03-12-2021, 04:17 PM | #1 |
Rep 7,466
Malo industries crank seal plate/crank seal guard for N54, N55, and S55
This is a quick summary of my take on the malo industries crank seal plate, for a more indepth review and all the technical details (with alot of back ground and explanations) of why you need a crank seal plate and why belt failures may occur go to my main thread: https://f87.bimmerpost.com/forums/sh...6#post27336806
Here are the reasons why you need a crank seal plate and why I think the malo industries plate is the best choice: 1) If oil (common gasket leaks, oil change), fluids (coolant leaks, rain from a vented hood), or debris gets on your serpentine belt it can slip off of the harmonic dampener and get caught behind it and end up being forced into your engine causing catastrophic engine failure. On rare instances belts can break during track use and also end up in your engine. The solution is a crank seal plate and the one I chose and like the most is the Malo industries plate. 2) Made in Canada (at the time of this writing from what I know only 3 plates are made in North America: Malo, Vac/Kies (can have fitment issues due to the ridge), Oxwerkz - not cnc constructed) - meaning good quality and great tolerances which is important because the fitment must be perfect or it will rub against the harmonic dampener and if it is not tight enough around the crank hub the belt fragments can still make it past the plate rendering it useless. 3) CNC from a single piece of billet aluminium meaning the plate is extremely strong which is important because the stresses of a belt break and being forced behind the dampener is immense. 4) Does not have the alignment ridge which may cause fitment issues because it hits the crank seal. 5) Is extremely affordable at ½ the price of many made competitor plates that are also made in North America (Vac/Kies - same plate) and made out of cnc billet aluminum. 6) Extremely robust tab design with alot of supporting material compared to other billet plates
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 03-12-2021 at 10:37 PM.. |
03-12-2021, 07:04 PM | #2 |
Rep 7,466
I should also mention this fits the F30 335i and F32 435i, Xdrive or RWD, manual or ZF.
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
Pussiwillow522.00 |
03-16-2021, 07:39 AM | #4 |
Rep 1,499
Thanks for posting this. I've been waiting for a cheaper alternative to the Kies crank seal plate but wanted a part machined from solid aluminum. This fit the bill so I just ordered one along with the BMW Accessory Drive Belt Kit - 11288604266KT from FCPEURO. I just clocked of 85k miles so replacing the belt tensioner kit and adding the crank seal cover for piece of mind.
F87source7300.50 |
03-16-2021, 09:31 AM | #5 | |
Rep 90
johnung4531.00 |
03-16-2021, 01:26 PM | #6 |
Rep 7,466
There are fitment issues reported with this plate, read my main thread for the images and full details.
03-16-2021, 01:29 PM | #7 | |
Rep 7,466
Accessory belts are also replaced based on time as well. As per continental these belts need to be replaced by 5-6 years before they start to degrade, and since new belt tech is formulated to not crack these belts wear thinner like a tire. So the only way to determine if it is time to replace based on wear is a belt wear tester. You can read the full thread for more details. Post install pics too whenever you install, and congrats on your purchase!
03-16-2021, 01:30 PM | #8 |
Rep 7,466
That's not the case for everyone, if you look at my original install thread you'll see why. I'll also try to bring those images here later on.
03-16-2021, 03:37 PM | #9 | ||
Rep 7,466
" Credit: BMWHoochie post #82 (https://www.spo olstreet.c om/threads/who-has-this-crank-seal-protection-plate.5221/page-5#post-108917) In this image you can see the small gap between the surface of the block and the plate due to the crank seal hitting the alignment ring. Credit: BMWHoochie post #82 (https://www.spo olstreet.c om/threads/who-has-this-crank-seal-protection-plate.5221/page-5#post-108917) In this image you can see the kies motorsports plate (vac manufactured) sitting crooked once one bolt is installed because it was initially sitting too far forwards (due to the crank seal not being recessed far enough back) so the bolt holes do not line up. So when you pull the plate back so the hole does line up it causes the plate to tilt. A slotted bolt hole would fix this issue. However bolt hole alignment is not an issue if the plate sits flush against the block (this area is identical in N54’s, N55’s, and S55’s iirc) which is how every plate is designed to sit or else all the forces of a belt failure will be deflected towards the tabs which may fail. Also if the plate doesn’t sit flush against the block it will hit the harmonic damper as the clearance in that area is extremely tight. So in the instance of a properly installed plate a slotted bolt hole could be a detriment imo as it can cause the plate to be harder to install, create a weaker tab area (as there is less material supporting the bolt) and even possibly move upon belt failure."
Tallicia73.50 |
03-16-2021, 04:04 PM | #10 | |
Rep 90
Thankfully mine sat flush and there were no fitment issues. Thanks Last edited by GAB0; 03-16-2021 at 04:30 PM.. |
F87source7300.50 |
03-16-2021, 04:09 PM | #11 | |
Rep 7,466
For me (if you go to my main thread) I will be doing the bottom up method so there will be alot more room, especially if you partially pull the radiator fan. Malo addressed this issue by not putting that guide ring in, no guide ring means no chance for interference with the seal, and thus no chance for that to cause a fitment issue. The only negative is a bit more hassle during install but it shouldn't be a problem because all you have to do is push up on the tabs to line it up and you can tape it down just to hold it temporarily while you screw it down if you wish. Or just hold down the front while screwing it in.
03-16-2021, 05:27 PM | #12 | |
Rep 5,396
I have the Kies Seal Guard installed on my car and I've seen it fitted on other engines. It is designed and manufactured to fit precisely on stock BMW N54, N55 & S55 engines. Every stock BMW engine that I have seen in this group comes with its front crankshaft seal precisely recessed the exact same amount within the cylinder that holds it. The Kies Seal Guard fits perfectly and after installation doesn't come within 2mm-3mm of the seal itself. Not even close! That is considered a large amount of space with a product that is engineered to fit within 20 thousandths of an inch from the spinning crankshaft. The fact that the Kies Seal Guard is engineered this way is a huge advantage over any other. It is the way BMW would have designed it. See attached photo. The Kies Seal Guard is made to protect the seal and made to be installed perfectly every single time. It takes the human error out of these flat plates that slide all around and have oval bolt holes. They are fully dependent on the installer aligning it and torquing it down perfectly. They aren't indexed to the cylinder like the Kies Seal Guard so if vibration loosens them at all over time, then they are in danger of hitting the spinning crankshaft. In a split second the whole thing would be a hot mess and probably destroy the crank seal. That's another thing that's impressive about the Kies Seal Guard. It uses expensive Genuine BMW engine bolts that are the same style, but slightly longer than the stock bolts being removed. And the Kies Seal Guard itself is exactly the thickness to match that extra length. Other seal guards use cheap hardware store bolts that don't match. The ones that I've checked have a lesser strength grade then BMW Genuine engine bolts. I bought another seal guard online and when I actually had it in my hands, I refused to put that crap on my expensive BMW engine. Then the Kies came out and it was a properly engineered product. Dig deeper and you'll find that these reports of "issues" stem from a few engines that have had their front crankshaft seals replaced and installed incorrectly. They were not recessed the same amount as their original seal was from the factory. Replacement of the front crankshaft seal is not common. In fact it's very unusual unless the car is older/high mileage. Most cars by far still have their original crank seals installed correctly from the factory. The chance that a seal on someone's particular engine wouldn't be correctly recessed is minuscule compared to the number of BMW engines that there are. If anyone goes to install any seal guard and finds that their crank seal is not recessed properly, I'd encourage them to remove it and install a new seal to the correct factory depth. Leaving it that way is an engine disaster waiting to happen. |
03-16-2021, 07:24 PM | #13 | |||||||
Rep 7,466
I am not mischaracterizing anything I am simply providing evidence that there are indeed fitment issues with this vac/kies plate, I have nothing to gain by spreading misinformation or trying to get people to buy the malo plate as my partnership for this product has concluded with malo industries. I only did this review to fulfill my end of the sponsorship and to let people know my thought on the plate and spread awareness about this product (which regardless of sponsorship or not I believe in my opinion is the best that is currently available, and the reasons are clearly explained in my main thread, I don't just reach out to any company I only do that with companies who sell parts that I actually would use and think is the absolute best) - that's kind of how a review works... Quote:
The next thing you need to know is Kies didn't design anything this plate is made by vac motorsports and relabeled for kies. Next it clearly was not manufactured with the n54 in mind because most if not all of those engines have flushed crank seals. If you want to argue this point provide some proof instead of saying you have "seen" fitment. Here is my proof: https://www.e90post.com/forums/showthread.php?t=1299182 https://www.e90post.com/forums/showthread.php?t=1299182 https://www.***********.com/showthre...ntenance-check So even on the stock n54 seal that was damaged it is still flush. That's probably why all the plates designed with the n54 as the starting platform (Malo, Oxwerkz, VTT, and the ebay plates) have flat backings because there was no room for an alignment rim. VTT even says in their other thread they designed their plate for engine compatibility across all the platforms. Quote:
Also guess what he said when he contacted vac: "I called VAC and confirmed that they do make the guard for other vendors who put their name on it. I called them because getting some form of speedy communication from Kies was difficult because you can't call them. You send a message, and wait one or two days, they send a message back and ask a question I would reply and would wait another day or two for a response. VAC wanted me to put the guard on, and lightly TAP it back pushing the seal back more (lol NOPE). They also said I could sand the lip down (again NOPE) not for the $200 that I paid. For $200 bucks this thing should come with Netflix. They did say they have new versions with the lip shaved back more because they have got a few complaints about this. I sent it back for a refund." So what do we learn from this? 1) This plate isn't so highly engineered to the point of extremely tolerance in terms of depth from the crank seal. 2) Kies has slow customer service, in my experience with malo it was really responsive customer service. 3) Vac's proposed solution was to "tap the the plate to push the seal back in more" - sounds sketchy as hell to me. They also said that the OP could sand the plate back a bit, again sketch. Sounds exactly what a highly engineered $200 plate needs right out of the box..... 4) Vac is working on a revised plate - hmm if it was so highly engineered to perfect tolerance why do they have to do that. it is also them acknowledging that these seals vary in depth. So far I don't see any huge advantage over other plates, I see a huge compromise in the engineering and a lack of engine fitment testing. It sounds like they designed it off of one engine and then instantly threw it onto the market for sale without having a fitment test. Also I'm sure if bmw designed it, it wouldn't be having fitment issues. Quote:
it may take out human error, but you would have to really suck at working on your car to not be able to position a metal plate. You literally line it up and push backwards (which has been done on hundred if not thousands of n54's without issue on prior plates), if you cannot do that then you probably shouldn't be installing this plate. In regards to the oval bolt holes only the VTT plate has them, and they are slotted bolt holes oval holes wouldn't allow for any movement forwards and back in positioning. The malo plate has circular holes. I don't think you know how this works... Once torqued down there is zero movement regardless of vibration, the only way you can get the plate to move is if the bolts come loose and if that were to occur any plate including the kies plate would be susceptible. Especially once the bolts are loctited in. Next there have been ebay plates that have completely broken by hitting the harmonic dampener and it didn't damage the seal. Credit: Slow335is post#12 (https://www.sp oolstreet.c om/threads/who-has-this-crank-seal-protection-plate.5221/page-5#post-108917 ) Credit: Slow335is post#12 (https://www.sp oolstreet.c om/threads/who-has-this-crank-seal-protection-plate.5221/page-5#post-108917 ) Oh and it seems like you are the one spreading FUD, and in your case you have zero proof or back up so it legitimately is mischaracterization. Quote:
1) IT is fantastic that VAC is using OEM bmw bolts 10/10. 2) Here is where it goes wrong, kies in their installation video does not torque to yield these bolts. What torque to yield does is stretches an aluminium bolts threads preventing vibration from loosening them. Kies did not do this and it leads me to wonder are these torque to yield bolts or just another bmw Etorx bolt with the same m8 thread pattern but longer. If kies has forgotten to torque to yield the bolt as per bmw's TIS (ISTA) then that is a huge mistake and can cause the plate to come loose and create a "hotmess and probably destroy the crank seal" like you said..... If kies did not torque to yield it because it is not a torque to yield bolt then the thing is susceptible to coming loose, and loctite should have been used. Then at this point the bolt is no better than any ordinary bolt, it is just a standard e torx but sold by bmw. BTW you can't yield a standard bolt or you will strip the threads... 2) Now here is where your lack of knowledge comes in, you said other seal guards use cheap hardware store bolts that don't match. First off this is more FUD and misinformation from someone who doesn't know the full situation. Firstly the bolts have the same m8 thread pattern as the block so how can there be a mismatch in this regard? Secondly you must not understand that vac had to design their plate around using the oem bmw bolts because they were only a certain size. Any other company could focus on designing their plate to have the tab at any thickeness that they wanted depending on strength requirements and after that they can pick a bolt to compensate for the thickness of the tab. How is this done? Well you do realize you can literally buy m8 bolts with nearly any mm length you want right? The stock bolt is 37 mm (https://www.realoem.com/bmw/enUS/par...&q=11110392552 -----> https://www.fcpeuro.com/products/bmw...lt-11110392552 -------> x4 11117528896 - ASA-Bolt M8x37 -AL, AW) and you can buy an m8 bolt from 37 mm going up by 1 mm to any length you want..... Literally this allows unparalled flexibility in engineering and design where you engineer based on needs not based on constraints of bolt length. This is a much better engineering philosophy. Next you said oem bmw bolts are lesser strength grade. Again proof or it is more misinformation and FUD. Now there are also 4 counters to this: a) The stock bmw bolt is aluminium and aftermarket bolts like the malo are grade A2 stainless, there is no way the stock alumium bolt is stronger than this especially because it is able to stretch. b) VTT sells grade 12.9 steel bolts, this is the highest strength rating for a bolt. So how is a stretchable alumium bolt stronger? Yeah exactly.... c) The stock block has aluminium threads those are more likely to strip out before any bolt fails.... d) You can replace any crank seal guards included bolts with grade 12.9 bolts if you wish. All these counters makes your point moot and just more fear mongering to justify your $200 expenditure. Quote:
Also price does not define quality, if you think that way then you are susceptible to being screwed over by mark up. Also we have just discussed that the kies/vac plate isn't so well engineered and thought out as you may have expected. There are flaws to this plate which is normal when you try to push the limits of innovation, but compared to other plates out there it is not superior. So at this point I doubt you know what a well engineered plate is. I have held the malo plate, it is extremely stiff with zero play. There is no rough edges or chips and no abnormal jagged edges to the plate. There are no machining burs left over it is an excellently crafted plate. It is also extremely light weight as it should be for its size. Quote:
Also this statement kind of shows your lack of knowledge regarding this platform, and it is frightening how you are the one offering advice regarding what owners should do to their crank seal. This can cause some costly repairs if people with seals that are flushed or not recessed enough start caving to your fear mongering and mess up their seals trying to push it in. Or it can cause someone to spend unecessary money to address a "problem" that doesn't exist. My advice is if your seal is recessed fine, if it is flush also fine, the only time you should touch your seal is if it leaks or is damaged. Also do you have to alter your seal to make a plate fit likely that plate has a poor design. That's why I recommend the malo plate no need to worry about any fitment issues from an alignment ring. The seals installed by the factory are recessed but tolerances are not all the same as shown by reports of the kies plate not fitting. Secondly a flush installed seal is perfectly fine, that is how bmw's TIS specifies to do it, so again more misinformation from you and spreading fear about seals that are supposed to be set at a certain depth. If it is supposed to be set at a certain depth where is your proof??? And what is the depth and what tool are you supposed to use to determine said depth? Here is a screen shot of the bmw tis straight from ISTA: This should conclude this debate, before you reply make sure you have some legit evidence. I'm tired of doing debates with people who just like to argue with no back up.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 03-17-2021 at 02:49 AM.. Reason: Editing grammatical errors |
Tallicia73.50 |
03-17-2021, 10:56 AM | #14 |
Rep 3,540
I think it's important everybody state their affiliations. Some already have.
03-17-2021, 02:03 PM | #15 | |
Rep 7,466
Also every review I have done has been done this way, but regardless I always speak how I truly feel about the items otherwise I wouldn't be able to go into this level of depth, plus I only review things I would put on my own car and that means it must be the best or at times near the best.
03-17-2021, 02:49 PM | #16 |
Rep 1,499
I'll provide a review when I install
03-17-2021, 02:58 PM | #17 |
Rep 7,466
03-17-2021, 03:21 PM | #18 | |
Rep 3,540
03-17-2021, 03:32 PM | #19 |
Rep 7,466
I couldn't see that part on my phone with the keyboard up lol.
03-18-2021, 04:43 PM | #20 |
Rep 70
Bought one last night. Thanks for this thread!
03-18-2021, 04:56 PM | #21 |
Rep 7,466
No problem! Glad I could have been helpful, post some install pics when you're done with the install!
Btw what plate did you buy and what color/finish (if the malo)?
03-19-2021, 05:04 PM | #22 |
Rep 529
I dont get this one either, so is this for people who never look under their hood whatsoever? Like your ofhg would have to be leaking pretty bad for quite some time for this catastrophic engine failure to occur. I think some people over exaggerate how frequently that may actually happen on these cars and then someone makes a product like this that makes it seem like a must have. Be way easier to just routinely inspect your car for leaks and address issues as they pop up.
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
F32Fleet3606.00 |
