BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > ER Oil Cooler
      08-15-2023, 07:01 PM   #1
Boostedphil698
Boostedphil698's Avatar
Drives: 2015 BMW 435i Xdrive MSport
2015 BMW 435XI  [10.00]
2009 Honda Civic  [0.00]
ER Oil Cooler
Has anyone run the ER oil cooler? How was the install? How has the oil cooler performed?
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily)
      08-15-2023, 08:02 PM   #2
Polo08816
Drives: 2014 335i M Sport
It's probably great for a complete track car.
But unless that's your sole use case, a plug and play M2 style oil cooler is going to be more than sufficient.
      08-15-2023, 08:14 PM   #3
Boostedphil698
I'm skeptical of the CSF cooler. I can't find any other upgrade though.
      08-15-2023, 08:57 PM   #4
thejeremyman9
thejeremyman9's Avatar
4464
Drives: 2015 BMW 335i
My first question is why you need the extra cooling capacity? Are you driving hard enough to overheat oil/exceed stock cooling system?
      08-16-2023, 05:12 AM   #5
Boostedphil698
Not immediately. Everything is in preparation of big power. ~700hp
      08-16-2023, 05:24 PM   #6
rphz
Drives: 2014 F32 435xi
Any particular reason why?
I ended up getting the CSF oil cooler as it's a direct replacement if you already have the aux cooler and doesn't require the new lines. I saw some pictures of the ER one installed and the oil lines are extremely close to the drive belt and pulleys. I've had the CSF installed for a year and a half and have had no issues with it and it does help with oil temps on the track.
Polo088161626.50
      08-16-2023, 05:26 PM   #7
Boostedphil698
I haven't seen any hard data that it does anything
      08-16-2023, 06:15 PM   #8
Polo08816
I have a CSF oil cooler as well.
While the ER appeared to be more capable, the install looked far more involved.
