01-15-2020, 07:57 PM | #1 |
Rep 100
Does RaceChip leave behind any permanent trace?
I was looking at flash tunes like bootmod3 and MHD at first, but realized that they mess with the ECU and leave a permanent trace for dealers to see. So I am now looking at a chip like RaceChip or maybe JB4.
1. Does RaceChip leave behind a permanent trace on the ECU like flashes? 2. They say they can make 350hp for the base chip (435i xDrive), can anyone confirm this? |
01-15-2020, 09:07 PM | #2 |
1296
Rep 3,532
They can still tell by the ecu logging peak numbers.. so just get bootmod3 or mhd.. it wont matter
mgc999115.00 |
01-15-2020, 09:16 PM | #3 | |
Gettin It Figured Out
1820
Rep 2,669
This ^^ ALL data are stored on DME/TCM (boost, over-boost, rpm, fuel pressure, timing, AFR, TQ...) .
mgc999115.00 |
01-16-2020, 10:43 AM | #4 | |
Rep 190,725
2- Sounds reasonable. I recommend the Jb4, its the best piggyback on the market
01-16-2020, 07:43 PM | #6 | |
Rep 1,105
01-16-2020, 07:44 PM | #7 |
Rep 949
That's why it's important the piggyback is well designed as keep all logged parameters within factory specification. It needs to be that way for them to work properly anyway.
01-16-2020, 08:04 PM | #8 | |
Rep 1,105
01-16-2020, 10:16 PM | #10 | |
Rep 7,597
JB4 is the same idea but more sophisticated in the sense that it is controlling other engine parameters to make up for the extra boost, but the concept of tricking the DME so that the DME thinks everything is within the stock tune parameters is the same. |
01-17-2020, 06:26 AM | #11 | |
Rep 1,105
mgc999115.00 |
01-18-2020, 12:28 PM | #12 |
Rep 100
Thanks for all the help. So do you think RaceChip would be a good option? JB4 is more for bolt ons and I don't really plan on doing any bolt ons.
01-18-2020, 12:44 PM | #13 |
1296
Rep 3,532
Any map pressures over the stock range will be logged in the DME, if they really want to know they will. There was a guy here who had a JB4 on his car and the dealer knew based on the saved data in the DME but they let him slide.
01-18-2020, 01:29 PM | #14 |
Rep 949
I don't suggest RaceChip at all, do the JB+ if you want really simple and inexpensive or JB4. The JB4 is just so much better even for factory cars and not much more expensive most people go right to that. It also has a lot better resale value than any of the other options down the road so actually winds up being cheaper in the long run.
01-18-2020, 01:31 PM | #15 |
Rep 949
Hate to repeat myself the but the DME only ever sees FACTORY boost pressures with a JB4 or other properly designed system. Dealer was either pulling his chain or saw scratch marks on the factory connectors and was guessing he tuned it.
