07-26-2017, 08:23 PM | #1 |
Rep 529
Coding Euro High Beam Assist but no LHM or TMS ECU Modules
So using the attached document, I'm trying to code the Euro High Beams (with the proper anti-dazzle shutters) and was able to remove the 5AP and 8S4 from my FA pretty easily. I verified the new the FA by recalculating it, and saved it. No errors with this.
Then went into Expert Mode, loaded the newly saved FA, and recalculated the FP again. Then went into the "VCM Master" tab and did the "Write FA FP" to write the new FA to the car. It looks like the 5AP and 8S4 elements were correctly removed as I don't see them in the SALAPA elements now. So now I need to add all the shutter values in to get the no-dazzle feature working correctly, but I can't find the LHM ECU modules or the TMS modules. I have a KAFAS2 module (but not a KAFAS) there already. Am I just missing something or did I do something wrong? My car is a May build, 2017 340i with the lighting package so I have the necessary hardware. I appreciate any help anyone can give me with this. Thanks. |
07-27-2017, 07:19 PM | #4 |
Rep 8,376
08-01-2017, 11:43 AM | #5 |
Rep 1,554
Drives: '22 Tesla MY + '23 Tesla MY
So do the 340 LCI Euro models with the different part numbers for headlights have FLE or TMS/LHM?
That document was for pre-lci, no one has updated it for the new modules.
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
08-01-2017, 12:16 PM | #6 |
Rep 8,376
08-01-2017, 12:55 PM | #7 |
Rep 1,554
So get the OP to try the coding for FLE and tell us if it works with F30 headlights. (I know you say no micro shutters), but NA F80/F82 have different part numbers than the Euro conterparts for headlights as well, and still the F80/F82 can be code for NGHB
08-01-2017, 01:00 PM | #8 |
Rep 8,376
Many have tried and it does not work on LCI F3x's.
08-01-2017, 01:23 PM | #9 |
Rep 529
No shutters = not going to try
Not going to bother since my car lacks the shutters required to get the No-Glare working properly. I don't want to be glaring other drivers all the time. I'll just deal with the base auto high-beams.
08-01-2017, 02:34 PM | #10 | ||
Rep 1,015
Suggesting he do that is an asshole move. Love to see how you react with driver behind you using high beams...or in opposite lane with brights blaring in your eyes. Quote:
In the OP you stated you had the proper EU shutters. What leas you to believe that? They are available, but will cost you. Last edited by GCinFLA; 08-01-2017 at 02:40 PM.. |
08-01-2017, 03:00 PM | #11 |
Rep 529
Smart move.
In the OP you stated you had the proper EU shutters. What leas you to believe that? They are available, but will cost you. I thought I had the proper hardware, but did not realize that starting with MY 2016 there was a change in the actual headlight units that removed the active shutters. I finally figured it out when I didn't see the appropriate sections to control the shutters in my coding session. Then I did more research and figured it out. Still annoyed at yet another cost-cutting move on BMWs part, but since they are illegal in the US anyway, I guess you can't blame them for saving money where they can. |
08-01-2017, 04:40 PM | #12 |
Plenipotentiary
2616
Rep 3,046
They use different methods to produce the Passing Beams. F8x Pre-LCI use Sail Beam (No Digital Optic Shutters). F3x 3er LCI Adaptive use Multibeam Dynamic Shadow in approved markets (Digital Shutters). US Cars have a different outer LED Array that cannot produce a Sail Beam or a Dynamic Shadow Beam.
08-01-2017, 04:41 PM | #13 | |
Rep 1,554
No one is suggesting that he leave it to glare other drivers if it doesn't work. I said 'try'.
08-01-2017, 05:42 PM | #14 | |
Rep 1,015
: The LEDs don't have shutters. |
08-01-2017, 05:46 PM | #15 | |
Rep 1,015
The shutters have NEVER been in the USA Xenon Headlights. They were NOT removed in 2016 USA Models. |
08-01-2017, 06:33 PM | #16 | |
Rep 1,554
I wouldn't expect any different answer from you though, aka, I can't actually quote any of the threads I just referenced.... Here is one I posted in a while back clearly showing the tunnelling on the US LCI 340i working. Suggest you read it http://www.bimmerfest.com/forums/sho...=871966&page=3
NavS23.50 |
08-01-2017, 08:18 PM | #17 | |
Rep 1,015
Even posted on multiple threads about LEDs where the know it all like yourself think LEDs in USA work without all the correct parts. I'll enjoy mine. You just keep on wishing and guessing. |
08-01-2017, 08:55 PM | #18 | |
Rep 1,554
Kabrich had the xenons figured out a long time ago, but since you know it all, you'll tell us about LED equipped cars I am sure
08-01-2017, 09:16 PM | #19 | |
Plenipotentiary
2616
Rep 3,046
"I VO coded both FLEs while I was out driving as I soon realized I was high beaming everyone from behind. Think we need to go back to the drawing board a bit before anyone applies this to their car." The "tunnel" was portions of the low beams cutting out, the long range high beams were coming on when the shouldn't, and there are errors galore because the ECE and US lights don't run on the same voltage. |
08-02-2017, 08:07 AM | #20 | |
Rep 1,554
http://www.bimmerfest.com/forums/sho...8&postcount=98 Still hasn't sorted out the tunneling fully, but there were no updates. In case anyone is looking, this is the cheapest I have found the Euro LED adaptive headligths https://betaautoparts.com/product/f3...8-oe-original/ https://betaautoparts.com/product/f3...7-oe-original/
08-03-2017, 12:19 AM | #21 | ||
Rep 605
As I have stated a few times in a few threads, the coding solution we ended up with is 90% of what the ECE cars do. I am still running it on my car today but since we realized we could not 100% enable due to hardware limitations it hasn't been distributed to my knowledge. The shutters are not responsible for the tunnel but from what I can tell are used in scenarios where we have oncoming traffic and the opposite high beam is to be enabled. Since the hardware is missing and hence it won't take the coding the opposite high beam doesn't enable in this situation so really no harm in running this...just not as good as it could be. FWIW there is no mystery to what the ECE coding is; the coding is all there in the firmware files and can be extrapolated with ESys. The key is you can't run that coding on a US car due to improper hardware. You have to pick the settings you can enable. Lots of misinformation floating around on this; I hope this clears it up a bit. Officially, coding doesn't work to enable. Unofficially, you can get most of it enabled.
- 2022 X3M Comp
- 2021 X5 xDrive 40i - 2018 F80 M3 (sold) |
08-03-2017, 12:59 PM | #22 | |
Rep 1,015
