10-14-2021, 09:54 AM | #23 | |
Rep 4
Drives: f31 330d Touring
10-14-2021, 09:56 AM | #24 | ||
Rep 45
10-14-2021, 12:15 PM | #25 |
Rep 4
10-14-2021, 12:45 PM | #26 |
Rep 45
10-20-2021, 12:20 PM | #27 |
Rep 3
Hello Sir,
I followed the coding on my f20 with the depo v2 lights and it works wonderfully for the daytime running light mode, but for the low beam mode it still flickers, which part of the table do I need to modify you think? Because in daytime running lights mode the rings go out when I put the turn signal so for me it's perfect that's what I wanted ... but for the low beam I would like it to stay on at 100% while I have a flicker like on all modes before your coding ... Thanks in advance, |
10-20-2021, 12:32 PM | #28 | |
Rep 45
Also if you coded in the second table for the dimming drl then up that pwm value to 0x32 or again 0x46 so it dims the drl with indicator without turning it off. |
10-20-2021, 12:58 PM | #29 |
Rep 3
Thank you very much, I will test this, on the other hand if I increase the gradation in the second table and they do not turn off I risk finding the flicker again, right?
So there is a flickering problem on the v2 depo? On this video the headlights work perfectly but with a coding done by a professional. |
10-20-2021, 01:28 PM | #30 | |
Rep 45
I've attached pictures of what mine looked like when they dimmed |
10-22-2021, 11:18 AM | #31 |
Rep 3
Hello Mike,
Here I did what you told me, so indeed the brightness of the leds decreases and does not go out completely, but I have this flickering problem ... Second thing I noticed that on the first table I do not have the same thing as you in the end, I can modify things in the first table it does not change anything ... https://ibb.co/Brx89wB So I don't mind it with your basic settings for the daytime running lights but for the low beam / high beam I always have this flickering and I don't know which one to change to put the LEDs on a higher voltage. Sorry to bother you with this! |
10-22-2021, 02:12 PM | #32 | |
Rep 45
Once you've tried that I guess maybe try setting all of those pwm value to 0x50 to see if that solves the flicker. I should add I am just an enthusiast here and no coding expert, I managed to figure out the coding for the LCI F30 through trial and error and research into the various coding meanings. |
Tags |
coding, depo, f30, f31, lci |
