05-23-2020, 10:49 AM | #1 |
Rep 15
BMW 437m Wheels on BMW 328I X-Drive.
I recently purchased the 437M wheels for my 2014 BMW 328i XDrive .
The wheels came directly off an M4 with the OEM Specs 255/35/19 19x9 ET 29 275/35/19. 19x10. ET 40 I understand this will not work with the X-Drive system so I decided to square the set and bought 2 more 255/35/19 to match the front My question is, Am I safe with this set up? I dont want to run this risk of messing with the X-Drive, Transfer Case, etc. I've noticed my EPS seems to be heavy one second then lighter the next. Perhaps I need a 4 wheel alignment. Has anyone had this EPS issue resolved with a wheel alignment? Or potentially this could be a SAS issue Notes- Stock suspension Not lowered Any feedback would be greatly appreciated! Last edited by ryanf30; 05-23-2020 at 01:50 PM.. |
05-23-2020, 12:24 PM | #2 | |
Rep 4,327
changing tire sizes WILL NOT change offset. the only way to change offset on a given wheel is, spacers to reduce offset or shave the hub to increase(not recommended) you're the first report i've seen of EPS affected by swap to wider front tires on a wider track. |
05-23-2020, 01:30 PM | #3 |
Rep 681
I'm running that setup on my xdrive wagon. No EPS issues that you're reporting however.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
alohasurftoad3078.00 |
05-23-2020, 01:34 PM | #4 | |
Rep 15
05-23-2020, 01:36 PM | #5 | |
Rep 15
19x9 ET 29. 255/35/19 19x10 ET 40. 255/35/19 |
05-23-2020, 01:52 PM | #6 |
Rep 681
Yup that's what I run. No noticeable changes from stock. Maybe slightly stiffer ride due to less sidewall but nothing too crazy. I think the rear is stretch a bit too much for my taste; I'll probably switch to a 235/40, 265/35 combo when I change my tires to help with that.
2006 997.1 C4S |
05-23-2020, 02:34 PM | #7 | |
Rep 15
05-23-2020, 03:46 PM | #8 |
Rep 681
I'm not sure. EPS issues could be related but best to pull codes to see if there's anything first. Could be fault on the rack or something else. I haven't had any strangeness with my EPS through the various tire sizes and diameter combos I've had.
2006 997.1 C4S |
05-24-2020, 07:55 AM | #9 |
Rep 611
If I am not mistaken, there is also an option to keep the expensive and grippy rear 275/35's and replace the fronts to 245/40? I am using this setup on my not lowered x-drive and I am happy with it.
05-24-2020, 12:36 PM | #10 |
Rep 15
Ok I will plug it into Carly App and see what happens. When you upgraded wheel sizes did you notice your car having less fuel efficiency? My MPG went down when I upgraded to 19" 437M
05-24-2020, 01:20 PM | #11 |
Rep 681
I didn't notice any change but I don't really track my fuel economy closely after going stage 2 tune.
2006 997.1 C4S |
05-25-2020, 06:48 AM | #12 |
Rep 611
05-25-2020, 11:02 AM | #13 | |
Rep 15
05-25-2020, 01:01 PM | #14 | |
Rep 681
View post on imgur.com For a bit better idea of how they'll poke/fit on stock xdrive suspension, here's my 513ms that I happen to take some photos from when I was still on stock suspension. The tire size is a bit shorter than OEM (25.6" instead of 26") so your gaps will be a bit smaller. But the poke and overall fitment will be the same as 513m's are the same width and offset as 437m, just 1" diameter smaller. View post on imgur.com
2006 997.1 C4S |
ryanf304.00 |
05-25-2020, 04:34 PM | #15 | |
Rep 15
Looks great! Here is mine on the 437M set up 255/35/19 19x9. ET 29. (FRONT) 255/35/19. 19x10. ET 40. (REAR) Photo 1 - Rear Tire Stretch on the 19x10 Tire Let me know what you think! Initial Impressions: - Noticed MPG went down from going from stock 17" - Handling Performance Increase View post on imgur.com Last edited by ryanf30; 05-25-2020 at 04:40 PM.. |
328ixdrive, 437m |
