01-07-2020, 05:39 PM | #15115 |
Rep 741
has anyone coded the tailight for 2016 f36?
i found something on line for f30, but the parameters when i went to code it for my car was slightly different.
2016 435i xDrive F36 M Sport - ER CP | ER Catless DP | VRSF 5" FMIC | bm3 stage 2 93 oct | black double slotted grill | AWE axle back exhaust w/102mm diamond black tips | 437m wheels
01-07-2020, 06:04 PM | #15116 |
Rep 40,779
PM sent.
01-09-2020, 05:35 PM | #15118 |
Rep 741
im sorry, what?
01-10-2020, 10:25 AM | #15120 | |
Rep 741
01-10-2020, 04:50 PM | #15121 |
Rep 1
also looking for the latest coding documents :)
Hi guys/ Shawn. Can you link me up to the coding docs as well?
Would also be interested in doing my lights like that |
01-10-2020, 05:06 PM | #15122 |
Rep 40,779
ID4 vs ID5/6 uses different FSC Codes, so you will need new ones for Navigation, Voice Control, etc..
01-10-2020, 05:37 PM | #15123 |
Rep 40,779
PM sent.
01-11-2020, 01:39 AM | #15124 |
Rep 135
id4
FSC code ok, but about the soft? Can I install id6?
01-11-2020, 06:54 AM | #15125 |
Rep 40,779
What is "the soft"? Are you talking about flashing your ID4 firmware to ID5/6 rather than retrofit an actual ID5/6 Head Unit?
It is possible, but not advisable. ID4 Hardware has 2 Gb of Ram. ID5/6 has 4 Gb. If you flash ID4 Hardware with ID5/6 Firmware, it will run slow, and suffer frequent reboots as it does not have enough memory. And besides new FSC COdes, unless car has a functional ATM module, you will loose all Telematics (e.g. RTTI). Lastly, to keep APIX1 CID (Screen) working on ID5/6 you need to flash it 18-03-xxx max else you get black screen issue.
janea120728.50 |
01-12-2020, 08:21 AM | #15126 |
Rep 2
Hi All!
First post on forum, although I had a great help on coding my US spec F30 LCI (2016) for ECE using BimmerCode with previous posts and Cheat Sheat! I'm having a trouble with the front turn signals, after I had to replace the turn signal module from US to ECE. The issue is that when I enable turn signal or emergency light, they are able to blink twice and then switch off/blink faster (light switch position on "0", with other positions front turn signals might not blink at all). When locking or unlocking the car the both front turn signals are blinking properly. I was trying with disabling "FRA_V_R_KALTUEBERWACHUNG" and "FRA_V_R_WARMUEBERWACHUNG" but without any luck. The errors I'm getting: - Daytime Running Lamp / Parking Lamp Malfunction - Left turn signal malfunction - Right turn signal malfunction I have FULL LED headlights (not adaptive). I'm assuming the errors and the issue is a result of difference between US and ECE turn signal module (additional LED). Note, "MAPPING_SIDEMARKER_L_OUTPUT" and "MAPPING_SIDEMARKER_R_OUTPUT" are coded to "off". Can anyone help me on the issue? Thanks! |
01-14-2020, 04:06 AM | #15127 |
Rep 51
Drives: BMW 530 xdrive
hello shawn,
sorry for my bad english / american I am French !: confused2 can you send me the links and the manual so that I can do it on my 420 dA gran coupe of 2016? I already made some modifications via 'bimmercode' but not in the 'fa' cordially I thank google translation which allows me to translate the comments of the posts on the forum! little questions 1 / when my wife is on the phone in the 420, the gps screen no longer appears while she is talking ... is it possible to modify this? style: having the screen in main display, with a pop-up which displays the name of the call and the communication time, for example ... or when the gps screen returns to its position in auto mode at the end a few seconds ... 2 / can I display a 'shortcut' of my gps on my meter screen? I explain: on my X3, I had a summary of the gps on the dashboard screen (ex: when I arrived on a roundabout, it showed me which exit to take, it was much easier to read rather than turning your head to read on the main screen!) I write in French for French speakers and google translation for English speakers ... if possibly in the code pages, there could be the english and french version of the comments it would be nice ... according to all my readings, the programming is the same as that of the f30 ... cordially Thank you for your answers.... bonjour shawn, excuse-moi pour mon mauvais anglais/américain je suis francais !: confused2 peux-tu m'envoyer les liens et le mode d"emploi pour que je puisse le faire sur ma 420 dA gran coupe de 2016? j'ai déjà fait quelques modifications via 'bimmercode' mais pas dans les 'fa' cordialement je remercie googlge traduction qui me permet de traduire les commentaires des posts sur le forum ! petites questions 1/quand ma femme est au tel dans la 420, l'écran gps ne s'affiche plus tant qu'elle est en conversation...est-il possible de modifier cela? du style: avoir l'écran en affichage principal, avec un pop-up qui affiche le nom de l'appel et le temps de communication par ex...ou alors que l'écran gps revienne en sa position en mode auto au bout de quelques secondes... 2/puis-je afficher un 'raccourci' de mon gps sur mon écran compteur? je m'explique: sur mon X3, j'avais un résumé du gps sur l'écran du tableau de bord(ex: quand j'arrivais sur un rond-point, il m'affichait quelle sortie prendre,c 'etait beaucoup plus facile à lire plutot que de tourner la tete pour lire sur l"écran principal!) j'ecris en francais pour les francophones et google traduction pour les anglophones ... si éventuellement dans les pages de codes, il pouvait y avoir la version anglaise et francaise des commentaires ca serait sympa... d'après toutes mes lectures , la programmation est la même que celle des f30... cordialement merci pour vos réponses.... |
01-14-2020, 08:18 AM | #15128 | |
Rep 40,779
01-16-2020, 02:06 AM | #15129 | |
Rep 2
hello shawn,
any chance you can help me on my issue? Quote:
01-16-2020, 07:20 AM | #15131 |
Rep 40,779
No, sorry. I never swap ECE Light for U.S. I have no idea on compatibility, pinout, etc.
01-16-2020, 10:21 PM | #15133 |
Rep 40,779
01-18-2020, 03:44 AM | #15134 |
Rep 51
01-20-2020, 01:47 PM | #15136 |
Rep 4
Any links for updated files for 2014 F30?
Only ever done coding through bimmercode so trying to make sure I have everything in place before wasting my car battery lol |
