04-12-2019, 10:03 AM | #23 | |
Rep 243
thatBimmerBloke872.50 |
04-12-2019, 10:15 AM | #24 | ||||||
Rep 5,392
04-12-2019, 10:35 AM | #25 | |
Rep 1,079
I did a bunch of coding on my old 328ix, I only got the eSys cable for $15 from amazon. It was pretty useful, I coded it for sport transmission, rolling windows up with keyfob, got rid of startup warning, changed the chime sound, got rid of warnings on swapping DRLs and low beam bulbs with LEDs, haven't done anything on my 435ix yet. |
learntocode53.50 |
04-12-2019, 10:38 AM | #26 | |
Rep 1,079
04-12-2019, 11:13 AM | #27 |
Rep 1,127
this thread is entertaining. The MPE is a joke to install so the dealership refusing to install it stupid, but I guess we live in a world of zero tolerance. At the same time the MPE is a joke to install just install it yourself. BMW even makes swapping the exhaust hangers, something that is usually a pain in the butt, into an easy task as they can be unbolted from the chassis.
04-12-2019, 11:32 AM | #28 | |
Rep 1,079
04-12-2019, 01:43 PM | #29 |
Rep 5,457
Drives: F30
FWIW...
My dealer has no problem installing OEM parts that I supply. |
04-12-2019, 01:51 PM | #30 | |
Rep 552
A lot of people end up wanting "more" at some point with it comes to the MPE. It sounds nicer than stock, but still leaves something to be desired. Held me over for about 8 months until I needed some more volume. |
04-12-2019, 02:24 PM | #31 | |
Rep 1,079
04-12-2019, 02:25 PM | #32 |
Rep 1,079
BeerHerder250.50 |
04-12-2019, 04:50 PM | #33 | ||||
Rep 5,392
I have the BMW M Performance exhaust because it came with my used car but if I was buying one now I'd look at AWE. I've seen and heard them at BMW car events and they stood out to me over other exhausts including my own. Hope this helps! |
04-12-2019, 09:02 PM | #35 |
Rep 16
04-14-2019, 11:27 AM | #36 |
Rep 1,117
Drives: 2015 BMW M235i
I would never go back to a douchy dealer like this one!
04-14-2019, 12:27 PM | #37 | |
Rep 1,079
04-14-2019, 12:56 PM | #38 | ||
Rep 5,392
04-14-2019, 02:14 PM | #39 | ||
Rep 5,392
04-14-2019, 02:36 PM | #40 | ||
Rep 5,392
04-14-2019, 04:21 PM | #41 | ||
Rep 5,392
04-14-2019, 07:21 PM | #42 | |
Rep 1,079
For the MPPK intake do I just need the part # 11122334344 which is $181 or do I need the entire assembly part# 13-71-8-616-013 for $298? Also does the lifetime aFe Pro Dry filter need regular cleaning? |
04-14-2019, 08:23 PM | #43 | ||
Rep 5,392
Photo1) This is the lower part of the intake box that comes with the M Performance Intake option. It has a hole in the side and I assume that the red piece of plastic is installed by the factory to add strength around the edges of the opening. Photo2) The stock air box bottom does NOT have a hole in it at this location (the location that was outlined in red in photo1) This photo2 shows the stock lower part of air box AFTER the first guy who posted about this DIY upgrade drilled holes in his own stock air box bottom. Photo3) Shows my suggestion which is instead of drilling round holes, cut rectangular shaped holes (indicated by the yellow) in the stock air box bottom between the ridge lines. Not cutting through those ridge lines helps to maintain the structural integrity of the plastic. Make sure that overall, your cuts are within the red area indicated in Photo1. To make the cuts, I would draw the rectangles with a Sharpie. Then drill small holes in each corner. Finally I'd cut out the edges of the full rectangle with either a utility knife with a new sharp blade- first scoring the plastic and then repeating over and over on the line until it cuts completely through. Or use a small Dremel tool with a small cutting wheel. My car came with all the components in the $298 package already installed so I've never seen the stock parts myself. But going by the guy who made this original DYI post, to get the added airflow the only thing needed is to either buy and install the MP bottom to the air box or cut the holes in your stock air box. I plan to clean the aFe Pro Dry air filter once a year in the summer when I usually change my cabin filter. I'll just see what their website suggests for the cleaning method. I checked my aFe filter after the first six months and it still looked new. Hope this helps! |
04-14-2019, 08:26 PM | #44 | ||
Rep 5,392
435 coupe, exhaust, m performace exhaust, mpe |
