05-20-2020, 09:14 PM | #111 | |
Rep 338
"Firmware updates for the hardware OBD Agent device require pulling the microSD card out of the device for an update. Step-by-step guide Download firmware from here: https://www.dropbox.com/s/91l8gqmlh0...07.img.gz?dl=0 Unzip the provided .gz file. On Windows you can use WinRAR or 7-zip software to extract the downloaded .gz file from the above link. On macOS in most cases it’ll just unzip automatically after downloading. Unzipped file will have a .img extension and the file will be just below 8 GB in size. Write the .img file to the card. You can use Etcher (on macOS or Windows), free utility: Etcher: https://www.balena.io/etcher/ Once updated, insert the microSD card back into the device and power it on to confirm connectivity." So even the BM3 app on my iphone, in the app store >available updates, it never shows up there for newer versions, so i am confused and scratching my receding hairline as we speak, lol..
2013 320ix N20 8AT|BM3 stg1|Muff Res Delete|HPB-LED-Amber-DRL's
IG: DadzBmer_N2o Last edited by DadzBmer_N2o; 05-20-2020 at 09:19 PM.. Reason: add more info |
05-20-2020, 09:19 PM | #112 | |
Rep 68
05-20-2020, 09:24 PM | #113 | |
Rep 338
IG: DadzBmer_N2o |
05-20-2020, 09:39 PM | #114 | |
Rep 68
05-20-2020, 10:22 PM | #115 |
Rep 338
Thanks for the info, i will try this, this week 👌
Okay updated as of today (5/27/20). I did get that warning to update my agent firmware, but it was gawd awefully slow loading (i assume from it being large), so i will just end up taking the SD card out and do the firmware update on the MAC, thanks for the advice and help..
IG: DadzBmer_N2o |
05-29-2020, 02:30 PM | #117 | |
Rep 134
Should my Rasbpain Lite have no desktop at all for it to work?. Please help. |
06-06-2020, 04:23 AM | #118 |
Rep 134
Any luck with Raspberry 4 ?. I'm struggling here. I do not know where I'm going wrong?.
I have managed to do this as well. Useful if you do not want cables running around or under your trim etc. |
06-06-2020, 06:23 PM | #119 |
Rep 338
So lately my OBD Pi3B has been giving me fits on trying to update the agent while inside the garage, this last update i ended up just taking her nearest my router and updating the agent firmware there. Well it took sometime but i left it and cameback and it updates to the latest version and haven't had any more probs doing my flashes now..
Also its weird but i still can get connected even though my phone is not named "bootmod3" in the >about settings, i do it have it named that for the hotspot name..
IG: DadzBmer_N2o |
06-07-2020, 05:38 AM | #120 | |
Rep 500
06-28-2020, 06:20 PM | #121 |
Rep 29
Drives: BMW X3M Comp/Pythonic Blue/BLK
Great tutorial and thanks for posting this. Even though Bootmod3 will be releasing the direct to phone setup in the near future I went ahead and added some stuff the original setup script did not have.
ADDS: - systemctl service - updated ssh - updated wifi connection to work with your custom SSID Sharing the systemctl service file i created. File locations: - working directory: /home/pi/bootmod3 - file locations: /home/pi . |-- bm3_installer_v1.1.sh |-- bootmod3 | |-- agent.jar | |-- agentapp.jar | |-- agentrunner.jar | |-- bm3_systemd.log | |-- bootmod3_service.sh NOTES: you need a raspbian build, i used the buster install and ran this script then customized as needed. The original cron setup did not work for me so i edited the bash script to work how i wanted. create a new file "/etc/systemd/system/bootmod3.service" Code:
[Unit] Description=Bootmod3 After=network.target StartLimitIntervalSec=0 [Service] Type=simple User=pi WorkingDirectory=/home/pi/bootmod3 ExecStart=/bin/bash /home/pi/bootmod3/bootmod3_service.sh ExecStop=killall java && echo $? > bm3_systemd.log 2>&1 Restart=always RestartSec=3 [Install] WantedBy=multi-user.target When you run top on the machine the service will show up under the user "pi" and not "root" You can access this by running "top" from your terminal then hitting "u" and enter "pi" as the user. Ctrl+c to exit top Code:
top - 20:01:15 up 1 min, 1 user, load average: 0.38, 0.20, 0.08 Tasks: 114 total, 1 running, 113 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.4 us, 1.2 sy, 0.0 ni, 98.4 id, 0.1 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 926.8 total, 699.1 free, 109.1 used, 118.6 buff/cache MiB Swap: 100.0 total, 100.0 free, 0.0 used. 762.8 avail Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 646 pi 20 0 662536 71500 10988 S 1.3 7.5 0:18.19 java -Xmx512m -jar /home/pi/bootmod3/agent.jar 831 pi 20 0 5736 2640 2108 R 0.7 0.3 0:00.23 top 619 pi 20 0 342460 20584 10776 S 0.3 2.2 0:01.09 java -jar agentrunner.jar 611 pi 20 0 7676 2508 2368 S 0.0 0.3 0:00.02 /bin/bash /home/pi/bootmod3/bootmod3_service.sh 626 pi 20 0 10848 3536 2908 S 0.0 0.4 0:00.07 sshd: pi@pts/0 628 pi 20 0 3740 3120 2304 S 0.0 0.3 0:00.26 -bash Custom Systemctl service script NOTE: the script needs the location of "agentrunner.jar". In my file location and setup this script and the jars are in the same location. Code:
DATE=`date '+%Y-%m-%d %H:%M:%S'` echo "Bootmod3 Service started: ${DATE}" | systemd-cat -p info java -jar agentrunner.jar > bm3_systemd.log 2>&1 Custom Mods: Code:
#!/bin/bash # Change the repo pointer ### # CONFIRM THIS MATCHES YOUR SETUP ### sudo sed -i 's/stretch/buster/g' /etc/apt/sources.list sudo sed -i 's/stretch/buster/g' /etc/apt/sources.list.d/raspi.list # Make raspberry.local reachable on the network sudo tee -a /etc/hostname > /dev/null <<EOT 127.0.1.1 raspberrypi EOT # Change the wifi setup sudo tee -a /etc/wpa_supplicant/wpa_supplicant.conf > /dev/null <<EOT ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev update_config=1 country=US network={ ssid="CUSTOM_WIFI_NAME" psk="CUSTOM_PASSWORD" key_mgmt=WPA-PSK } EOT Use systemctl: NOTE: May need to run "sudo systemctl daemon-reload" to get the service to be recognized by systemctl. Check service is recognized Code:
▶ sudo systemctl status bootmod3.service # OUTPUT * bootmod3.service - Bootmod3 Loaded: loaded (/etc/systemd/system/bootmod3.service; disabled; vendor preset: enabled) Active: inactive (dead) Start the service and check the status of the logs Code:
▶ sudo systemctl start bootmod3.service #CHECK THE SERVICE ▶ systemctl status bootmod3.service # OUTPUT * bootmod3.service - Bootmod3 Loaded: loaded (/etc/systemd/system/bootmod3.service; disabled; vendor preset: enabled) Active: active (running) since Sun 2020-06-28 19:01:01 EDT; 1s ago Main PID: 8471 (bash) Tasks: 23 (limit: 2068) CGroup: /system.slice/bootmod3.service |-8471 /bin/bash /home/pi/bootmod3/bootmod3_service.sh |-8478 java -jar agentrunner.jar `-8487 java -Xmx512m -jar /home/pi/bootmod3/agent.jar Jun 28 19:01:01 raspberrypi systemd[1]: Started Bootmod3. Jun 28 19:01:01 raspberrypi cat[8474]: Bootmod3 Service started: 2020-06-28 19:01:01 Now if it all went well enable the service and restart to confirm the agentrunner is started by the new service you just created Code:
▶ sudo systemctl enable bootmod3.service ▶ sudo systemctl status bootmod3.service #OUTPUT * bootmod3.service - Bootmod3 Loaded: loaded (/etc/systemd/system/bootmod3.service; enabled; vendor preset: enabled) Active: inactive (dead) SSH Add Public ssh key First on your laptop create an SSH Key pair Code:
▶ ssh-keygen -t rsa -b 4096 -C "bootmod3_raspberry_pi" ########## # Follow the prompts and make sure you change the directory path to the ssh private key ########## Code:
▶ scp ~/.ssh/bootmod3_raspberry.pub pi@raspberry.local:/home/pi/bootmod3_raspberry.pub ########## # Follow the prompts and make sure you change the directory path to the ssh private key ########## # From the raspberry pi ▶ mkdir -p ~/.ssh ▶ mv bootmod3_raspberry.pub ~/.ssh/authorized_keys ▶ chmod 600 ~/.ssh/authorized_keys Use SSH only access setup this: /etc/ssh/sshd_config: Code:
#Uncomment these lines PubkeyAuthentication yes AuthorizedKeysFile %h/.ssh/authorized_keys PasswordAuthentication no ChallengeResponseAuthentication no UsePAM no Code:
▶ sudo systemctl daemon-reload ▶ systemctl status sshd ▶ sudo systemctl restart sshd To ssh as long as you are on the same network you can ssh to Code:
ssh -i ~/.ssh/bootmod3_raspberry pi@raspberry.local Last edited by codelinx; 06-28-2020 at 07:03 PM.. Reason: added more content |
08-26-2020, 02:20 PM | #122 |
Rep 1
Thank you dieselg5 for the OP with great instructions and codelinx with the recommendations for running as a service. I've got this setup and running on an underclocked RPi B+ and flashing/logging worked great on my test run this afternoon. Huge kudos to you guys.
10-03-2020, 06:39 AM | #123 |
Rep 2
Hi,
What is the latest version of the bootmod3 agent jar files? Are those jar files downloaded via the OP's script latest version? I have the latest mobile apps installed in my Android phone. Earlier I was attempting to update the official standard wifi firmware from PTF but due to I was unable to connect to BM3_NET and internet simultaneously, later I have decided to revert to raspberry buster lite (the method guided by OP). Since the latest mobile apps is unable to update OBD agent anymore, I just want to ensure I have the latest version of agent jar files. Thanks in advance for your advice! Damon |
10-06-2020, 01:50 PM | #125 |
Rep 1,179
Drives: 2014 X5 50i M Sport, M3(sold)
12-29-2020, 10:27 PM | #126 |
Rep 38
Thought of building something like this the other day and see I am late to the party. Has anyone here tried to package this up as a docker image on docker hub so that it is easier to maintain/deploy?
