05-05-2020, 03:37 PM | #1 |
Rep 1
hi.
I'm Osman and I own a F30 (2012) Im New to the forum. I've been reading a lot about backup cameras, I've seen install posts and some other post but I couldn't find the answers to the questions I have. I want to install a Backup camera in combination with an Android 10.25 Screen. I'm planning to buy them both on AliExpress. I'm looking for a camera with decent quality which is integrable in my NBT system. - I want the guidelines to be dynamic and as OEM as possible. - I want the camera to turn on automatically when I put the car in Reverse. - I want the camera to turn on immediately (also the Guidelines have to be on as fast as I put the car in park) - I want the camera to shut off when I put the car in Park. also it would be nice to have guidelines that are adjustable. - I want the camera to be able to show in full screen i have a camera installed now but I am not happy with it. the camera comes on pretty quick but the guidelines have to think about showing up sometimes. it takes about 2--3 seconds for the lines to show. help would be appreciated and if you have experience with a certain type of camera let me know! Thanks, Osman |
05-06-2020, 01:40 PM | #2 |
Rep 399
All your criteria are possible except the last one. There is no point in fullscreen because the signal you get from the camera will be stretched and distorted.
Dynamic guidlines are supplied by the Android unit, so buy a camera without guidlines. |
05-06-2020, 01:53 PM | #3 |
Rep 144
There are also backup cameras that support switching guidelines on or off, by cutting a white wire. This could also work well for him.
06-21-2020, 11:27 PM | #4 |
Rep 175
OP, what did you end up buying? In a similar place - looking for the best camera with my Andream MMI unit, and there are hundreds of similar looking products on Ali Express with no way to know which has the best quality (or if claims about resolution/"HD" hold any water when the signal is just going over composite video anyway).
07-23-2021, 10:30 AM | #5 | ||
Rep 15
07-23-2021, 11:08 AM | #6 | |||
Rep 799
it's not hd since it's just rca connector but could not be any happier how it integrates with the mmi box. https://www.amazon.com/dp/B07GXPD56R...PK5G6ESPR9BDCN |
07-26-2021, 07:44 AM | #7 | |
Rep 15
07-27-2021, 11:36 AM | #8 | |
Rep 7
07-27-2021, 03:11 PM | #9 |
Rep 175
I ended up going with https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I had ordered an AliExpress one first but it was impossible to disable the static reverse lines and the quality was also worse. I now have a different car with the OEM camera which is much better But this Amazon one is not bad and does the job. |
08-01-2021, 07:51 AM | #11 |
Rep 125
