11-29-2020, 09:54 PM | #2 |
Rep 1,934
Go to ECS tuning, kies motorsports any of the sponsors on this forum and look at parts. Choose part(s) in your budget. Do research on said parts here, Google and YouTube. Make decision about said parts. Research some more, make another decision. Then purchase.
11-30-2020, 02:36 PM | #4 |
Rep 833
Drives: BMW F36, E36, E93
Bilstein
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
11-30-2020, 04:21 PM | #5 |
Rep 67
I just installed BC racing coilovers few weeks back and I love it so far! Affordable, very nice drop and adjustability, and feels much better than my old oe m sport suspension.
11-30-2020, 04:27 PM | #6 |
Rep 1,288
dollar per dollar you can't beat "Flatout Suspension" ... SR's Black Friday are only $966... Front's are built like KW's V3 and the rear shocks are inverted like $3000 Ohlins... great shocks.. couldn't be happier...
12-01-2020, 03:03 PM | #7 |
Rep 10,256
The decision to select the right coilovers for your car is a bit more complicated than following recommendations consisting of letters and numbers.
This will help. 1. Budget: KW Street Comfort would be my entry level product. Plan on spending $1800 plus installation plus alignment. You might be able to find a slightly used set on this forum. 2. Adjustment controls: compression and rebound together, compression and rebound independent, only compression or rebound. KW3 coilovers offer independent compression and rebound controls 3. Location of adjustment controls: top or bottom. Bottom is preferred especially for rear coilovers. 4. Lowering range: something you have tod encode. There is no perfect lowering target, other than a cosmetic target - what is commonly known as "reducing wheel gap". 5. Will the vehicle see any track duty? KW3 would be one of my top recommendation if the budget is flexible. |
alohasurftoad3078.00 |
