BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs) > Any recommendation for DIY Ceramic coating product with 1yr + life?
      02-23-2025, 12:36 AM   #45
starlights
Drives: G05 50i
Originally Posted by EvasiveF87 View Post
pro detailer here, get yourself a bottle of gyeon cancoat or optimum glosscoat (known as one of the easiest DIY coatings and the coating I install most frequently for my clients)
If you're not going to polish the car I wouldn't even go for a "true" ceramic coating anyways. You're wasting your time and money. It won't bond properly.
I personally wouldn't recommend mohs to someone doing a first time coating. Nor Carpro. Just my $0.02 after tinkering with these products for years.
Edit / Couple other things
Don't waste your time with a chalky, shitty polish like Meguiars 205. Get a bottle of this instead as it's safe on trim, won't require masking and is super easy to use. You mentioned your car doesn't have a whole lot of heavy defects so this in tandem with a few RUPES Yellow pads is all you need. We're talking a few passes per panel on medium high speed and wiping the polish off. With the condition you described your vehicle to be in there's no reason you should need to spend any more than 60 - 90 minutes polishing.
Secondly, you need a panel wipe before coating. Every coating brand makes one, I usually buy GYEON Prep and call it a day. Panel wipe as you go (after removing the polish) and consider doing one last panel wipe of the entire car at the end.
Third, invest in quality towels if you're going to do this. You need the proper towels to level the coating efficiently. I guarantee you doing this job without the proper towels you are going to introduce a fuck ton of marring and swirlmarks. I've seen it time and time again and it's probably the most overlooked item for people new to detailing. You can spend hours and hours cleaning, correcting etc and the moment you go to apply that ceramic coating with those cheap yellow microfibers you got from costco or that pack from autozone you're ruining all that hard work.
Awesome info, and thanks! I wasn’t aware of the optimum polish but now it’s on my list! I am planning to use the the rag company towels as in link below but please let me know if these aren’t good enough.
https://www.amazon.com/gp/product/B08NQ593K2/ or these https://www.amazon.com/RAG-COMPANY-P.../dp/B00GXRG4L8
Thanks again!
      02-24-2025, 11:56 AM   #46
Strz.luke
Drives: BMW M2 G42
I used CarPro Cquartz Dlux, a bit more difficult to apple but it lasted me around 9-10 moths. Will probably try something different this time but it did the job pretty good. Used a buch of tunel washers too.
      02-24-2025, 12:40 PM   #47
s_ribs
Drives: '15 535i xDrive M-Sport, E30
Originally Posted by starlights View Post
Awesome info, and thanks! I wasn’t aware of the optimum polish but now it’s on my list! I was planning to use the he rag company towels as in link below but please let me know if these aren’t good enough and I should be looking at different towels.
Thanks again!
Those towels will work great!
      02-27-2025, 10:51 AM   #48
BlkGS
BlkGS's Avatar
4346
Drives: BMW X5 M50i
Originally Posted by akashyap View Post
I just applied Adams Advanced Graphene coating. It was pretty easy overall the and the protection seems good. I was a bit nervous as I hadnt done it before but happy with the results. Did it a little at a time over the course of about 5 days.
I used this twice, it's great stuff, tons of protection. Very pleased with it. I'm like 2.5 to 3 years deep with it and it's doing awesome still.
Ingot it in a lot that came with everything needed for like $150. Rags, smiceosuede applicators, surface prep spray, even some nitrile gloves. Better than getting nickel and dimes by these other brands that work equally as well.
      03-03-2025, 08:53 PM   #49
starlights
Drives: G05 50i
I decided to go with Adam’s Advance Graphene as well. Three reasons for my change of heart. First, as pointed above it was easier to get everything in one package since Adam’s is available as kit. Second, yesterday Amazon had a sale and I picked up two kits for both cars at $99 for UV kit and $89 for non uv kit. Finally I saw this video that was helpful.
I have already cleaned and clayed the car. Tomorrow will touch up a few small chips on front bumper and over the next couple weekends once th temperature gets to 60, will polish and apply ceramic. Advice in this thread has been awesome, Thank you all!
Btw, there are tons of great videos on the channel above for other brands and myths of ceramic. Enjoy
bosstones1371.50
s_ribs122.50
