BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > USA - NY / NJ / CT / PA > '13 328 MSport 6mt RWD EBII
      11-10-2014, 10:11 AM   #1
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
Car has under 13k miles(In service date of 9/12, fairly under mileage).
It is light on options, the car you would only find as a special order. If an option is not listed below, it means the car does not have it(so save the "if only it didn't have halogens, or had Dakota, or NAV questions/comments).
It has:
MSport line
Heated Seats
Moonroof
Estoril Blue II paint
Sirius SAT radio
Upgrades:
APEX EC7 18x8.5/18x9.5 w/BMW center caps and OEM Conti SSR RFTS w/OEM sensors
MPerformance grills
BMS clutch stop
AFE scoop
H&R Sport springs(drives how it should now)
Rogue Exhaust(current one on the car is a prototype, currently the only one in existance)
Integral Audio F30 upgrade(Including speakers, amps, sub, $5k value) This blows anything else you have heard out of the water and will be the first car to have it, 100% engineered for the F30 with 16 months of R&D)
Swapped burled wood trim for Hex aluminum over black finisher
[B]
Included additions:
Stock grills
Stock exhaust
Stock speakers and amps
Condition:
Car is in excellent shape. I detail/clay frequently. There are no door dings or scratches on metal surfaces. Two scratches, one gouge in the rear bumper facing the sky from loading something in the trunk, the second a scrape LOW on the passenger side skirt only seen when crouching. Wheels and tires are nearly flawless. Interior shows NO wear.
NOTE: This is a July/12 build car which means it has no Bluetooth/USB
Summary:
This is a great example and great way to get into a more purpose built RWD 6mt car that is not easily found on a lot. It has been babied but driven just hard enough to keep the car in proper condition. It was broken in @ 1200 miles where it was dyno'd and showed strong stock performance. It was never tracked, never abused on the street, never a clutch dump, or a missed shift(FYI-I get at least 100-160k out of my clutches). It has had its services such as an low miles oil change-good to go.
Car will be available in NY/NJ until early Dec, then will be available in Michigan, so delivery location is negotiable.
PRICE: $33,250
Interested parties can PM me.
Pics below are of an un-detailed car.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      11-24-2014, 10:39 AM   #2
Jamesons Viggen
BUMP
Will be home this week to show the car locally before it comes with me to Michigan
      12-01-2014, 10:35 AM   #3
Jamesons Viggen
SOLD. Delivery taken on 12/6
