10-12-2016, 04:17 AM | #1 |
Rep 114
Enable rear camera and keep it on at all speeds
Hello
I finally found the way to enable and keep on the rear camera at all speeds Last edited by F36420I; 10-17-2016 at 10:19 AM.. |
10-13-2016, 12:49 PM | #2 | |
Rep 397
Thanks for sharing.
Past: E46 Metallic Blue Coupe 323i GONE: E86 Jet Black Z4 Convertible GONE: E92 Crimson Red 335i, F30 Liquid Blue Matallic 328i Current Garage Queen: Mineral White F83 M4 |
Gospeedracer27.00 k4sh_90539.00 |
10-17-2016, 01:48 AM | #4 | |
Rep 56
Rear cam shuts off after 255 meters
I have already coded all all the above in the REM and TRSVC modules. The rear camera stays on forever if I do not move, but still shuts down after 255 meters with D_SCHWELLE_1 and D_SCHWELLE_2 se to "00". (could it have anything to do with "wert_01"/"wert_02"/"wert_03", even though my "werte=00"?) Can you confirm you can have rear camera on ALL THE TIME even after 255 meters? Attached my REM part of the coding |
10-17-2016, 06:17 AM | #5 |
Rep 114
Hello yes I confirm it stays always on
You must chose wert _03 for both REM 3000 The distance when it auto disables rear camera view when in forward D_SCHWELLE_1 wert _03 REM 3000 The distance when it auto disables rear camera view when reverse is engaged D_SCHWELLE_2 wert _03 This will set the werte=00 If it doesn't work also change REM 3201 Max speed when visible and audible warning is given with PDC km/h in hexa CUT_OFF_SPEED werte = FF Last edited by F36420I; 10-17-2016 at 10:19 AM.. |
10-17-2016, 09:21 AM | #7 | |
Rep 114
Sorry an error in the cheat sheet TRSVC 3000 Activate Rear View Camera at any speed SV_Deactivate_Speed werte = it must be 00 not FF Cheat sheet corrected Let me know if it worked Last edited by F36420I; 10-17-2016 at 10:24 AM.. |
10-26-2016, 03:21 AM | #8 |
Rep 5
Hi Marskiller - I followed your excellent instructions on my F32, and it worked perfectly! However, after driving around for a few hours I found it quite disconcerting to have the (moving) rear camera view in my peripheral vision the whole time. Of course I can turn it off by just pressing the PDC button, but what would be great for me is:
- camera turns off like default at say 15kmh or 255m - at any time or speed I can turn ON the rear camera by pressing the PDC button, then turn it off again with a second press. Any ideas? Thanks again for getting this sorted out! |
11-09-2016, 04:33 AM | #9 | |
Rep 114
Hello I didn't have time to check Try to put REM 3203 The distance when it auto disables rear camera view when reverse is engaged D_SCHWELLE_2 to wert _02 |
06-27-2017, 03:52 PM | #11 |
Rep 16,088
06-28-2017, 05:48 AM | #12 |
Rep 2,128
Do the PDC sensors still work when your driving?
Just thinking this may be an easy way of having front PDC on all the time. Activate rearview cam, then press menu, so camera should still technically be active (light above the parking sensor button still on) and hey presto, PDC on all the time too? |
06-28-2017, 07:20 AM | #13 |
Rep 114
Hello
Yes the pdc will be on all the time if enabled trough the button or after engaged reverse. Its nice as I use it like a collision warning or if a biker passes by me to close lol |
06-28-2017, 08:02 AM | #14 |
Rep 16,088
I don't think there's any way to turn off the PDC, if the camera is on the PDC is on. But I can't be sure, no matter what I've tried both the camera and PDC shut down after a few feet of traveling forward, even though the speed and distance shutdown function is coded off. I've also coded to turn on at any speed, but that doesn't work either.
07-07-2017, 08:05 AM | #15 |
Rep 16,088
UPDATE: Since the camera and PDC are tied together I surmised that both would have to be coded to use the camera at all speeds. In my configuration there's no separate PDC module, PDC is controlled by the REM module. That's where I applied these changes:
REM 3203 PdcParkMasterVar V_OFF_PF_R FF REM 3203 PdcParkMasterVar V_SCHWELLE_1 FF REM 3203 PdcParkMasterVar V_SCHWELLE_2 FF REM 3203 PdcParkMasterVar D_SCHWELLE_1 FF REM 3203 PdcParkMasterVar D_SCHWELLE_2 FF After doing that the camera will go on at any speed, and stay on at any speed. However, it still goes off after traveling 255m, as determined by the FF setting in the D_SCHWELLE lines. I'm curious if anyone knows if there's a value that can be entered for D_SCHWELLE that removes the distance limitation entirely rather than just extending it to 255m. |
07-07-2017, 04:00 PM | #16 | |
Rep 8,364
07-07-2017, 10:08 PM | #17 |
Rep 16,088
07-07-2017, 10:36 PM | #18 |
Rep 8,364
07-08-2017, 12:27 PM | #19 |
Rep 749
Drives: 335i xDrive
What is the line to enable zoom feature of rear view camera?
07-08-2017, 02:19 PM | #20 | |
Rep 16,088
https://www.cnet.com/news/bmw-ditche...camera-system/ |
Almaretto2374.00 |
07-09-2017, 12:23 AM | #21 | |
Rep 8,364
08-08-2017, 11:07 AM | #22 |
Rep 16,088
Quoting my own post, I changed the FF to 00 in the REM 3203 PdcParkMasterVar D_SCHWELLE_ 1. That turns off the distance setting entirely, so the camera no longer turns off unless I want it to.
