BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > F30 noisy blower
      10-02-2017, 04:23 AM   #1
Soul_Glo
Soul_Glo's Avatar
Drives: G20
The blpwer sounds like a dyson.
Demisting the windscreen this morning was interesting.
Any one know how to access the blower to check if a leaf is not stuck there?
      10-02-2017, 08:00 AM   #2
Sasquartch
Drives: 520i G30
Look at http://f30.bimmerpost.com/forums/sho....php?t=1415353
Had exactly the same issue as you a few weeks back.
Easy fix.
Soul_Glo13347.00
      10-02-2017, 09:08 AM   #3
Soul_Glo
Soul_Glo's Avatar
Drives: G20
Easy fix.
So is it near the centre console side of the footwell or toward the door side?
Thanks for the link! Will take this on tonight.
      10-02-2017, 09:39 AM   #4
Sasquartch
Drives: 520i G30
It's fairly obvious once you've removed the lower trim piece - I'd suggest removing the pollen filter first (nearest the centre of the car) then the motor / fan.
Make sure you have a decent torch.
Soul_Glo13347.00
      10-03-2017, 12:32 PM   #5
Soul_Glo
Soul_Glo's Avatar
Drives: G20
Done. The back torx screw is a pig. My screwdriver was too long. Luckily people just buy me DIY stuff for xmas so I had three sets of precision torx sets to choose from. Leaf removed!!! Gauze installed! Plastic hamster wheel cleaned.
Thanks big foot
      10-03-2017, 01:04 PM   #6
Kal101
Kal101's Avatar
Drives: 335xd Msport +
Just a quick check if I may
Is your an earlier model 2012 or so because there was a free retrofit available to cure the leaf in tubework issue.
Involved fitting a new grille - had it done to Mine worked a treat.
Soul_Glo13347.00
      10-03-2017, 01:11 PM   #7
Soul_Glo
Soul_Glo's Avatar
Drives: G20
Why yes it is. March 2012.
Is there a SIB/TSB that I can shove under the service reps. nose?
      10-03-2017, 03:30 PM   #8
Kal101
Kal101's Avatar
Same as my one was.
They should be able to check on the history if it was fitted or not. Might be worth having a chat with your friendly dealer.
Unsure if it was a case of doing them all or just those that showed up with an issue.
Think i read a thread on this forum about it - few years ago unfortunately.
Soul_Glo13347.00
      10-03-2017, 03:38 PM   #9
rocketretro
rocketretro's Avatar
England
180
Drives: M235i Coupe
I had (embarrassingly!) the same fault a couple of weeks ago, it turned out to be a parking ticket from August that had gradually slipped down through the top of the dashboard to the blower housing, horrendous noise and vibration on the day on the passenger side vents, until taken apart and cleared by the dealer. I now put the tickets in a non slip plastic cover to avoid a re-occurence.
Soul_Glo13347.00
      10-03-2017, 08:38 PM   #10
Soul_Glo
Soul_Glo's Avatar
Drives: G20
Same as my one was.
Will :
      10-04-2017, 03:18 AM   #11
Sasquartch
Drives: 520i G30
Will :
If you find anything please share, mine's a 2012 and fairly sure there's no grill on mine
      10-04-2017, 12:50 PM   #12
Soul_Glo
Soul_Glo's Avatar
Drives: G20
Can?t seem to find anything but will keep searching:
https://www.aboutautomobile.com/Tech...2/BMW/3-Series
      10-05-2017, 06:14 PM   #13
Kal101
Kal101's Avatar
How many do you get ??
      10-05-2017, 06:16 PM   #14
Kal101
Kal101's Avatar
Would it be listed in here as it wasn’t a recall or do all cars - only those that were affected ?
      10-05-2017, 08:08 PM   #15
Soul_Glo
Soul_Glo's Avatar
Drives: G20
The lists are basic on that site- preliminary research. Some things have not been updated.
CotswoldBMWMini
Is there an updated part to address this please? Thanks
      10-06-2017, 03:20 AM   #16
CotswoldBMWMini
CotswoldBMWMini's Avatar
Drives: BMWMini
CotswoldBMWMini
If you could give me your Reg or Vin please I can put it to our service department to check for you
      10-06-2017, 03:47 AM   #17
Sasquartch
Drives: 520i G30
My VIN ends E888052 (2012 328i) - I'd be greateful if you could check mine please
      10-06-2017, 08:55 AM   #18
CotswoldBMWMini
Drives: BMWMini
Hi,
Your vehicle has received 5 QE's but there is nothing showing for the heater blower and nothing outstanding
Soul_Glo13347.00
      10-06-2017, 09:49 AM   #19
Sasquartch
Drives: 520i G30
Hi,
Thank you
Are you allowed to share what these QE's were please ?
Always interesting to know the history when you're not the original owner.
      10-06-2017, 10:00 AM   #20
CotswoldBMWMini
Drives: BMWMini
Thank you
This is what is shown
16/07/14
Job: E84 E89 F10 F11 F30 F35 N20 Program control units (OBD)
Job: F2x F3x Rework corrosion protection of engine compartment (part 2)
Job: F2x F3x Remove the water drain grommet of the units compartment
11/07/13
Job: F20 F21 F30 F31 F35 Program control units (FEM)
Job: F20 F21 F30 F31 Rework the corrosion protection connector for luggage compartment
      10-06-2017, 10:10 AM   #21
Soul_Glo
Soul_Glo's Avatar
Drives: G20
Thanks Phil
      10-06-2017, 10:50 AM   #22
Sasquartch
Drives: 520i G30
