11-16-2020, 11:07 PM | #23 | ||
Rep 5,393
FYI- you mentioned the 370/380 calipers using the 380mm diameter rotors because of a 10mm offset on the hub. Actually it's 5mm further out from the hub. The additional 5mm radius adds 10mm to the diameter. Take care! |
11-16-2020, 11:14 PM | #24 | ||
Rep 5,393
The M Performance Kit Installation Instructions say that the car needs to be coded afterwards. But since your car came stock with the 340 front calipers, your car doesn't need to be coded. The factory brake bias code is exactly the same for the 340 and 370 calipers. It doesn't code for specific calipers. It's actually the bias between front and rear brakes. Whether brakes are 340/330 or 340/345 or 370/345, it's the same bias coding. |
11-17-2020, 01:18 AM | #25 | |
Rep 833
Drives: BMW F36, E36, E93
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
11-17-2020, 01:23 AM | #26 | |
Rep 833
https://f30.bimmerpost.com/forums/sh...ghlight=brakes
Such Fun
11-17-2020, 07:14 AM | #27 | |
Rep 83
Drives: 2016 340ix MPPSK| 2015 R60 JCW
https://f30.bimmerpost.com/forums/sh....php?t=1590916 I understand the bosch units are 330mm, the 2 piston brembo is 345mm so should be easy to tell by just looking at the rear of a base 40i. |
11-17-2020, 07:47 AM | #28 | |
Rep 833
Such Fun
11-17-2020, 08:10 AM | #29 | |
Rep 68
2017 440ix w/ M Sport/Aero packages/ MPPSK/MPBBK/6MT
2018 X5 xDrive 35i w/ M Sport |
11-28-2020, 06:52 PM | #30 | |
Rep 68
11-28-2020, 07:05 PM | #31 |
Rep 149
well worth the $$, love these on the track and daily driving
BMWF30GuyUK8.00 paulymu62.50 |
11-28-2020, 07:13 PM | #32 |
Rep 1,934
You can buy the red calipers separately from ECS. Or buy a used blue set from an F30 or stock on the M2/3/4 and powder coat them red.
11-29-2020, 02:27 PM | #33 |
Rep 68
Good to hear. When did you install your MPBBK? Are you experiencing any noise with these rotors as others have mentioned in various threads on this site?
11-29-2020, 03:19 PM | #34 | ||
Rep 5,393
I'd sell the pads that come with it too. They are only average. Hawk 5.0 are superior street performance pads in every category. StopTech does sell crossdrilled only. I have them on two cars. Part numbers below. Front 370mm x 30mm 128.34144L 128.34144R Rear 345mm x 24mm (185mm handbrake) 128.34147L &R Hawk 5.0 Front 340 or 370 pads HB765B.664 Hawk 5.0 Rear 345 pads HB766B.624 No, don't get combo rotors. Adding slots to crossdrilled rotors won't improve bite. It will only create noise and tear up pads quicker. IMO don't waste money on the cryo treatment. The metallurgy on these is already excellent. Definitely upgrade your rubber brake hoses to stainless steel brake lines. It makes brake pedal more solid and responsive. I've used StopTech SS lines for about $108 total. Check Turner for them. The Turner SS lines also look nice although I've never used them. They have been putting them on sale. StopTech SS Lines Front: 950.34032 Rear: 950.34531 Check around for Black Friday pricing. I'd suggest sending Mike at X-PH an email with your part number list. I'm sure that you'll get a great price. Hope this helps! |
pdxdbo331.00 |
11-29-2020, 06:54 PM | #35 | |
Rep 68
11-30-2020, 02:47 PM | #36 | |
Rep 833
Such Fun
BMWF30GuyUK8.00 |
12-01-2020, 07:21 AM | #37 | ||
Rep 5,393
The internal vanes on the StopTech's are directional to provide optimal cooling. They are a higher tech design than the rotors in the MP brake kit. The BMW rotors have excellent metallurgy like the StopTech, but the dimpled/slotted kit rotors are all for show, not actual brake performance. StopTech crossdrilled with Hawk 5.0 pads will easily out perform dimpled/slotted rotors with the kit pads in both dry and in rain. It should be fairly easy to sell the rotors and pads since they are brand new and considered an upgrade to anyone that has the blue M Sport Front 370/Rear 345 brakes. Advertise on local BMW forums within driving distance to meet, since the heavy weight makes them expensive to ship. BMW list pricing can get found on GetBMWParts website. Comparative pricing can be found on ECS. Your parts are brand new and you aren't charging local sales tax so anything at or below ECS prices would be a deal for someone. Link to ECS Note that description incorrectly says that they are crossdrilled/slotted when the are dimpled/slotted https://www.ecstuning.com/b-genuine-...34106797603kt/ Front BMW M Performance Pads https://www.ecstuning.com/b-genuine-...a/34116878882/ Rear BMW M Sport Brake Pads I didn't spot the exact MP pads but this will give you an idea of price. For exact MP pads part number try emailing GetBMWParts https://www.ecstuning.com/b-genuine-...a/34216887576/ Note: the reason that the MP kit doesn't include rear rotors is because F3x's came with two different sizes of handbrakes that are built into the rear rotor hats like drum brakes. Earlier cars had 160mm "drums" machined inside smaller rotor hats. Later cars had 185mm handbrakes inside larger rotor hats. So if someone is retrofitting the MP kit onto a car with a 160mm handbrake then rear rotors in 345x24 need to be purchased with the 160mm handbrake. BMW makes both sizes of rear 345mm rotors. Hope this helps! |
12-01-2020, 08:57 AM | #38 | |
Rep 68
12-01-2020, 12:14 PM | #39 | |
Rep 178
Also recently bought a set of M-Sport front and rear calipers along with discs and pads. Was hoping to get a few bucks back and sell the original setup |
12-01-2020, 07:23 PM | #40 | ||
Rep 5,393
The most valuable piece that is coming off your car is the pair of front Brembo 340mm calipers. Used in grey they are typically $400-$450. If they were blue in perfect condition, probably $450-$500. I really don't know about 330mm rear Bosch calipers. Guessing someone who wants them for an upgrade maybe 100-$200 It's really difficult to price used rotors and pads depending on condition. Front 340 rotors probably $100-$150/pair. Rear 330 rotors maybe $50-$100/pair. Pads maybe $50 or often used as a toss in if someone buys the rotors. Note: Remember that the 330mm rear rotors are made for the newer larger 185mm handbrake. Someone who has older small hat rear 160mm handbrake is going to need a 330x20 rear rotor with 160mm handbrake machined into it. I don't think that I've ever seen one. Could probably mount larger 185mm handbrake rotor. But the car's handbrake wouldn't work. |
12-01-2020, 07:38 PM | #41 | |
Rep 68
12-02-2020, 11:06 AM | #42 | ||
Rep 5,393
You need to have patience. Different guys will try to lowball you. Just like when you buy a used part, you need to know how high you are willing to pay. When selling you always need to know how low you are willing to go on price. If you think that you have set a fair price you have no reason to drop it much for the first guy who contacts you. Unless you really need cash right away. If you are not cash strapped, then it's better to be patient and wait for the right buyer. You only need one buyer who wants what you are selling. Clean the parts well and take quality photos to assure potential buyers. I try to look up part numbers or take clear photos of the part number on the part itself. Remember that you can't guarantee fitment on their car. So be careful what you say, but absolutely give them the data that they need to look up compatibility issues themselves. If it's a local sale pick a convenient public place to meet like a McDonald's or 7/11 parking lot. Park where you are clearly visible and probably on video cameras. My local police department makes a section of their parking lot available to people making online sales. It has signs making it clear that videotaping is happening. I have always had great experiences selling to other BMW guys. But I've read nightmares about Craig's list sales, so it pays to always put yourself in a safe situation. Make clear that you expect cash. If someone turns up pleading poverty and asking if you'll take $150 when you had agreed on $200, say "No, I'd like the amount that we agreed on." If the full amount doesn't immediately appear then just say thanks anyway and immediately get in your car and drive away. Don't listen to any talk, any stories, any con jobs. And whatever you do, do not go with them or follow them to get the money from a friend or a bank machine. The transaction happens at the designated location or not at all. Not trying to scare anyone reading this. Just be smart and put yourself in only positive situations. Do that, and things will go right 99% of the time! Hope this helps! |
12-03-2020, 07:19 PM | #43 | |
Rep 68
johnung4528.00 |
12-29-2020, 07:07 PM | #44 | ||
Rep 18
Drives: BMW F30 318d M Sport LCI
I'm still waiting for the right set of M Performance brakes to come up on the market at a fair price. most lenders are coming up with ridiculous prices in the UK right now.
I need more money for my lifestyle ?
