06-23-2019, 11:40 PM | #1 |
Rep 69
Vrsf downpipe doesnt fit?
Hey
I got a VRSF downpipe for b58 and it doesnt fit right (ive installed downpipes before on my n54 and n26 and have good experience in terms of procedure and clocking them... I even used pipe expanders but it wont slide in all the way so I returned it). Did anyone have issues with this company and horrible fit? Im hesitant to give them another shot and would like recommendation Last edited by 340idude; 06-24-2019 at 03:47 AM.. |
06-24-2019, 06:25 AM | #2 |
Rep 124
Drives: 2017 340i M-Sport
Pretty sure I've only seen good things about their b58 products. I had their n54 dps and they were great.
06-24-2019, 09:23 PM | #4 |
Rep 5,457
VRSF has one of the worst fitment track records on the F30 platform, across multiple engines.
This has been going on for at least a couple years. I would run. |
alohasurftoad3076.50 |
06-24-2019, 09:41 PM | #5 |
Rep 1,369
Maybe there really is a reason Evolution Racewerks DP costs more. No issues installing theirs and the welds are a thing of beauty. Not too bad if you catch it on sale.
06-25-2019, 12:04 AM | #6 |
Rep 385
I just installed my vrsf downpipe over the weekend. Easy job and fitment was on point on my b58. I did read that a lot of others had fitment issues.
06-25-2019, 05:37 PM | #7 |
Built Motor F30 340i
403
Rep 257
I had similar issues. We used a pipe expander rented from O Riley's as well as penetrating oil (I think thats what it was) to get it to slide all the way in.
06-25-2019, 10:10 PM | #8 |
Rep 94
My fitment was not good, it makes some wierd high pitched noise at 2.5k and then goes away past 3k
06-25-2019, 10:20 PM | #9 |
Rep 4,876
I found with the catted version, fitment was a bit of a PITA. Once connected to the turbo, I had a bear of a time getting the mid pipe in, and it ended up with their "flex couple" (in quotes since it doesn't flex, and that's 99% of the issue) rammed up against the vertical support. I'm guessing the non-cat versions might be a bit easier to get in.
06-28-2019, 12:52 AM | #10 | |
Rep 190,750
06-30-2019, 05:28 AM | #14 |
Rep 6
Fitted the VRSF to my M140i without any issue. I put some lube on then gave it a good thrust in to the hole, a little bit of wiggling in and out and 30 seconds later it was done but no issues then or sense.
