08-24-2020, 05:40 PM | #1 |
Rep 245
What is this arrow on HUD?
I have seen this a few times, but not a lot. I verified that navigation was not active. What is the white arrow pointing down/left?
2017 F30 340i RWD // MG Flasher // xHP // CG DS-1 // ZTR ZMP ZCW ZLP
08-24-2020, 08:53 PM | #3 |
Rep 1,452
Sometimes the arrow stays on after I have used Navigation. I don’t know what it represents since the navigation is over. It stays on until a restart. I don’t have the speed limits.
08-25-2020, 03:47 AM | #4 |
Rep 3,873
Immediate thought - the direction to your destination. Shouldn't stay on though. Haven't seen it on mine.
tex26702412.50 |
08-25-2020, 04:31 AM | #5 |
Rep 27
I had it the other day, I had used the navigation on my previous trip and the arrow appeared to be pointing to that destination, but it wasn't active.
I set a new destination and then canceled it, the arrow disappeared from the HUD. I assume it's just a weird thing that happens now and again. |
08-25-2020, 07:50 AM | #6 |
Rep 359
Same this happened to me ..not on HUD but on the display, and stayed on for sometime.
BeerHerder250.50 |
08-25-2020, 09:00 AM | #7 |
Rep 426
I don't have HUD, but yesterday I was using nav and it stayed on after reaching my destination in the display in the dash. Seemed to be kind of just tracking the road I was on... after I turned off the car and came back later it was gone.
Glacier Silver Metallic 335i X-Drive - Can't leave well enough alone... Fabspeed DP, Wagner Evo Comp II IC, ER CP, BM3 Stage 2 93 OTS, Bimmertech Amp (more to come... always more) Graphite Metallic X3 (nothing yet, but... you know) |
tex26702412.50 |
08-25-2020, 10:27 AM | #8 |
Rep 178
I have no idea what the big arrow is trying to tell me. It doesn't seem to align with where it wants me to go, or what the next turn is.
What is its purpose? Thanks |
08-25-2020, 10:36 AM | #9 |
Rep 894
This is normal. On my car the arrow stays on after youve reached/cancelled your nav destination until you power cycle the car.
2017 440i with Id6
08-25-2020, 11:10 AM | #10 |
Rep 4,449
Drives: '23 X1 28i xDrive
it's the general direction toward your destination. it's present the entire trip when guidance is on.
08-25-2020, 11:47 AM | #11 |
Rep 694
I would agree its a non-termination from the last navigation but could it be "North?"
Some GPS will always have an arrow that points to "North" |
08-25-2020, 12:18 PM | #12 |
Rep 1,641
It is a remnant from Nav. It seems to remain and points in the direction you need to go to the point you set. For me it only seems to do this if I don't stop at the site it thinks is my destination. As a good example for me; since my car often loads my appointment addresses and if that address for example were the front entrance of the building I am suppose to go to and I then park in the back, the arrow will stay on until I park. It goes away the next time you start or shut off the nav setting; at least for me.
08-25-2020, 12:19 PM | #13 |
Rep 245
Thanks for all the replies. It does seem to be a residual pointer from a previous navigation session. In this photo it is pointing southeast so definitely not a North pointing arrow. I can't recall what my previous destination was in this photo, but it is likely pointing to where it had been set to.
I originally thought it was an arrow telling me to lower my speed :-) I slowed down below the limit just to prove that theory wrong.
08-25-2020, 12:41 PM | #14 |
Rep 16,079
08-25-2020, 11:02 PM | #15 |
Rep 1,789
Same here, that arrow stays on the HUD sometimes after using navigation and reaching the destination. I've used voice command "cancel navigation" to try and get it to go away and the lady voice said nav wasn't active. Mine also goes away after shutting off the car and turning it back on.
08-26-2020, 12:48 AM | #16 |
2JZ-GTE
3038
Rep 3,992
It indicates the car next to you wants to race
08-26-2020, 12:14 PM | #17 | |
Rep 259
Why it stayed on I don't know but it is a pretty cool feature, especially when you are blasting down unfamiliar roads when you are not sure where the next turn is or which way it is headed. |
tex26702412.50 |
08-26-2020, 12:47 PM | #18 |
Rep 298
I zoomed in and noticed it is actually pointing out that there is a screw laying on the road that you should avoid.
08-26-2020, 01:51 PM | #19 |
Rep 245
08-26-2020, 06:49 PM | #20 |
Rep 178
So, no one really knows what that large arrow is? I have a 2 series loaner right now, it does not have heads up, but it has the same odd arrow in the gauge cluster. It made no sense at all. Seems very random in its direction.
08-26-2020, 08:14 PM | #21 |
Rep 245
It seems to point to the last destination the Nav system was guiding to even after navigation has been cancelled. It may only happen when you don't actually get to your destination and cancel Nav, but that is speculation.
