08-27-2019, 11:15 AM | #199 | |
Car Hypochondriac
335
Rep 901
08-27-2019, 02:38 PM | #200 | |
Rep 785
The meyle part #s someone mentioned on this page are referred to as lower control arms in the eBay listings. They look more like the thrust arms with their curvy shape though, while the lcas look straight in the product listings |
08-27-2019, 07:58 PM | #201 | ||
Rep 241
09-04-2019, 07:57 AM | #202 |
Rep 396
Drives: 2014 335i M Sport, 2004 .:R32T
just placed my order for lemforder TS and LCA from onlinecarparts.co.uk. They have a sale going on right now so I ended up getting all 4 arms for my F30 for $400 shipped. A lot better than the $1000 shipped I was about to spend on OEM M3 LCA and Turner Monoball pre installed TS from ECS.
The PNs I ordered are below. Lemforder 38256 01 Lemforder 38257 01 Lemforder 38258 01 Lemforder 38259 01 Now I just need to order the spacers or probably have them made at my job. Correct me if I am wrong but its the spacers below for the TS. spacers from Summit Racing: http://www.summitracing.com/parts/KYS-100-377-3 2x http://www.summitracing.com/parts/KYS-100-377-1 2x People have mentioned using 2mm spacers on each side as well for the LCAs? So 4x 2mm spacers? Also, does anyone have the PN for the necessary headlight leveling rod that is needed to use the F8x TS/LCAs? |
10-02-2019, 12:12 PM | #203 | |
Rep 1,597
12-23-2019, 03:16 PM | #204 | |
Rep 47
How did this setup work out for you ? I just ordered m3 arms and want to do m3 TS also. |
01-27-2020, 01:24 AM | #206 |
Rep 1,291
01-27-2020, 08:33 AM | #207 |
Rep 5,456
Drives: F30
I've heard that the M3 LCA/TS move the wheel forward within the wheel well... is this not correct from your experience?
01-27-2020, 08:51 AM | #208 | |
Rep 3,947
I'm also able to fit my 235/45/18 winter tire in the front wheel well without rubbing. |
sspade2464.50 |
01-27-2020, 08:52 AM | #209 | |
Rep 1,291
But the TS does nothing to correct this, which is what i was referring to. I think these LCA are not designed for our cars and we should opt for camber plates, i bought the millway street camber plates which are similar in design to OEM and avoid all those headaches of wheel not being where it's supposed to with the F80 LCA If you think about the geometry of suspension, it's totally wrong to put LCA of the wrong length, since the wheel moves fwd, it makes the lateral thrust force push not against an LCA directly facing it, but at an angle instead, and i think that's weakening it a lot. On top of that if you're somewhat lower it's going to rub at the front. And to finish it, you may be at the end of the steering rack thread when aligning with the wider track width. I tried, and i've come back from that
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
sspade2464.50 |
01-27-2020, 10:41 AM | #210 | |
Rep 891
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 01-27-2020 at 11:04 AM.. |
01-27-2020, 10:49 AM | #211 | ||
Rep 1,291
01-27-2020, 11:10 AM | #212 |
Rep 891
Perfectly fine. I know this to be the case because I spent about two months with my fender linings coated with painters tape to track rubbing. Changes in caster may not appear to influence geometry with the wheels dead on, but certainly does progressively as lock is added. Similarly, Farkle was having rubbing issues with the F80 LCAs, but once he reduced his caster (from around 8.5* to 8* just like the TS do), albeit with a eccentric bushing method, his also went away.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 01-27-2020 at 11:21 AM.. |
09-02-2020, 04:46 PM | #213 |
Rep 833
Drives: BMW F36, E36, E93
I'm now through all 10 pages but just found one describtion of the driving experiance on motorways. Sorry for digging out this old thread but now since my warranty has expired I want to do this modification too, meaning the F80 TS and LCA, no bushings but spacers.
Will this setup worsen the driving with higher speeds on the motorway? Thanks for sharing your experiances.
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
09-02-2020, 06:29 PM | #214 | |
Rep 241
Do i regret it? No not at all. If you are expecting a luxury car soft ride feel on the highway i would avoid ts change for sure. If you want sharper turn in and more road feel, this is a great mod for you. |
10-14-2020, 02:50 PM | #215 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
So for the F30 RWD guys, both the F80 M3 LCA and TS were swapped? Swapping the bushing will prevent the need of spacers?
10-14-2020, 03:34 PM | #216 | |
Rep 833
Such Fun
10-16-2020, 12:29 AM | #217 | |
Rep 3,947
However, the increase negative camber and steering feel will improve significantly. |
BWbimmer276.50 |
10-16-2020, 04:41 AM | #218 | ||
Rep 241
10-16-2020, 04:44 AM | #219 | ||
Rep 241
10-16-2020, 09:36 AM | #220 | |
Rep 3,947
My front suspension modifications are: F80 LCA F80 Thurst Arms Wheel hub/carriers for an additional -.5 degrees of camber M Performance suspension kit square 255/40/18 MPS4S previously and now Conti ExtremeContact Sport I don't feel like NVH has increased that much from the F80 parts alone. |
