BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Changing wheels on 19 440i xdrive gc, need tire advice
      02-11-2025, 10:47 PM   #1
AtoB58
Drives: bmw 440i xdrive
Hey yall,
I need to replace my wheels and looking to pick up a set of BBS CI-R (19x8.5 ET 35) and need advice on the tire size.
I have a '19 440i xdrive gran coupe (stock ride height) and currently running the stock staggered set-up (F: 19x8 ET36 225/40r19 R: 19x8.5 ET 47 255/35r19).
With a square setup in mind, has anyone had experience with 255/35 on all fours? Or would I need to get 225/40 to make this all work?
      02-11-2025, 11:10 PM   #2
Tato
Drives: 2019 BMW 440i
255/35 is fine. I'm running 255/40/18, which is the same outer diameter, but on 9.5 et 35
      02-11-2025, 11:29 PM   #3
AtoB58
Ahh thanks, do you know if the 340i and 440i xdrives have the same clearance? Just trying to triple check since the company I ordered my wheels called to make sure, which I appreciate lol.
Thanks again!
      02-12-2025, 02:06 AM   #4
Tato
Thanks again!
I don't know if they're exactly the same, but you aren't running an overly-aggressive fitment, so this setup would fit either cars. Slicer ran a very similar setup to me on his 3 series, so I'd imagine the clearance is fairly similar
      02-12-2025, 02:09 AM   #5
Tato
This guy ran essentially the same setup you're looking at on his 3 series as well
https://f30.bimmerpost.com/forums/sh...e#post20775977
      02-12-2025, 04:15 PM   #6
SD Convert
Drives: 2017 430i convertible
Hey yall,
I think you'll get more responsive handling with either slightly wider wheels or slightly narrower tires. That improvement would come with a slight increase in NVH.
Basis:
I recently upgraded from 255/40r18 on 18x8.5 to the same tire on 18x9. The difference in dynamic response (turn-in) is significant, but there's more road noise and road feel (rough roads are more noticeable). With the shorter sidewalls you're running, the increase would be more noticeable.
Good luck.
2017 430i w/ Strut Brace / M-Perf brakes / M-Sport anti-sway / 255/40/18 square / iDrive-6
tire, tire size, wheel, wheel & tires, wheel size
