BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Front Park Distance Control (PDC) Retrofit DYI
proTUNING Freaks
      05-22-2018, 01:46 PM   #177
Jhnblckwood
Drives: F30 2014 320i xdrive
Did u inject the cafd? Or write ur new vcm to the car?
      05-24-2018, 03:26 PM   #178
Jhnblckwood
Originally Posted by VadikT View Post
HellO!
Could i use set of rear pdc holder (51127312750) for installation front pdc?
Just wondering if u ended up using the rear holders for the front? lol he price is not 10$ difference. Rear is 17$ n front is $60+ at my local shop. My bumper is non sport so I may jus try using the back but before I ordered was hoping someone could add alil more info on this. Even tho the rear ones are labeled I don’t see a difference between them at all. Any help would b appreciated. Thanks.
      07-20-2018, 06:11 AM   #179
ekucet
ekucet's Avatar
Turkey
Drives: 320i ED Sport Plus LCI
Originally Posted by johnnieb View Post
Installation guide and photos added!
Edit 2013-09-29:
- added photos of the installation and the Centre console unit
can you add photos again?
      07-25-2018, 05:58 PM   #180
teutf30
Drives: F30, 2015
Pictures are missing
Same here.
The photos in the first post are no longer available. Can someone please re-upload them?
      07-26-2018, 12:20 PM   #181
Toneskii
Drives: F32, 2015
Hey Guys,
I'm new here and currently upgrading my rear bumper. The mechanic said the PDC system is a one time use and will need to be replaced if the bumper is switched? Is this true or is he trying to get me with a lil scammy scam?
      07-26-2018, 02:23 PM   #182
Sanelko
Sanelko's Avatar
70
Drives: 2012 Jet Black 328i
Originally Posted by Toneskii View Post
Hey Guys,
scammy whammy
      07-28-2018, 06:40 PM   #183
johnnieb
Drives: BMW F30 318D
Originally Posted by teutf30 View Post
Same here.
Sorry, had the pictures on an external picture service that went kaput.
I uploaded them again as attachments.
Nice to see this thread still helps out people
      07-28-2018, 06:45 PM   #184
johnnieb
Hey Guys,
The sensors and the supports are reusable but I'll bet the 3M tape won't
      08-05-2018, 09:33 AM   #185
Levanius
Levanius's Avatar
Spain
Drives: F30 20d M Pack
Just finished. Thanks to all. This post helped me very much!!
      08-07-2018, 08:57 AM   #186
ekucet
ekucet's Avatar
Turkey
Thank you bro. i will try installation.
      08-07-2018, 08:59 AM   #187
ekucet
ekucet's Avatar
Turkey
Where did you get the pieces from? My car has a rear parking sensor and camera but no front parking sensor. Can you share the place you bought with me with the part numbers. Thank you buddy.
      08-09-2018, 01:57 AM   #188
Levanius
Levanius's Avatar
Spain
I bought the pieces from here https://www.leebmann24.de/bmw-ersatzteile/ and from ebay.
For the part numbers please check the post #1 and #3.
      08-09-2018, 07:06 AM   #189
ekucet
ekucet's Avatar
Turkey
Thank you for help me. I will collect the pieces and do it.
      08-09-2018, 07:44 AM   #190
Levanius
Levanius's Avatar
Spain
Post #11 not #3 for part number for M or not M bumper repair kit.
      08-09-2018, 09:06 AM   #191
agad
agad's Avatar
Drives: 18' F32 435d M-Sport Plus
*SORTED*
Manged to get the proper wiring diagram from newtis.com and the wiring should be:
Pin1 ---> Pin 48
Pin2 ---> Pin 36
Pin3 ---> Pin 53
Pin4 ---> Pin 40
Pin5 ---> Pin 41
Pin6 ---> Pin 52
Hope this helps!
Hi, I need some help with regards to the pins in the wiring. I bought the front wiring set that connects to the sensors and built my own wiring from the front bumper to the rear of the car. The installation and coding went well however I have a problem with the pin arrangement. The sensors are not showing the correct location on the screen, for example the right sensor is showing left or middle because the pins are not plugged in the correct location in the REM, this happened because I thought I'd get the correct pin numbers from ISTA/D or from the the official retrofit guide, but unfortunately they are not numbered so I couldn't match my wire colors with the colors mentioned in the retrofit PDF.
I'd appreciate very much if anyone could guide me to the wire colors in the X187 socket which is the connector that connects the front bumper wiring loom to the rear wiring loom.
My custom wiring pin colors is as follow:
Pin1: Orange
Pin2: Violet
Pin3: Blue
Pin4: Pink
Pin5: Green
Pin6: White
I'd need the original pins colors so I can match them with mine and connects them accordingly into my REM.
I connected them to the REM as follow:
Pin1 ---> Pin 48 "Correct as this is for power"
Pin2 ---> Pin 36 "Correct as this is for ground"
Pin3 ---> Pin 53 "Wrong"
Pin4 ---> Pin 52 "Wrong"
Pin5 ---> Pin 40 "Wrong"
Pin6 ---> Pin 41 "Wrong"
Please have a look at the attached photo as this is the socket I need its original pins arrangement
Thanks very much guys!
      08-09-2018, 06:46 PM   #192
Levanius
Levanius's Avatar
Spain
Originally Posted by agad View Post
*SORTED*
Pin1 ---> Pin 48
Pin2 ---> Pin 36
Pin3 ---> Pin 53
Pin4 ---> Pin 40
Pin5 ---> Pin 41
Pin6 ---> Pin 52
Hope this helps!
Pin1: Orange
Pin2: Violet
Pin3: Blue
Pin4: Pink
Pin5: Green
Pin6: White
[img]https://preview.ibb.co/nxFQbU/IMG_3481.jpg[/img]
Did you check this??
      08-09-2018, 06:49 PM   #193
agad
agad's Avatar
Yeah this is the one in the retrofit PDF but it doesn't say the pin numbers in X187, however the proper diagram could be found on newtis website, here's the link:
https://www.newtis.info/tisv2/a/en/f...l-pdc/FpUFBsSH
Cheers!
      09-04-2018, 01:49 AM   #194
Pires751
Drives: BMW F30
I am looking for the centre console and found this with the camera icon.
This icon for what and should i buy this or just buy the item with the P only?
Many thanks
      09-08-2018, 05:31 AM   #195
Opponent
Drives: 320d Xdrive
Anyone know of a technician in the UK, down south to fit the front parking sensors
      09-28-2018, 02:24 PM   #196
BMWE902011
Drives: BMW 328i Drive
I have a 328i Xdrive E90 - 2011 and having a hard time to buy a Front PDC wiring harness for the sensors, does anybody had that issue as well? I called the dealer but I didn't feel secure what the salesman sent to me, did not sound right.
      09-29-2018, 04:18 AM   #197
atzebmw
Drives: Tesla Model 3
Where is the problem?
PDC retrofit cable set has the part number 61120401223.
The complete retrofit set has the part number 66200399629.
      09-29-2018, 05:12 PM   #198
BMWE902011
Thank you for that. The problem is that I bought a car that was rebuilt, it has the back sensors in place but not the front, they painted the bumper and there is no sensors in there, so I need to buy the sensors and the wiring so the mechanic can put it back in order th have both working.
