11-20-2021, 12:12 AM | #1 |
Rep 11
513M WHEEL FITMENT Help on BMW 340i RWD M-Sport
Hi,
I’m looking to purchase OEM 513M wheels that have the following spec: 18x9 ET 29 - Front 18x10 ET 40 - Rear The thing I’m worried about is the tires poking outside the fenders and/or rubbing issues. I’m on stock M-Sport suspension and have not modified the height or suspension in any way. Is there any way we can eliminate the tires from poking out? If I had to drop the car it would be the Dinan lowering springs which lowers the car 1” front and 1” back. I just want the fitment of the wheels to be flush with the fenders and not have to drop the car lower than 1”. Are there any tire sizes you guys recommend? Does anyone have this setup and want to share pics with me? I’ve read through all the other threads on this topic and I just can’t get myself to buy these wheels because I fear that they will poke out a lot. Thanks for all your help! |
11-20-2021, 11:17 AM | #2 |
Rep 4,314
235/45/18 front, 265/40/18 rear, from stock height to mildly lowered, tires have least shoulder poke due to moderate stretch up front and mild stretch rear. taller sidewalls help reduce fenderwell gaps.
245/40/18 front, 275/35/18 rear, from mildly lowered to medium. lowering adds slight negative camber which reduces poke of the tires upper shoulder. here is an example...https://f30.bimmerpost.com/forums/sh....php?t=1445526 if springs only drop, consider Eibach Pro-Kit and F80 bumpstops. Eibach Pro-Kit has best ride, fixes reverse rake(front springs lower more than rear), best for maintaining OEM damper lifespan since it has the mildest lowering. |
11-21-2021, 04:54 AM | #3 |
Rep 133
Drives: F32 435dx
You will have exactly the same poke as OEM M437 wheels since they have exactly the same offset, only difference is the diameter (19" instead of 18"). You can check the thread about these wheels where you will find lots of pics of many of us who have installed the M437. There's no rubbing issue at all, but there is poking and depends on how much you are willing to tolerate as an end result.
But if you want wheels to be flush with fender lip, then I guess your only option is to go to aftermarket wheels with appropriate offset or different OEM wheels plus spacers. |
hsohal245.00 |
12-11-2021, 12:06 AM | #4 |
Rep 1,055
@hsohal24
Hopefully this answers your question. Stock 18x9 255/40/18 front 18x10 275/40/18 rear m3 take offs. 513m wheels
MY13: TTE400 Stage 2 turbo, Spec Single Mass flywheel + Stage 3+ Clutch, FTP V2 Turbo Inlet, Evolution Racewerks Charge pipe + Boost pipe + Intercooler, Turbosmart Recirculating Diverter Valve, aFE grill scoop + aFE Magnum Force Cold Air Intake, B58 coil retrofit, eBay Downpipe, Active Autowerke muffler, DW400 LPFP, B58TU HPFP, M5 s63TU injectors, Bimmermilvs, e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
12-11-2021, 09:27 AM | #6 |
Rep 1,055
Stock m sport suspension. I am rwd only. This is how much gap you have. An inch drop won't be an issue. I personally want to drop it maybe .5 if inch because daily driver + speed bumps + always running over random debris.
12-13-2021, 07:45 PM | #7 |
Rep 11
sqwinny What rotors are you running? Reason I ask is because of all the photos of 513Ms on F30s I saw, I noticed that those that had the stock rotors had more tire poke than those that changed their rotors out. I see that your rotors are not stock too. What are they?
07-25-2022, 09:50 AM | #8 | |
Rep 1
I've been on the fence about getting the 513m's for the longest time. I have an F30 on m sport suspension like you. Would you happen to have more photos of the wheel and tire poke? I'm mainly worried about the tire poking out looking like mexiflush. Thanks! |
07-25-2022, 12:54 PM | #9 | |||
Rep 1,055
No other pictures of the poke. It's really 100% flush and no mexiflush. Maybe sticks out 2-3mm but that's it
07-25-2022, 03:50 PM | #10 | |
Rep 5,391
07-25-2022, 04:07 PM | #11 | ||
Rep 5,391
The wheel is 1" wider so 1/2" of that will come out further. 1/2" = 12.7mm The offset is 5mm less, so the wheel will stick out 5mm more due to the offset change. So the wheel rim 9n the 18x9ET29 wheel will stick out 17.7mm more than stock. 17.7mm = 0.69 inches which is about 11/16". More than 5/8" but less than 3/4". So you could put a ruler edge on your current wheel lip and see exactly how much further the new wheel lip would stick out from the current wheel lip. Tire width is another matter. Tires vary even if the size listed on their sidewall is identical. TireRack publishes the actual measured sizes in the Specs section for each tire. From TireRack, collect the tire width and tire tread width from your existing tire model & size and also the tire model & size you intend to purchase for your new wheels. Subtract them from each other and take half that difference. Those are how much further the new tire width and tire tread width will stick out from the existing tire width and tread width. Just use a ruler the same way to see for yourself. Hope this helps! |
alohasurftoad3069.00 |
07-25-2022, 04:35 PM | #12 | ||
Rep 1,055
johnung4525.00 |
07-25-2022, 04:41 PM | #13 | |||
Rep 5,391
Again regardless of 17" or 18" diameter wheels, the poke out of the wheel well doesn't change unless the wheel width, wheel offset, tire width or tire tread width changes. |
513, 513m, f30, f80, f82, fitment, lowering spring, m wheels |
