02-10-2017, 07:46 PM | #24 |
Driver
465
Rep 1,002
I'm the OP and no I don't particularly need to save the money, just don't want to waste money if different tyres on different axles would cause no issues! But I also want my car to handle as well as it possibly can so, not being an expert or an engineer I asked a simple (or apparently not so simple looking at the replies) question. I also was NOT referring to winter tyres as I never drive in snow or ice so do not use them! I will almost certainly replace like for like as recommended by BMW, but in reality I don't believe most drivers necessarily do. They turn up at their local tyre depot on a Saturday morning, want a tyre there and then and go with whatever is recommended. The chances of the exact size and brand for a direct replacement being in stock is fairly slim I'd say, but then most people don't drive top end cars so maybe it's not so much of an issue!
02-10-2017, 07:49 PM | #25 |
Driver
465
Rep 1,002
I disagree, isn't this exactly what these threads are for, advice and opinions from other drivers. Call me stupid for even asking the question but looking at some of the replies, I'm glad I did (plus my original question made no reference to winter tyres as I never use them)
02-11-2017, 02:53 AM | #27 | |
Rep 15,858
Problem with opinion like, "I've changed tires on one axle and it didn't make any difference", we don't have the full context. Not always very scientific. How do we know how the car is driven? Is it ever put near the limits? I've known folks say how good their car drives, (was in the trade) only to drive the car myself and feel all sorts wrong with it. Individual opinion can be so flawed. Ever seen the car driven along with a tire (or tires) that are nearly flat? Have a word and the driver has no idea! Really? Advice really needs to be tempered with appropriate testing methods and accepted wisdom. Hence best to heed what the car and tire makers along with related safety organisations recommend. |
nozydog465.00 |
02-11-2017, 04:07 AM | #28 | |
Driver
465
Rep 1,002
In fact BMW state that my car comes with 'mixed' performance tyres!!! This clearly refers to the fact that the rear tyres are a different size to the front tyres! Last edited by nozydog; 02-11-2017 at 04:16 AM.. |
02-11-2017, 07:06 AM | #29 | ||||
Rep 15,858
The "mixed performance tyres" statement is not intended to mean mixing different tyre brands. Simply the wheel set up for a particular vehicle, 'staggered' or 'square' as we call it. Doesn't mean a vehicle can't have either option, but characteristics change with say the staggered 'mixed' set. Deliberately so, builds in more understeer for the sport setups. If you have driven the same chassis on the different wheel set types, you'll know how a 'square' setup is a more neutral balance, (better in many cases) and requires more skill to control as you reach the limits. The staggered setup allows more 'give' in car control. But that is different to mixing tyres. There are specific guidelines and recommendations from the tyre manufacturers and organisations like TyreSafe, BTMA (British Tyre Manufacturers’ Association). For example, on using and mixing run-flats. Typical BTMA statement: Quote:
nozydog465.00 |
02-11-2017, 09:22 AM | #30 | |
Rep 8,942
For instance I ditched my 18" wheels w PSS tires in favor of 17" w DWS06 knowing what compromises and advantages I was gaining.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
nozydog465.00 |
02-11-2017, 09:49 AM | #31 |
Rep 4,876
I don't think it was a bad question to ask either. The real issue is not many people in the world actually know what makes up a tire. You just assume it's black, it's rubber, and it's round. Comes in different brands and sizes.
The real deal is there is hardly any rubber in it. It's a hybrid of materials and compounds, and is quite frankly, a marvel of the modern world. Here is great example if you run Michelin Pilot Sports. When you look at the tread, there is a center rib that has no siping (slits in the tire that allow it to contour to unstable road conditions). That rib is made from a compound that repels water so that the tire will have a solid contact patch in wet weather. The inner 1/2 of the tread (closest to the car) is made from materials that deal with everyday driving (rain, rocks, etc). The outer 1/2 of the tire have different compounds that allow it give high traction during cornering (since the car will lean and the weight is transferred to the outer 1/2 of the tire). For winter tires, the compounds are designed to stay softer at cold temperatures, and have a lot of blocky patterns to eject snow from the tread. You'll find that they have a lot of siping (slits) as well that works like little fingers trying to grab whatever it can on ice for traction. Try taking summer sport tires out on 1/4" of melting slush, or a gravel road if you really want to respect life! Since the tires aren't just black circles of rubber, and every manufacturer ahs their own secret recipe of compounds and designs, you have no idea how they will react differently. If you miss-match brands/styles, you can run into a situation where the fronts have amazing grip during a corner, whereas the rears drift more. In this situation, the rear of the car will spin out, causing an unpredictable and dangerous situation. |
02-11-2017, 03:21 PM | #33 |
Rep 8,942
One exception. Say you have summer wheels / tires and a winter set. If you get a flat you can throw one of the other set on to use as a spare in a pinch until you get the other tire fixed. I wouldn't drive too much like that but for a short trip to the tire shop or whatever you'd be fine.
2022 Macan S
02-11-2017, 03:34 PM | #34 | |
Rep 774
i'm not sure if this is a serious post or not....
Polo088161610.00 |
02-13-2017, 04:13 PM | #35 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
2+2 handled as expected..which ever end is going to washout on maneuvers....
NEVER skimp on tires. Period. Your only road contact are those 4 patches of rubber, no matter if you have ceramic, Carbon metallic etc pads. I prefer the ability of short stopping distances and handling/emergency maneuver capabilities for a couple of years over a c-note or 2 in my wallet.
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
Wires1645.50 |
02-14-2017, 12:17 PM | #36 | |
Rep 4,876
And then think about 4 of those little hand prints when pulling 1-G on a cloverleaf! |
