BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Spacers Recommendations?
      04-01-2021, 06:14 PM   #1
CamTaylor11
Drives: 2016 435i M Sport (Manual)
Hey guys, so I am currently purchasing a 435i M Sport and the guy who had it before had spacers on the wheels. He told me that he had 15mm in the front and 12mm in the rear. Is that a good set up? I was doing some reading and most people go larger in the rear. I'm assuming he had it like that because he wanted the wheels to line up straight when looking from the front since the rear of the car is wider. But I see a lot of people going larger in the front than the back. Does anyone have a pic of 15mm in the front and 12mm in the rear? What are your guy's opinions on that set up?
      04-02-2021, 12:16 PM   #2
J555
Drives: F31 LCI 340iX
What wheels do you have?
      04-02-2021, 12:58 PM   #3
328iX
David
328iX's Avatar
Drives: 2015 328iX F31
Plenty of pics online, BMS has a good article with photos.
It depends if you're stock height or lowered.
      04-02-2021, 02:33 PM   #4
CamTaylor11
I have stock rims 19inch and lowered on hr sport springs
      04-02-2021, 02:34 PM   #5
CamTaylor11
Bms?
      04-02-2021, 02:54 PM   #6
Silverlining_m2
Silverlining_m2's Avatar
1732
Drives: 2023 M2, 2024 m235i
If you have 704 sport suspension can you share a pic of that setup? I'm about to put sport springs on my 435i with 19's as well and have been wondering how it may look.
2023 M2. ZB. Manual.
2024 m235i
      04-02-2021, 04:39 PM   #7
J555
Then I recommend 12 mm front and 15-18 mm rear for a flush look. H&R sets with longer bolts are one of the great (but pricey) options.
Maybe this would be helpful for you, too:
      04-02-2021, 05:26 PM   #8
CamTaylor11
I have received the car yet because it is being shipped from virginia to south florida but when i do i will post pics. I get the car on monday April 5th
      04-02-2021, 05:31 PM   #9
CamTaylor11
thanks for the vid. I might have to switch them then if that's the case. cause i would think it would be weird if the front end is wider than the back
      04-02-2021, 05:32 PM   #10
johnung
Watch the Kies video that someone posted a link on. It's a great illustration of the spacer options.
Spacer choice is so dependent on the wheel width, wheel offset, tire width and tire tread width. Don't attempt to compare photos of two cars or even two cars in person unless you know those values. Otherwise you can spend money on spacers only to get different results on your own car.
      04-02-2021, 05:57 PM   #11
CamTaylor11
great point! thanks!
johnung4528.00
      04-03-2021, 07:12 PM   #12
Randy Johnson
M340i
Randy Johnson's Avatar
Drives: BMW M340i
2021 BMW M340i  [10.00]
I wanted a flush look and went with 10mm front and 12mm in back. If I did it over I'd do 12mm up front and 15mm in the back. Spacers are such a subtle mod but they really do give the car a better stance.
12mm, 12mm spacer, 15mm, 15mm spacer, spacer, wheels
