05-14-2015, 08:50 PM | #1 |
Rep 2,379
WARNING!!! JB4 can damage your cars electrical system if handeled improperly
To all current owners of a JB4!
The JB4 installation manual has been updated with the following warning: "Also be very careful when working with the BMS USB cable as it sits close to the battery rail which is a live +12v connection. Allowing the USB cable to touch the +12v connection WILL damage the JB4 and MAY damage the TMAP sensor wiring requiring the ground bypass at the bottom of the guide to be performed. Wrapping a piece of cloth tape over the battery rail connection and/or USB connection will help prevent accidental damage"
(A Dane in China) |
05-15-2015, 10:20 AM | #2 |
Rep 851
Yep, I read that clear as day thats why I never have USB cord connected while I'm not using it. This pretty common knowledge as its pretty clear in the instructions....
05-15-2015, 12:29 PM | #3 |
Rep 1,436
Is this for N20 as well ?!!
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
05-15-2015, 12:49 PM | #4 |
Rep 116,037
The N20 the tuner box is located on the opposite side of the engine so accidentally touching the battery rail isn't a concern there. You should still disconnect the battery when working with the wiring though.
Mike |
05-15-2015, 01:01 PM | #5 | |
Rep 116,037
Mike |
05-15-2015, 01:25 PM | #6 |
Rep 1,436
even posi tape one connected to auto. transmission for read/delete errors ?!
05-15-2015, 07:07 PM | #7 |
Rep 2,379
rustyminded
Route your USB cable inside the cabin or disconnect the battery every time you move it around to be safe. If you store the USB cable under the hood then do it in an insulated bag and secure it safely. Since this warning was not mentioned in the installation manual back in July 2014; I was not aware that a USB cable getting in contact with 12v can cause damage to the ECU. Maybe I am stupid, unlucky or just dont have common 101 knowledge on electronics - no matter the reason I accidentally damaged my ECU. Luckily it can be bettered by small means.
(A Dane in China) |
05-16-2015, 01:29 AM | #8 | |
Rep 1,436
them at shop while man was welding he said no need to disconnect battery so i bought him for that as it's 5 min. job after fixing it read "119002 rail pressure sensor short to ground" i deleted or and it never came back then today i read your post and i was shiting my pants from fear Jon told me as long as error gets deleted in fine but I'm still worried Is there a way to find everything is ok ? |
