different and very well could be higher or lower. The point of this was never to compare to other dyno results, rather to get an accurate baseline for my particular car on this specific dyno for the purpose of comparing to when the JB+ is installed and set to max. Not discounting your comment, but unless you brought your car to this exact dyno, then it would be nearly impossible to compare the data with any kind of accuracy.
CalCarNut1060.50 BradMacklin44.00 |
07-06-2018, 03:18 PM | #33 | |
Rep 3,680
N26Ghost496.50 |
07-06-2018, 04:32 PM | #34 |
Rep 40
I’m running the Dinantronics Sport module (similar single plug-intercept device) and running in “race” mode with +4psi. Looking forward to your results!
07-06-2018, 04:35 PM | #35 | |
Rep 3,680
07-06-2018, 11:31 PM | #36 |
Rep 307
Can you have them change the correction factor to SAE instead of STD? SAE is the more commonly used correction factor. It doesn’t really matter, since it’s just a base line, but it should make it more inline with other dynos.
07-06-2018, 11:34 PM | #37 | |
Rep 307
07-07-2018, 07:12 AM | #38 | |
Rep 3,680
07-07-2018, 07:20 PM | #40 |
Rep 537
Why, indeed...
07-07-2018, 07:43 PM | #42 |
Rep 537
Amended
There was a giant fan in front of the car which you can hear at the beginning of the video, but the hood did remain closed for all runs.
07-07-2018, 07:43 PM | #43 |
¯\_(ツ)_/¯
945
Rep 1,762
I was thinking the same..
