BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Pre-lci instrument cluster failing
      11-06-2024, 06:41 PM   #1
fortythirtyfive
Drives: 435i
Has anybody come across or experienced the below?
My pre-lci instrument cluster appears to be failing, the small rectangle screen across the bottom of the unit often flickers/dims before coming back to full brightness, I've also had it full go out on the odd occasion.
Just recently it's been happening more frequently, car is a 2015 with 90k miles - I'm not really in the market for dropping £800+ on an 6WB.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, B58tu HPFP, MHD Stage 2 HPFP 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru)
      11-07-2024, 10:45 AM   #2
Oksamit78
Oksamit78's Avatar
423
Drives: E39, E90, F30 & F34
Sorry to hear that. The intermittent flickering and stuff could be related to poor connection somewhere on the board or at the plug. Does not hurt to check it out...
2003 E39 530i 5-Speed w/ M Spec, Sapphire/Black, M54B30, Active Autowerke Perf Tune
2010 E90 328i XDrive, Space Gray/Saddle Brown, N52B30A
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12
2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0
2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1
      11-07-2024, 11:14 AM   #3
fortythirtyfive
Drives: 435i
I too thought that, it's never been out before but I still checked it.
I have had a persistent error code about MPG, however it displays perfectly fine on my iDrive display and the instrument cluster so I'm going to guess thats unrelated..
E12C3C - Interface DME, DDE (status of engine fuel consumption, 0x2C4): Signal invalid
This one is also new and persistent:
B7F694 Dashboard: Display backlighting: Short circuit to supply voltage
Guess I'll live with it until the screen goes out permanently ha.
2015 435i - 401whp
      11-07-2024, 07:37 PM   #4
kmarei
kmarei's Avatar
Egypt
818
Drives: 2014 BMW 435i X-drive
2018 Audi RS5  [0.00]
the aftermarket digital dashboard (6WB imitation) is about $400 or about 300 sterling on ali express
not bad, but you need to find someone local to do the programming
as long as you don't have heads up display
it doesn't work with that
      11-08-2024, 09:19 AM   #5
fortythirtyfive
Drives: 435i
Are those the ones which look like the G series clusters?
I remember seeing them when they first came out and the fonts were like times new roman I believe a lot of people were put off by it and they promised tweaks, maybe I need to take another look.
2015 435i - 401whp
      11-09-2024, 11:30 AM   #6
kmarei
kmarei's Avatar
Egypt
818
yep
go check them out, they have a lot of different models at different prices
try to rear some reviews
if i am paying similar money to oem analogue gauges, i would rather go with these
