01-26-2020, 05:06 AM | #595 |
Rep 44
01-26-2020, 05:34 AM | #596 |
Rep 843
01-26-2020, 06:01 AM | #597 | |
Rep 5
I wonder if is the unit itself is not working or I've done something wrong and trying to find out if someone else experienced the same problem. Thanks Last edited by constantind; 01-26-2020 at 07:29 AM.. |
01-26-2020, 06:17 AM | #598 | |
Rep 285
01-26-2020, 06:21 PM | #599 | ||
Rep 396
01-27-2020, 09:47 AM | #601 | |
Rep 152
I run in night mode all the time in CarPlay, as I don't like the bright background anyway. Just wish the Apple Maps would work.
2011 335i, totaled by a deer.
2015 335xi. 2018 X3 M40i currently. |
01-27-2020, 09:57 AM | #602 |
Rep 21
New system firmware v2.0.2.7.gpe.b https://mega.nz/#!f8chgYaI!sLT1Ncahf...5rqBJEQSevWBeA
Changelog (Google translate from chinese): 20.1.7 1. Optimize the connection speed of wireless carplay 2.NBT BMW adds switch headlight carplay will automatically change to dark and white mode 3.NBT supports test code (fourth digit) 4.NBT BMW acc off will disconnect the carplay connection 5.Solve NBT large screen BMW upgrade or restart will appear no single 6. Added NBT BMW P gear to D gear into the front view (lead time is set) 19.12.14 1. Optimize carplay to play music freeze 2.Settings- Audio Added Open Echo Debugging Function 3. Added channel selection in the settings, the default Chinese version is 149 channels, the default English is 36 channels, the channel does not change with the language (2.4GWiFi channel is 6 channels) 4.Fixed the reversing interface with Chinese when setting English or other languages 5. Added menu and back keys to long press the function switch button switch in the settings (need to cooperate with the latest mcu19.12.12) |
01-27-2020, 10:11 AM | #603 | |
Rep 843
01-27-2020, 10:15 AM | #604 |
Rep 21
From Android car stereo Store. I claimed, that phone calls are by default routed via Carplay's Bluetooth, not via car's BT. After installing i 50 times made calls, disconnected and reconnected Carplay on the phone, after this seems memorise, that phone call must make by default via car-s BT.
They given me instruction for update: bmw carplay Download link: https://mega.nz/#!f8chgYaI!sLT1Ncahf...5rqBJEQSevWBeA Operation steps: 1. Unzip 'bmwe客户版v2.0.2.7.gpe.b.rar', then copy the upgrade file "ISPBOOOT.BIN" into the root directory of the USB flash drive 2. Insert the USB flash drive into the USB port 3. Power on the CarPlay system to enter the main menu, click 'Setting'-- 'User Upgrade' -- 'System update' 4. The following menu appears and click “√”, the system will be upgraded 5. Wait for about 1 minute, the upgrade process will occur during the process, and the power cannot be cut off during the process. 6. After the upgrade is completed, it will switch back to the original car interface Last edited by sass24; 01-27-2020 at 10:24 AM.. |
01-27-2020, 12:01 PM | #605 |
Rep 280
Thanks for sharing!
I extracted it and compared both squashfs partitions. Good news first: They seem to be working on different screen resolutions. The folder structure is now: Code:
/etc/accessory/ /etc/accessory_0/ /etc/accessory_3/ /etc/accessory_7/ /etc/accessory_m/ /etc/androidauto/ /etc/androidauto_0/ /etc/androidauto_3/ /etc/androidauto_7/ /etc/androidauto_m/ /etc/aoa_feature/ Code:
if [ -z "$(grep cartype=5 /proc/cmdline)" ]; then grep bdtype=1 /proc/cmdline > /dev/null && mount /tmp/sp/usr/local/etc/accessory_m /tmp/sp/usr/local/etc/accessory grep bdtype=1 /proc/cmdline > /dev/null && mount /tmp/sp/usr/local/etc/androidauto_m /tmp/sp/usr/local/etc/androidauto else grep bdtype=0 /proc/cmdline > /dev/null && mount /tmp/sp/usr/local/etc/accessory_0 /tmp/sp/usr/local/etc/accessory grep bdtype=0 /proc/cmdline > /dev/null && mount /tmp/sp/usr/local/etc/androidauto_0 /tmp/sp/usr/local/etc/androidauto grep bdtype=3 /proc/cmdline > /dev/null && mount /tmp/sp/usr/local/etc/accessory_3 /tmp/sp/usr/local/etc/accessory grep bdtype=3 /proc/cmdline > /dev/null && mount /tmp/sp/usr/local/etc/androidauto_3 /tmp/sp/usr/local/etc/androidauto grep bdtype=7 /proc/cmdline > /dev/null && mount /tmp/sp/usr/local/etc/accessory_7 /tmp/sp/usr/local/etc/accessory grep bdtype=7 /proc/cmdline > /dev/null && mount /tmp/sp/usr/local/etc/androidauto_7 /tmp/sp/usr/local/etc/androidauto fi The bad news is that the files are almost identical, so it doesn't matter which one is loaded. But at least they are working on it. Other interesting finding: Unichip seems to have bought the SoC as well The automatic day/night mode feature seems to be the same as in the latest Bimmertech update (not very surprising, the software comes from Sunplus). Also number 6 with the P to D switch. I wonder what that test code from number 3 is. |
singhinho1.50 |
01-27-2020, 12:31 PM | #607 | |
Rep 843
01-27-2020, 12:51 PM | #608 | |
Rep 1,217
01-27-2020, 01:00 PM | #609 | |
Rep 1,217
But on Android when I disable the mmi's BT call permission it automatically turns itself back on. However it still seems that calls are routed via the BMW BT connection. And the only drawback I have noticed of having both BT connections at the same time is a double beep and cancellation of the google assistant when using the voice button on the steering wheel. The double beep doesn't happen when long-pressing the i-drive controller to trigger the google assistant. |
01-27-2020, 01:48 PM | #610 | |
Rep 8
You can check it very easy if you remove the cover panel below the radio. I need also to say a big thanks to all the people and topic starter who share their experience. Last edited by Caught; 01-27-2020 at 01:56 PM.. |
x-m4n148.00 |
01-27-2020, 02:48 PM | #611 |
Rep 21
Thanks for everyone who has participated in this thread and especially OP!
I'm so glad I found this before pulling the trigger on the Bimmertech for almost 3x as much... I do have a couple questions...I've read every page and hopefully not retreading... 1. I read a few posts about issues with the parking sensors? What exactly is the issue/is it still an issue? 2. I haven't seen anyone comment about the CarPlay texting? Is this seamless? (Siri will guide you through voice-to-text responses to texts you receive) 3. If you have BT for calls on ID, and audio on CarPlay, what happens to texts? Thanks! |
01-28-2020, 10:15 AM | #612 | |
Rep 212
2. I am always able to use the mic without issues to play contents and send SMS and Whatsapp messages. 3. Since I installed the MMI, phone calls using CarPlay (and sometime the MMI Bluetooth for some reason), have been crystal clear! I didn't need to use ID Bluetooth to live with the complex setup. |
01-28-2020, 10:41 AM | #613 | |
Rep 21
What is "the complex setup"? I'm a little confused about the connections...you can connect your phone via bluetooth to ID, via bluetooth to andream, or/and via wifi to andream? |
01-28-2020, 10:52 AM | #614 | ||
Rep 212
The moment iPhone registers with the head unit, it configures Bluetooth and WiFi together. Here is a quote about how it works from https://connectedcarlife.com/tech/ho...carplay-work/: Quote:
01-28-2020, 04:46 PM | #616 |
Rep 396
Tags |
andream, android, android auto, apple, carplay, mmi, retrofit |
