05-30-2021, 09:11 PM | #23 | |
Rep 462
05-31-2021, 05:08 PM | #25 |
Rep 54
Hey there brother I still am tweaking my tune with the help of David Shoup in my opinion hes very hard working and knows his stuff. But we have very similar mods
Stage 2 pure turbo with the latest wheel upgrade Pure turbo inlet AFE magnum intake Stage 2 dorshe HPFP NGK iridium plugs gapped at .020 Wagner evo 2 comp intercooler VRSF highflow catted downpipe CTS charge pipe DV+ I am limited to 91 octane here as luck would have it and mine like yours is daily driven. So i have bought a meth kit as it seems the easiest way to get more octane into the system. Currently I have been working with David and we are round 19psi on pump its on the ragged edge and we may back it off a little there are some corrections but the plugs look great no signs of detonation. Many get paranoid of corrections but they happen even with a stock system as I have logged a few totally stock cars and they even get timing corrections. I was always trying to get zero but it seems thats almost impossible maybe with the meth or E50-E85 but not on 91 pee water highly doubtful. Currently Im using MHD but I hear good things about Ecutek and was considering changing over to them if thats what your running can you tell me a bit about it? I have XHP stage 4 as well and love it and I have the Xdelete but personally i like my AWD i spin too much in RWD and i originally bought it cause they said we could use a sport mode like 80/20 split or custom but thats only on the E series so misleading. I feel I am not making as much as you being I have to use 91 versus your 94 but I do need to get to a dyno and see where im at. Thanks following Last edited by PUREF30cjz; 06-01-2021 at 05:04 PM.. |
06-01-2021, 02:58 AM | #26 | |
Rep 2,354
Mind sharing some logs??
(A Dane in China) |
06-01-2021, 08:52 AM | #27 |
Rep 87
Update: I got the car back yesterday from the shop, they told me they detuned and it wasn't bugging anymore, Picked up, when I finally got around to do doing a pull it, 2nd gear I can shit at 6k, then 3rd gear 5k and so on
I'm waiting to see how fast my swhop can get me the HPFP or the PMI, whichever is fastest i'll get it in so I can finally get my car running up again. |
06-01-2021, 04:10 PM | #28 | |
Rep 54
The car is going to my indy to have the oil pan gasket changed and when its there hes going to install ACL race bearings and new rod bolts as well. I currently have a high flow catted downpipe but I also have a catless downpipe and was thinking of throwing it in when he does the pan gasket. But I have heard conflicting stories of if its worth it .... thoughts? https://datazap.me/u/cjz0220/log-162...og=0&data=3-13 |
06-01-2021, 04:35 PM | #29 | |
Rep 7,591
Which catted DP? Not all are created equal. The gains on stock turbo are pretty small for a good catted vs catless but given how slow your turbo seems to spool there might be some real gains there, if you want to deal with all the drawbacks to catless. |
06-01-2021, 05:04 PM | #30 | |
Rep 54
I am currently running the VRSF catted downpipe and have a VRSF non catted as well. |
06-01-2021, 05:13 PM | #31 | |
Rep 7,591
06-01-2021, 05:23 PM | #32 | |
Rep 54
06-01-2021, 09:34 PM | #33 |
Rep 2,354
Looking at the datalog I would say that these guys are very capable. WG control is some of the best I have ever seen on PWG and they do a proper load based tune from what I can tell.
There is always the discussion of boost vs ign timing. I would lower boost until I can run 8° timing but that is just personal preference. Car might make more power running higher boost and less timing - just not as efficiently. Do you mind sharing the contact details to this tuner? PS: I am running de-cat and has been for the last 5 years. Occasionally I get a whiff of "rotten eggs" or what ever people say it smells like. The positive trade off is a great sounding car
(A Dane in China) |
06-02-2021, 12:09 AM | #34 | |
Rep 54
I may try and go catless and see how i like it ...... i guess i can always go back if i dont. |
06-02-2021, 12:24 PM | #35 |
Rep 87
About to order in the PMI kit, my shop recommended I still upgrade my HPFP even if I'm still going with PMI, as my HPFP is pretty worn, and that when I run out of meth up top I could still need the hpfp use.
Now I was under the impression I only needed the PMI kit as that would make the HPFP redundant, or does it still use it lightly? I don't mind buying both HPFP/kit but if I don't need it I'd prefer not to lol. |
06-02-2021, 12:56 PM | #36 | |
Rep 7,591
06-02-2021, 06:05 PM | #37 | |
Rep 462
Granted there is a bit of labor overlap for PI and hpfp, but for a ps2 both would be major overkill. Last edited by 435gc; 06-02-2021 at 08:56 PM.. |
n55david1295.50 |
06-02-2021, 07:10 PM | #38 | |
1296
Rep 3,529
06-02-2021, 07:29 PM | #39 |
Rep 1,148
Shop is taking you for a ride
You won't run out of meth up top if it's set up correctly, if you run out of meth up top and you're tuned for meth, you have big problems real quick... the hpfp isn't gonna save you in any case, pump gas, no need for hpfp, if you ever plan to use E then you may as well get it done for future proofing since labor over laps |
06-02-2021, 07:53 PM | #40 | |
Rep 87
https://www.parkautomotorsports.ca/collections/snow-performance/products/stage-2-5-boost-cooler-s55-n54-n55-direct-port-water-methanol-injection-kit This is the PMI kit i plan to go with And what would cause me to “run out of meth up top” was kinda confused about that part Also i’ve had a long relationship and never had any issues with the shop i use, i’ll definitely ask them about this. Thank you all |
06-02-2021, 08:07 PM | #41 | ||
Rep 1,148
Google n54 port meth injection and check out people's set ups, more modded n54 cars than anything g and "similar" platform cross over, also go check out spool street forums and ask around there as well I'm debating using a meth compatible fuel injector set up instead of nozzles, so I'm still in the air but it can get pretty damn expensive over entry level kits, make sure your controller has outputs for wiring in a fail safe |
06-02-2021, 09:46 PM | #42 |
Rep 2,354
I am using meth both for octane and volume running stock HPFP. Working perfectly. Running dual CP nozzle - no issues. I can highly recommend the Torqbyte CM5-LT. It is a bit of work setting up but after this my setup has run for 2 years without any sort of maintenance/tweaking needed.
I might go as far as recommending against PI for meth. More failure points No proof of unequal distribution running just CP injection MUCH more expensive if you find the need for going with bigger/smaller nozzles
(A Dane in China) |
1bad14-F3029.50 |
06-02-2021, 10:08 PM | #43 | |
Rep 1,148
Some guys in the n54 community were switching from charge pipe to port injection because cylinder 1 and 6 were doing weird timing pulling, some big horsepower cars made a lot more power through port injection but that's another story, better atomization etc but too many variables. Most port injection guys with proper set ups have been maintenance free as well, but as you said, there is more to go wrong ultimately. |
06-02-2021, 10:42 PM | #44 | |
Rep 87
] I've been trying to find people who have used that same PMI kit but haven't had much luck. I'm hoping I won't have to change much from what comes from the kit for what I want to run. |
