06-10-2020, 12:57 AM | #15379 |
Rep 8
Any chance some knows how to code when petrol engine kicks in on my 330e, there is a setting that give option from 50 to 80, I'll like to be able to go to 30ish
06-10-2020, 11:38 PM | #15380 | |
Rep 20
Able to get to step to "Detect CAFD for SWE" and it finds a bunch of files. When I go to click 'code' I get a bunch of erros. VCM-Update is deactivated. VCM sill not be updated. ZGW-10 - Could not read ComParam 'IDR_required_before_flash' maybe the template is too old then goes on for a bunch more. using PSZDATA 63
BMW 528xi - Premium Package, Cold weather package, Technology package, Navigation, SIRIUS, BMW Assist
06-10-2020, 11:43 PM | #15381 | |
Rep 40,789
06-11-2020, 12:20 AM | #15382 |
Rep 20
Thanks! got a bit further, but no have this error still
TAL execution started. VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197] MCDDiagService<id=84900, job=com.bmw.psdz.jobs.uds.MCD3_ReadFlashTimingPara meters, service=RDBI_FTP - ReadDataByIdentifier FlashTimingParameter, description=error: timeout, link=RDC_20_ETHERNET> [DIAGSERVICE] [] use default timing parameters as an exception occured [WARN] [] - [Exception - RDC - 20] negative response error: code: TIMEOUT P2/T2 occurred description: P2 timeout on Service RDBI_FTP has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; LinkName: RDC_20_ETHERNET severity: ERROR
06-11-2020, 01:33 AM | #15383 | |
Rep 40,789
06-11-2020, 09:53 AM | #15384 |
Rep 20
Could it be because I had done some previous VA coding before? Is there anything I need to do to 'flash' back to factory before I do any ECU coding?
06-11-2020, 11:39 AM | #15385 |
Rep 40,789
Use original unmodified FA, and it should not matter.
06-12-2020, 06:34 PM | #15386 |
Rep 12
hi.
i have install esys 3.30.1 and PSdZData_Lite_v4.22.41, and my car 3 GT F34 has i-level F020-13-11-502. my problem is, that after o connect to car and ai press read FA, i can't activate FA, is loading forever. i have unnistall and reinstall the program 5 times, and still the same problem can't activate FA (loading forever). i have read you old posts with this problem, but i don't know how to solve this. could you please help me? thank you in advance. |
06-12-2020, 07:07 PM | #15387 | |
Rep 40,789
06-14-2020, 09:54 PM | #15390 |
Rep 40,789
06-14-2020, 09:55 PM | #15391 |
Rep 40,789
PM sent.
06-17-2020, 10:09 AM | #15392 | |
Rep 8
06-17-2020, 10:38 AM | #15393 |
Rep 40,789
06-17-2020, 03:19 PM | #15394 |
Rep 1
hi i need help regarding F30 Led fog lights coding, i am getting this error
UNKNOWN] CAF cafd_00000794-018_070_003 does not support FA2FP version 001.000.143 for F030. Minimum required version is 001.000.154. Please use current PDX template! Thanks And Regards |
06-17-2020, 03:29 PM | #15395 | |
Rep 40,789
06-21-2020, 12:38 AM | #15397 |
Rep 40,789
PM sent.
06-21-2020, 04:15 PM | #15398 |
Rep 26
I'm code with bimeercode in basic version not in expert.
Sport gauges, pressure and temperature of tires. Now I have this options in iDrive but its not working, isn't any values |
06-21-2020, 04:29 PM | #15399 |
Rep 40,789
Not all cars support Sport Gauges, and TMPS requires car with Option 2VB Tyre pressure control (TPC), else you don't have actual wheel sensors.
06-24-2020, 04:33 PM | #15400 |
Rep 4
Hi,
Can I get please get the files for my 2017 F30, they just update flashed my car during a service. Thanks. |
