BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Anyone have experience with an alibaba steering wheel for f32?
      01-06-2025, 04:55 PM   #1
I4nn
Drives: Bmw 335i
I bought an f8x m sport style wheel from alibaba for my f32 440i, and the paddle shifters don’t work but the volume buttons work. If anyone has bought the same one or similar and had the same problem, is there coding that i have to do in order for the paddle shifters to work?
      01-07-2025, 08:36 AM   #2
Oksamit78
Oksamit78's Avatar
422
Drives: E39, E90, F30 & F34
Did you have the paddle shifters on your original wheel?
2003 E39 530i 5-Speed w/ M Spec, Sapphire/Black, M54B30, Active Autowerke Perf Tune
2010 E90 328i XDrive, Space Gray/Saddle Brown, N52B30A
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12
2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0
2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1
      02-13-2025, 04:49 AM   #3
zatelli
zatelli's Avatar
Morocco
47
Drives: 2013 RWD F30
I'll assume you already had paddle shifters, if not, it requires wiring and coding to retrofit them.
I retrofitted the m-sport steering wheel and from an ODM based in China, and experienced similar issues, with the left shifter. The fix is fairly simple and involves opening the shifters and putting back a loose spring back in place. I think it has to do with careless handling of the steering wheel during transit.
