06-21-2018, 02:02 PM | #309 | |
Rep 235
06-21-2018, 02:32 PM | #310 |
Rep 581
How do you mean? The China clone will be installed in another car unfortunately so I don't think I can sacrifice its wiring harness!
Current: 2021 M340i xDrive, 2001 530i Sport
Previous: 2015 530d M Sport, 2010 530d SE, 2008 335i M Sport |
06-21-2018, 04:50 PM | #311 |
Rep 235
The only reason the original isn't plug-and-play was due to the fact that the designer likely wasn't able to find/produce the same male + female connector housing as the OEM one. The China clone, on the other hand, somehow did.
06-26-2018, 07:37 AM | #312 |
Rep 1
06-27-2018, 04:43 AM | #313 | |
Rep 581
I'm currently running the ebay version in my F10, it works wonderfully and displays the correct speed limit in mph at all times, yet says 'kmh' under the number which is irritating.
07-04-2018, 12:40 PM | #315 | |
Rep 6
Does anybody use an Emulator and actual map (Europe Next, 2018) and no faults? |
07-05-2018, 10:04 AM | #316 |
North Country Cabriolet Enthusiast
Rep 36
Possible alternative?
Random thought ... Garmin DriveAssist 51.
$139 on Amazon. Lifetime free HD traffic, speed limit data / warning, frontal collision warning, lane departure warning. Of course, it's not integrated with your car's telemetry, so that brings with it certain limitations (e.g. it "false positives" more often because it doesn't know that you've signaled a lane change or are already breaking to avoid a car in front of you). But it actually works quite well ... I have one for my old, "non smart" vehicles. https://www.amazon.com/Garmin-010-N1...ct_top?ie=UTF8 |
07-06-2018, 03:05 AM | #317 |
Schmollbraten
12503
Rep 1,985
The basic difference is always with the clone to the real thing, thats no live data but database data - but displayed into cluster and HUD.
Additional Navi as substitute wouldnt match at least neither nor
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
07-18-2018, 11:29 PM | #318 |
Rep 46
I'm also interested in this. I have a 2016 330e F30. Could you please provide instructions on how to install the Ebay item?
07-21-2018, 11:05 AM | #319 |
Rep 12
This will only work if your map has SLI (Speed limit information) and results seem to vary based on country and map version. I haven't found a way to check this just by looking at the raw map data. Any ideas?
07-21-2018, 05:46 PM | #320 |
Schmollbraten
12503
Rep 1,985
Not sure if I get the question right, but the speed limits are within the navi datas and you couldnt check the presence of them.
Even if youre having SLI or not, the data are present. Bimmer wouldnt release two different kinds of map material. My F32 had navi pro and no KAFAS cameras, installed the emulator from the romanian guys and coded as required and it worked instantly for me. Cant speak for the clone but as read here previously I wont safe money for the wrong reasons
07-31-2018, 12:41 PM | #321 |
Rep 27
-removed-
Previous bimmers: E30 318, E34 524TD, couple of E32 750i, E38 750i
Last edited by Sean750; 10-23-2018 at 12:40 PM.. Reason: FSC code can still be purchased |
08-12-2018, 02:40 AM | #322 |
Rep 8
So last week I received my Chinese emulator and installed it following the steps below:
- VO code 8TH -> Check - update HU_CHAMP2 and KOMBI (based on older version of psdzdata..) -> Check - set HU_NBT (in my case I did this in HU_CHAMP2) speedlimit_info activ -> Check - set KOMBI KI_PIA_SPEED_LIMIT activ -> Check - set KOMBI HUD_PIA_SPEED_LIMIT activ -> Option not available - set KOMBI SPEED_LIMIT_GENERATION activ -> Option not available After this, I can see the three dashes in my Instrument Cluster. But helas, no speed limit signs. I've Googled through this forum but couldn't find an answer to one question: does Move navigation (that makes it Business Navi, right?) contain speed limit info? If the answer is yes, would using a newer version of psdzdata solve my problem? Or what else can it be? |
08-23-2018, 01:44 AM | #323 |
Rep 128
Just fitted my “genuine” emulator to my f82. Very happy indeed - even uses RTTI (or some other voodoo) to update speeds through roadworks - where the speed is dropped on temporary limits it is adjusting.
Works flawlessly. |
08-28-2018, 02:14 AM | #324 |
Rep 46
Would fitting one of these units void my warranty?
I'm keen to get SLI happening, but I still have about 2.5 years of warranty left and I'd hate for the dealer to tell me that I've blown my warranty. |
08-28-2018, 02:32 AM | #325 |
Rep 128
They could argue if something happened to the cluster or associated wiring, but nothing else IMO.
You’d never be excluded from warranty on a gearbox issue or a wheel bearing because you fitted a small electronic box behind the dash. Otherwise the same could be argued of a dashcam or tracker etc. |
08-28-2018, 02:36 AM | #326 | |
Rep 144
If you're concerned when your BMW goes in for warranty, just remove dash cluster and unclip SLI emulator. |
08-28-2018, 06:36 PM | #327 |
Rep 46
How easy is it to remove the instrument cluster to install the emulator? I've never done it before.
08-28-2018, 07:16 PM | #328 | |
Rep 1,076
