BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Front Park Distance Control (PDC) Retrofit DYI
Studio RSR
      11-16-2018, 11:45 AM   #199
Nunaat
Drives: E34 525tds F33 420d I01 bmw i3
Originally Posted by roxxor View Post
EDIT: You beat my reply with your update
I absolutely love Rheingold now that I got it working on my laptop, it has helped me with figuring out the problems I was having with my Park Assist retrofit. I wish mine were a simple sensor replacement, instead every so often I get both PDC and Park Assist malfunctions, and the code I'm getting is an "Ultrasonic Sensor: Short Circuit to B+ positive" error, but it isn't kind enough to tell me which sensor has the error. Instead, my test plan in Rheingold is that I have to remove both bumpers and go sensor by sensor through all 10, removing each one and running the test to see if it detects the fault when a particular sensor is removed, then reconnecting it and moving on to the next one.
Hi Roxxor, I have the same ista error but ista say the problem is front left pma sensor with Short Circuit to positive error. How did you solve the problem? Thanks.
F33 420d, E34 525 tds
      11-16-2018, 05:14 PM   #200
Jhnblckwood
Drives: F30 2014 320i xdrive
Make sure the connection is good in the rem. If so maybe the sensor is bad?
      11-16-2018, 05:16 PM   #201
Jhnblckwood
U can try switching sensors and see if it gives same error or if the error follows that sensor.
      02-27-2019, 11:53 AM   #202
Crz13
Drives: F32 435d M Sport xDrive
Hi all,
Weird request, but if I wanted to code out front is the process the same but in reverse? So instead of 508 code to 507?
Reason being I’ve got an issue with my front sensors and it’s annoying that the rears stop working. So would like atleast the rears working until i sort out the fronts. Any help is appreciated
      02-27-2019, 11:55 AM   #203
atzebmw
Drives: Tesla Model 3
Originally Posted by Crz13 View Post
Hi all,
Yes.
      02-27-2019, 12:02 PM   #204
Crz13
Originally Posted by atzebmw View Post
Yes.
Many thanks for the speedy reply.
Would i also have to recode all ECU’s or just REM?
I’ve done quite a bit of FDL coding and just wondering if that’ll reset all back to default so I have to do it all again?
      02-27-2019, 12:27 PM   #205
atzebmw
Yes, after changing from 508 to 507 you have to code the REM and ICM.
And yes, if you code these ecus all FDL codings in REM and ICM will be overwritten.
      02-27-2019, 12:28 PM   #206
Crz13
Thanks once again!
Will the Hu_EntryNav also need reocoding or just REM and ICM?
      02-27-2019, 12:42 PM   #207
atzebmw
Thanks once again!
I'm not sure, but maybe.
In 2.5 hours, I can tell you exactly which ecus have to be coded.
And then i also tell you the solution to keep your FDL codings.
      02-27-2019, 12:52 PM   #208
Crz13
Ok perfect thankyou will wait for your confirmation
      02-27-2019, 03:11 PM   #209
atzebmw
OK, here we are.
If you change from 508 to 507 you have to code the REM, ICM and HU_EntryNav.
If you want to keep your FDL codings you should not code the appropriate ecu.
You then can FDL code this ecu.
On the picture you see the FDL codings for 507 and 508, so you can change the values manually.
      02-27-2019, 04:06 PM   #210
Crz13
OK, here we are.
Thankyou very much!
Will give it a try and report back!
      02-27-2019, 04:48 PM   #211
Crz13
OK, here we are.
So I changed 508 to 507
Followed the correct procedure to save ect
The moved onto coding ICM, REM and Hu_Entrynav
ICM and Hu_Entrynav coded successfully however REM brings up an error when trying to code, error displayed:
“File for “cafd_000007a1-005_005_044_016” not found [C012]”
Any idea?
      02-27-2019, 05:04 PM   #212
atzebmw
Any idea?
Mark the REM and then „detect caf for swe“.
Choose the CAFD with the highest numbers and then „code“.
      02-27-2019, 05:13 PM   #213
Crz13
Im struggling to locate: “detect caf for swe”
I’ve right clicked on REM but only options showing are: code, read coding data, expand and collapse
      02-27-2019, 05:15 PM   #214
Crz13
I’ve located the option: detect caf for swe but it is greyed out...
      02-27-2019, 05:19 PM   #215
atzebmw
Did you mark the REM (the yellow folder)?
Which E-Sys version do you use?
      02-27-2019, 05:26 PM   #216
Crz13
Yes marked the folder. Using v3.28.1 but have just read online that 3.27.1 is better to use so have just installed that but detect caf option is still greyed out?
      02-27-2019, 05:28 PM   #217
atzebmw
Yes, i thought you are using 3.28.
Here you can download 3.27
Edit:
OK, just read you have already installed 3.27
Did you activate the VO (FA)?
      02-27-2019, 05:40 PM   #218
Crz13
Edit:
Option has now become active after I restarted laptop and re-opend the application. Chose the highest file (most bottom/last one)
successfully coded REM
But rear sensors still do not work. I have walked around the rear putting my ear to each of the 4 sensors and all 4 all clicking indicating that they are functional.
Display on screen no longer shows the front but rear shows a triangle with exclamation mark.
Prior to this when I plugged in a code reader tool. All errors for pdc were in regards to the front sensors only.
Any ideas?
      02-27-2019, 05:46 PM   #219
atzebmw
Did you code all 3 ecus or any ecu FDL code?
      02-27-2019, 05:50 PM   #220
Crz13
Coded all 3, (REM, ICM, HU_EntryNav)
Thought I’d FDL code my options back into Hu_Entry afterwards
