12-05-2021, 11:58 PM | #133 | ||
Rep 643
If ptf did it conservatively, then using mm stg2+, then use the live adjust feature to change ethanol content to 20%, torque and thus boost, should be reduced as compared to if e30 was in tank. Keep e30 fuel in tank just in case during testing.
M235i rwd 6mt
12-06-2021, 12:45 PM | #134 | |
Rep 7,597
johnung4526.50 |
12-06-2021, 12:51 PM | #135 | |
Rep 7,597
12-06-2021, 03:16 PM | #136 | ||
Rep 643
M235i rwd 6mt
12-06-2021, 07:03 PM | #137 | |||
Rep 5,392
designatedposter175.00 |
12-07-2021, 07:11 AM | #138 | ||||
1296
Rep 3,532
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
12-07-2021, 08:23 AM | #139 | |||||
Rep 5,392
Having my wife stuck at a gas station with an empty tank and not being able to just fill it with 93 is not conducive to my health and well-being. 😀 UPDATE: Bootmod3 tech support responded that they are adding this to their list for the next update of the N55 EWG MultiMap Stage2+. That would mean that you could be driving the E30 tune (with FlexFuel hardware up to E85 in the tank) and if you fill up with 93 Octane, you'll be able to just use the steering wheel buttons to just click over to a 93 base tune within MultiMap Stage2+ rather than be forced to reflash down to MultiMap Stage2 at the gas station. Note: This doesn't mean that they are developing a Stage2+ tune to try to squeeze more power out of 93 Octane. That's like trying to milk a dead cow. Guessing that it would be the same as MultiMap Stage2 93, but accessible from within the MultiMap Stage2+ menu choices so reflashing won't be necessary. This is a huge deal in my state (NJ) and for traveling in surrounding states like PA, DE, MD where E85 pumps are scarce. |
12-08-2021, 10:13 PM | #140 |
Rep 340
just installed their flexfuel kit and test out their stage 2+ multi map.. e30 map but i only had e20 in the tank.. i didnt get a chance to do a full log but boost was around 21psi..
2016 435i GC - FBO - PS2 - XDI-35 hpfp - Stage 2 lpfp - M performance LSD -Custom tune BM3 w/ MHD monitor - xHP Flash stage 3 - Valvetronic Design Exhaust
12-08-2021, 11:55 PM | #142 | |
Rep 340
https://www.bootmod3.net/log?id=61ab...90c666e435a9f0 for some reason my max boost was just around boost was just around 14psi when i flash their 2+ e30 i get around 21psi...
12-09-2021, 12:10 AM | #143 | |
Rep 174
VRSF RACE IC, FTP CP, VRSF CATLESS DP, BORLA ATAK CATBACK, CTS TURBO INTAKE, MST V2 INLET, PURE STAGE 2, TURBOSMART BOV,FTP TURBO OUTLET, SPOOL FX180, BM3 ETHANOL ANALYZER, PRECISION RACEWORKS COILS, BM3 STAGE 2+ E30
12-09-2021, 03:33 AM | #144 | |
Rep 5,392
I'm running MMapSt2 with it now. I can use the steering wheel buttons to switch between 91ACN, 91 and 93. I wonder if E25 logs would show anything different than my E30 and E50 logs for these three tunes? |
12-09-2021, 11:33 AM | #145 | ||
Rep 7,597
12-09-2021, 11:37 AM | #146 | |
Rep 340
hey would you be kind enough to check out my log ?? i just got my flexfuel map from my tuner?? https://www.bootmod3.net/log?id=61b2...0b4316549d6d8a
12-09-2021, 11:50 AM | #147 | |
Rep 7,597
12-09-2021, 11:56 AM | #148 | |
Rep 340
12-09-2021, 05:44 PM | #149 | ||
Rep 5,392
Tip: Don't pump in the E85 amount and then fill the tank with 93. The pumps all shut off at different times. I tell e85Cal that my tank holds like 15.5 gallons instead of 15.8. Then I pump in the exact number of E85 and 93 gallons that it tells me |
12-10-2021, 10:47 PM | #150 |
Rep 263
Blend factors won't scale below zero. Zero is the base map 91, 93, E30 etc. So running E20 on a 2+ tune will still target E30 timing, torque and fuel. It would be like running 91 on a 93 map - sort of.
12-13-2021, 12:46 PM | #151 |
Rep 7,597
Well unless you have a M2 with 93 available in the 2+ map. So for those without that option currently, you wont want to go below E30 with the 2+ map.
12-13-2021, 02:29 PM | #152 |
Rep 263
Weird that they would do that for the M2 and not the 335. Seems like an oversight of some sort.
2018 340i F30 Xdrive
12-13-2021, 02:35 PM | #153 | |
Rep 7,597
Also, one other thing ill mention is that it looked like blend factors were already maxed at 1 when he was running E78. So, i don't think they scale all the way up to 85% ethanol. At E50 they were at like 0.7. |
n55david1295.50 |
12-13-2021, 02:45 PM | #154 | |
Rep 263
