01-23-2019, 12:05 PM | #1 |
Rep 1,862
Drives: powered by bootmod3
*** bootmod3 *** New Dashboard features
Hey guys, wanted to demo the new bootmod3 dashboard and gauge features to you that over time we have collected and now incorporated.
Here are the new features included with the latest 0.10.047 update: - peak recall for min and max values - re-arrangement of gauge using simple drag and drop - close gauges by tapping on them and hitting the x in the top right corner - orientation detection and handling so gauges render appropriately on mobile devices as device changes orientation from portrait to landscape and back - ability to set alarms - min and max threshold values, if breached for a given channel with place a red border around that channel for a period of 5 secs currently. We can expand on this further if needed. Suggestions welcome as always - configure precision(decimals) if defaults aren’t satisfactory for any reason (we have defaults set up for what we feel is pretty decent, e.g. engine speed won’t show with decimal places 🙂 - show a pointer on the gauge or turn it off - change colours for pointer, gauge sweep and dial - configure custom min and max values for each gauge - configure gauge refresh speed. Default is realtime (fastest updating no delay) but you can now also slow down updates to each gauge as needed to 1, 5 or 10 Hz (1, 5 or 10 updates per second) - set each gauge to imperial or metric units and in case of pressure channels to absolute or relative, overriding the global defaults if you like. Say boost you like in psi but temp you prefer Celsius for some reason, now you can - speed, gauges in realtime even faster responding - small mobile device screen support (i.e. iPhone 5) - using a fixed width font for gauge values There is more coming and as always we’re looking to you guys for suggestions so we can build this out even further where needed. Let us know your thoughts💪💪 Web version and the new OBD Agent are released. Android and iOS apps are in app review and should hopefully be available soon for download/update. NOTE: Excuse the low res on the video. It was an upload to Facebook which decided to shrink the resolution of it for some reason
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
01-23-2019, 12:24 PM | #2 |
Rep 521
Good stuff in the update! This might be a reach, but here's a suggestion.
To expand on the alarm function, would it be possible to have an alarm set to trigger data logging? Beyond that, would it be possible to have buffered logging so that when an alarm triggers, data logging could be seen for 5, 10, 30, etc... seconds prior to the alarm? Similar to a parked car buffered dash cam that gets hit.
2019 M2 Comp, MT, BSM
2015 X5 Msport, CB (Hers) 2014 M235i MT, BSM, MPE, Dinan Springs (Sold) |
harkes1077.00 |
01-23-2019, 09:17 PM | #3 |
Rep 190,750
01-24-2019, 12:47 PM | #4 | |
Rep 1,862
01-26-2019, 04:54 AM | #5 | |
Rep 232
I would personally like to see an update for out transmission shiftspeed and or smoothness, based on our mode: The car is in Sport / Sport+, the shifting would be a bit quicker, the obvious side-effect would be a more abrupt and and sharp. Comfort mode would be smoother than factory, with the obvious side-effect of slower shifting. I believe that something is in the works for that, but maybe someone can confirm... Either way, keep it up guys! |
01-26-2019, 05:06 AM | #6 | |
Rep 232
Boost (pre-throttle) below the digital number is throwing me off... |
01-28-2019, 12:21 PM | #7 | |
Rep 1,862
jv004400.00 |
01-28-2019, 12:25 PM | #8 | |
Rep 1,862
Transmission programming is in a separate ECU from the DME. We might be revisiting that again as time allows. We've spent some time on it in the past but its gone on the back burner due to other priorities that people were pushing for updates/changes on. No matter what/how much we release, everything can always be better and improved upon and that's our only goal
dr.roro195.50 |
01-28-2019, 04:25 PM | #9 | |
Rep 605
Also On stock turbo FBO is 14.5-15psi ok? Looks like I'm doing about the same on my end with California quality gas. |
01-29-2019, 09:10 AM | #10 |
Rep 1,499
14.5-15 psi is perefect. I'm hitting just over 17 psi on stock turbo running the e30 map.
01-29-2019, 09:13 AM | #11 |
Rep 2,653
This is my latest log (1-16). Three third gear pulls from 2.5K RPM with NY 93 shite gas:
http://www.bootmod3.net/log?id=5c35f323c090c64ad8851918
01-31-2019, 12:33 AM | #12 | |
Rep 232
bm3, bootmod3 |
