01-28-2020, 09:43 AM | #1 |
Rep 942
Transmission Temperature Diagnostic Tool?
I did a quick search and couldn't find any related threads. I'm looking for a good diagnostic tool I can purchase to check transmission temp while I do a transmission fluid flush.
I've got bootmod3, that wouldn't happen to have that diagnostic built in? |
01-28-2020, 12:50 PM | #2 |
Rep 714
When I did the transmission fluid and pan change on my E90 335d, I used an infrared thermometer like this one.
https://www.harborfreight.com/121-in...ter-63985.html |
01-28-2020, 03:16 PM | #3 |
Rep 10,346
Any mid-level BMW scan tool will do. Ex. Alltel
"Drive more, worry less. "
01-28-2020, 03:41 PM | #4 |
Rep 5,391
I haven't tried it but my Bluetooth OBD connector that I use for BimmerCode also has its own app that puts real time gauges on my phone. I use it mostly for the boost gauge but it probably has a transmission temperature gauge capability. I'll have to play with it.
01-28-2020, 03:44 PM | #5 | |
Rep 1,500
Drives: F36 435xd
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
sspade2464.50 |
01-28-2020, 08:36 PM | #6 |
Rep 5,457
Drives: F30
BimmerLink
02-19-2021, 06:07 PM | #8 |
Rep 25
02-20-2021, 04:54 PM | #10 | |
Rep 1,568
If you chose to use an infrared device, be sure to let the temp of the fluid have time to soak through and be reflected by the pan you are reading the surface temperature.
03-12-2021, 06:14 PM | #15 |
Rep 205
I used ISTA+ via the fluid change procedure when I changed out mine.
I am curious though (and a bit surprised) - when I see similar threads, I see a lot of recommendations for Foxwell NT and the like, but rarely do I see recommendations for ISTA+. Is ISTA+ an inaccurate/inferior solution compared to, say, the Foxwell NT, for measuring transmission fluid temps? Wondering if I used the "wrong" tool for the job. |
03-19-2021, 07:57 PM | #16 | |
Rep 605
Ista+ is great once it's properly set up and functioning. |
pw0n43.00 |
