BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > First custom made turbo blanket for B58
      10-28-2020, 07:37 PM   #221
WrxToBeamerGuy
WrxToBeamerGuy's Avatar
492
Drives: BMW 340i xDrive
Originally Posted by pauli18c View Post
doesn't help that half the people who bought it can't get it installed themselves
Ended up installing it with two gear head buddies while I sat back and watched. Definitely was not easy and it took upwards of 6 hours to do.
      11-02-2020, 04:55 PM   #222
luke1990
Drives: G30 540ix
It is possible to be done. Not everybody is a mechanic of course so depends on your skill. For me, the blanket made a huge difference in engine bay temperatures - really impressed - it's night and day difference
      11-12-2020, 09:25 PM   #223
Mr. 340
Drives: 2016 BMW 340i
I finally got around to put on my turbo blanket. Took me a while to get around it, I apologize for those who I left waiting on my review, however here it finally is.
The installation I didn't end up doing it myself. I gave it to my shop in which they said the installation was pretty tedious and somewhat complex. It took them around 3 to 4 hours to install it. For sure they recommend to have a second set of hands because doing it alone can be a little more frustrating.
In terms of performance and heat management I have to say, I am very impressed with how much heat it contains. Most of the heat I use to feel when opening the hood is gone. Engine bay temps dropped significantly just by the feel of it. Still have to get some logs done to see the overall IAT difference.
Here are some pics of my engine bay and the turbo blanket. Turbo blanket also helped big time keeping my catch can cooler since I retrofitted the BMS catch can to sit right on top of the turbo manifold to keep my stock airbox, which I also highly recommend to keep IATs lower.
AFE Filter | BMS Intake Pipe
CTS DP | CTS CP | CTS Heat Exchanger
PTP Turbo Blanket | AEM WMI Kit | Custom Exhaust
PJ ACN91 + Meth tune| XHP Stage 3
      11-13-2020, 10:25 AM   #224
WrxToBeamerGuy
492
Would you mind sharing your process for installing that oil catch can in that location? I removed mine to put the stock intake back in and would love to put the catch can where you put yours.
      11-13-2020, 11:03 AM   #225
TheFanatic
TheFanatic's Avatar
Drives: BMW 340i
Are these available for aftermarket turbos? Or just the stock housing
      11-13-2020, 11:04 AM   #226
luke1990
Drives: G30 540ix
Stock housing so our 800 will fit. Maybe Vargas would fit too. But things like big boost they would have to do custom
Mr. 34068.00
kern4174449.50
      11-13-2020, 01:04 PM   #227
TheFanatic
TheFanatic's Avatar
Drives: BMW 340i
the GC+ in specific is what I have in mind. That's a different housing than stock though.
      11-13-2020, 01:04 PM   #228
Mr. 340
Yeah sure. I'll post some pics tonight so you can see how it's setup. Pretty simple.
      11-13-2020, 01:07 PM   #229
luke1990
Drives: G30 540ix
Yeah I would say it should - the housing is not different but nobody will be 100% able to confirm it as we don't have the manifolds next to each other
      11-13-2020, 02:01 PM   #230
WrxToBeamerGuy
492
Thank you!
      11-13-2020, 09:50 PM   #231
Mr. 340
Thank you!
I know this is not the appropriate thread for this but maybe some other people wondered how I did it. Anyways here you go! Pretty simple nothing crazy. All I did was get a nut and bolt and utilized the existing BMS Oil Catch can bracket and attached it to a tab that was right behind the intake. All F30s have it, but I have seen some F30s with a different spec that utilize that factory tab for something else. My tab was completely free in my case. The BMS catch can has multiple holes on top to screw on the bracket from, so just pick the one that works best, for me it was the one on the corner. It might seem a little sketchy but I have had 0 issues with this and it is very sturdy, just make sure to torque it down properly and you'll be fine. From there I just cut down the hoses length to match the new location and done! Took me 15 minutes. (Sorry I don't know how to flip the images vertically)
      11-17-2020, 10:38 AM   #232
WrxToBeamerGuy
492
This is perfect. Thanks so much!
      11-22-2020, 05:07 PM   #233
BMWILUVU
Drives: 340ix
I can see the manifold install was complicated. If I only bought and installed the turbo blanket and not the manifold blanket, can I get away with not having to take a tool to any of my parts? Also, what has ptp got over Design Engineering's turbo blanket?
      11-22-2020, 07:12 PM   #234
weehe126
Drives: 2017 340i
Manifold blanket is the easy part. Turbo blanket is the hard part.
luke1990132.50
      11-23-2020, 07:59 PM   #235
Mr. 340
The turbo blanket is the hardest part. The manifold blanket only requieres the removal of the intake and heatshield. Getting all the way down to the turbo and removing the turbo bracket is what makes everything 10x more complex. If that turbo bracket didn't exist the install would be a breeze.
luke1990132.50
      11-24-2020, 01:13 AM   #236
alpinweiss340
alpinweiss340's Avatar
88
Drives: 340i
Does DE have a B58 turbo blanket available? I haven’t seen any other one made yet? *just curious
      11-24-2020, 05:16 PM   #237
BMWILUVU
Drives: 340ix
Maybe the B58 turbo needs a custom blanket. ECS has the T3 blanket fitting the 340 but I'm not so sure.
      11-28-2020, 09:11 AM   #238
eritF30
Drives: 340i xdrive
Seems like installation would be a bit easier during the downpipe install
      11-29-2020, 12:57 AM   #239
alpinweiss340
88
Drives: 340i
Definitely it would be
      09-16-2021, 10:47 AM   #240
BMWILUVU
Drives: 340ix
What's the verdict? Was anybody able to install this turbo blanket without actually removing any components? Sounds like the headers blanket could be installed without header removal? Can the turbo side blanket be installed by just removal of the downpipe only? I've done so much work this year under and in this car I really don't feel like doing anymore so the easier an install the better.
      09-16-2021, 04:14 PM   #241
alpinweiss340
88
Drives: 340i
You’re definitely going to have to under the car and remove the turbo bracket. You won’t have to remove the header, but be ready to spend a while with the positioning/fishing the wire. If you’re a average gear head who is confident on working on your own car, I’d say this install is a 8/10 on the difficulty level. depending on how you go about the install
BMWILUVU809.00
      09-16-2021, 07:16 PM   #242
BMWILUVU
Drives: 340ix
So you confirm the only items needed removed are the turbo heat shield and the support bracket?
