BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > USA - California > Are any of you 335i/435i guys pushing 400hp... legally? :)
Carbahn Autoworks
      07-18-2018, 01:28 PM   #1
percychow
Drives: 2015 435i M Sport
Hey guys, I'm starting my recipe list for 400hp for my 435i.
Are any of you guys pushing +/- 10hp of that with CARB compliant stuff (or close to it, e.g. keeping a catalytic converter)?
If so, what was your list?
And yes I have searched but it's not totally clear what people are running.
Like name of tune, intercooler, piping, boost pressure, etc.
Happy to follow a link if you got one too. Thanks!
      07-18-2018, 03:05 PM   #2
yoon_209
Masterchief
yoon_209's Avatar
Drives: 13' BMW 335i
most people who are FBO are pushing around 360whp/400 torque
and most of them will have catless dps and a tune in and of itself will not be CARB compliant
BMS Intake | ER CP | VRSF FMIC & DP | MPE | JB4 | APEX ARC-8 | H&R Sport | CF Everythang
      07-18-2018, 03:23 PM   #3
louielouie
Drives: 2015 435i
The Fabspeed HFC uses the HJS 200 cell and won't trigger a CEL, but still isn't CARB legal.
I'm not sure what you mean by close to CARB compliant. Is this to build around smog testing in California? You either fail or you don't.
      07-19-2018, 01:13 AM   #4
percychow
Thanks guys... to clarify. I'm good with tunes and basic bolts on to get me closer to 400hp. But not on board with pulling the catalytic converter as I feel that's the No. 1 pollution reducing thing on our cars.
So the tunes or devices don't have to be CARB certified, but at least emissions friendly when not on the gas.
That make sense?
      07-19-2018, 02:50 AM   #5
louielouie
Drives: 2015 435i
That make sense?
An aftermarket will get you the best gains out of all the bolt ons but that is up to you if you want to swap it out.
I've had an amazing experience thus far with Fabspeed's high flow catted DP. I'm unsure about pollution metrics vs stock, but there's no terrible smell. It's also ~90% as efficient as catless. It will set you back $1,400 though.
      07-19-2018, 12:51 PM   #6
percychow
Thank you Louie...
Thanks, so apart from the cat upgrade... are we talking just a good stage-whatever tune and that's it?
FWIW - I've got 20+ years on the NA side as well as Turbos and Superchargers - but I'm still in the mechanical and chipset mentality.
The web that is the F30 turbos et al with active software systems... that's seems like a minefield of sorts.
Has anyone done or have a clean recipe or list?
      07-19-2018, 09:42 PM   #7
grassy_91
Drives: '18 340i
When I had my 335, I pulled 410whp and 467 or 476wtq with the following mods:
- catless dp (evolution racewerks)
- jb4 (with ewg harness)
- intercooler (evolution racewerks)
- chargepipe (evolution racewerks)
- 3.5 gallons e85 on map5
Dyno was performed at European auto source in Anaheim, Ca January 2017
Youíll never be carb compliant in this state. As long as your car isnít obnoxiously loud and youíre polite if you get pulled over by a police officer, youíll be fine.
Ď18 340i AW
KWv3/JB4
'15 335 M-Sport MGM (Totaled )
KWv3/JB4/IC/DP/CP 410whp/463wtq
'06 Lexus IS350 BC/Work/AFE/Invidia/FSport/Wald
      07-20-2018, 01:40 PM   #8
percychow
Thanks Grassy - if I backed-out the catless set-up and e85... what do you estimate the power to the wheels would be?
      07-20-2018, 05:19 PM   #9
louielouie
Drives: 2015 435i
If you're not planning on changing the downpipe, the only bolt on giving you noticeably more power is the FMIC but it will be incredibly restricted by not changing your downpipe.
The CP doesn't increase power but is preemptive maintenance as the plastic OEM is known to blow (stock or not).
You may be better off just changing the charge pipe as a precaution and flashing stage 1.
      07-21-2018, 10:57 AM   #10
percychow
Thanks Louie - agreed. The intake charge pipe and IC are kind of the easy ones followed by a tune. Some threads mentioned a catted high-flow downpipe which is something to consider too. But my past experiences with non-OEM DP are that they tend to last barely 4 years (smog to smog check).
      07-25-2018, 05:42 PM   #11
grassy_91
Drives: '18 340i
Probably around 330-340. I only did the IC to keep my IATís low. After an oil cooler I was going to be done modding but the car got totaled. Be sure to buy the EWG harness if you want to do e85. It raises the max psi and makes a big difference in map5
      07-25-2018, 10:32 PM   #12
s2kvee
Drives: 2008 BMW E90 M3
400hp legally in California? on a F30 N55, lol NOPE.. you might as well sell your 435i and buy a m3 / m4 if you're worried about legal issues..
an option to avoid catless DP due to pollution would be to use the AFE 400 cell high flow catted downpipe. it will pollute more than original DP but with a 400 cell. its a pretty restricted HFC..
if youre looking to push higher power, running a JB4 with about 3-4 gallons of E85 on map 5. you should get a small kick. Be sure to upgrade your Charge pipe as they are prone to break even on stock boost..
my current set up is Catless DP, ER Charge Pipe, VRSF Intercooler, AFE Momentum Intake, MPE Exhaust, running BM3 on Stage 2 as well as the occasional e30 mix.
2008 E90 M3 6-Speed - Sold
2013 F30 335i MSport 6-Speed - Current
      07-28-2018, 01:33 PM   #13
percychow
Thank you sir! I appreciate your candor. Yes, I weighed the M3/M4 route for about $20k more... but kid running off to college within the year so I'd rather that money to go her. I'll just have to buy my toys later.
Given all the responses - I'll just do the easy stuff and get the 20hp-30hp for now.
      07-31-2018, 03:57 PM   #14
jinxremoved
Drives: F30 335 Dinan Stage 4
Assuming you mean whp, not quite. But I really love my setup.
F30 335. Dinan Stage 4 including suspension. Wavetrac LSD.
      08-04-2018, 05:31 PM   #15
ramos.33f
Enthusiast
ramos.33f's Avatar
Drives: AW F30 335i
You could always go Dinan, it is more expensive but you also get warranty and its carb legal in all 50 states, like their “Big Turbo”.
https://www.dinancars.com/product/D3...e-ewg-no-core/
MHD Stage 2 - Injen Intake - VRSF Catless Downpipe and Chargepipe - Muffler Delete - H&R Sports - BBS LM
IG: ramos.33f
      08-04-2018, 07:15 PM   #16
percychow
Ramos.33f - whoa! How did I miss that?
Thanks for the lead on that one.
But in the grand scheme of things... would this be the recipe for pushing 400hp+ then?
1. Tune
2. Intercooler and piping (upgraded)
3. Intake
4. Turbo
And that's it?
      08-05-2018, 02:59 AM   #17
grassy_91
Drives: '18 340i
1. Tune
3. Intake
4. Turbo
And that's it?
Honestly you donít need a new turbo man. If you just want 400 whp stick with a tune, downpipe, and intercooler. Donít forget chargepipe too. It also depends on your budget but if you donít need crazy power donít get a new or upgraded turbo. I never had an intake on my car and everything was fine. Donít forget to set jb4 to map 5 and get the EWG harness
      08-05-2018, 04:15 AM   #18
ramos.33f
Enthusiast
ramos.33f's Avatar
Drives: AW F30 335i
You canít reach 400 horsepower without sacrificing smog-legal with N55, BMS claims 355 wheel horsepower with intake and full exhaust. An intercooler and catted downpipe may only add 30 max horspower. The next step would be to either switch your fuel system to run E85 and get a tune that is still smog legal (good luck with that) or upgrade your compressor/inlet on your turbo with either a Pure Stage 1 or Dinan Big Turbo.
Dyno Maps are down the page:
http://www.burgertuning.com/N55_JB4_...BMW_tuner.html
IG: ramos.33f
      08-05-2018, 04:28 AM   #19
ramos.33f
Enthusiast
ramos.33f's Avatar
Drives: AW F30 335i
1. Tune
3. Intake
4. Turbo
And that's it?
Personally, in order I would have this list to break the 400 whp mark and still maintain the ability to be smog-legal:
1.) Charge-pipe (preemptive modification, no hp gains)
2.) Intake
3.) 7Ē Intercooler
4.) Downpipe
5.) Exhaust (MPE counts)
6.) ďUpgradedĒ turbo
7.) Tune done at the same time as turbo unless you have JB4
Hopefully other members can add input too
IG: ramos.33f
      08-08-2018, 02:20 AM   #20
grassy_91
Drives: '18 340i
You can go full dinan but itíll cost you a lot more money. Once the time comes to smog your car just go to a shop that will pass you. You wonít even have to worry about a smog check until your car is 6 years old though. Just mod it the way YOU want to and enjoy the car
Ď18 340i AW
KWv3/JB4
