BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Tires wearing down the center, but pressure is on the low end
      04-06-2019, 06:11 PM   #1
Eschmacher
Car Hypochondriac
174
2014 BMW 335i  [0.00]
Hey guys,
I've had a consistent issue with my 335i where the center of the rear tires wears much quicker than the outsides. The fronts wear evenly. I'm running 32psi front/33 rear because I like the way the car handles with this balance.
I've read lots of people recommend that I run 35-38 on the rears which the door sticker seems to agree with. Why is it that my rears wear down the center even though my pressures are lower that recommended? Wouldn't bumping the pressure up to 35-38 just make this issue worse?
For the record, I'm running Michelin PSS, 245/40 front, 265/40 rear (was 275/35).
Power mods: VRSF CP/IC/Catted DP - AFE Cat-back - BM3 S2 93 - XHP S2
Handling mods: B6 damptronic - Eibach prokit - M Performance LSD - M3 brakes - EBC yellow
Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser
Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327
      04-06-2019, 06:15 PM   #2
Eschmacher
Car Hypochondriac
174
May have just answered my own question with some additional googling...
Apparently stiff sidewall tires can show the opposite effect under load, meaning the center wear is due to me under-inflating the tires. This is interesting, I'll have to bump my pressures up and see what happens.
      04-08-2019, 10:00 AM   #3
wdeerfield
A family of bimmers
Drives: '18 G01 X3M40i, '13 F30 335i
i run 34/37 on my MPS4S on my 19s and they handle and wear great. id recommend sticking to the door for tire pressures or slightly varying from that to have proper wear. oh and limit burnouts..
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX
2013 EB/CR 335i xdrive | DHP | 19" VMR V803 | MPS4S | MPerformance | M3 Grills | BMS Tips | LED Turn Signals | CTS intake | VRSF FMIC | VRSF CP
      04-10-2019, 11:16 PM   #4
PabloK
PabloK's Avatar
I run 235/35/20 275/30/20 mps4s - even wear no issues
most common issue for this is a rim that is too narrow. what specs are your wheels?
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is
2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3
2017 Alpina B6
2019 GMC AT4
      04-10-2019, 11:30 PM   #5
328iX
David
328iX's Avatar
Drives: 2015 328iX F31
I run 2 psi higher than sticker, but I do it for tire longevity + mpg, if i wanted more handling oriented setup i'd do at the recommended psi or 1-2psi below that.
I've chucked my car into some corners too at the higher psi and never have any traction issue or noise coming from my tires.
      04-11-2019, 09:07 AM   #6
Eschmacher
Car Hypochondriac
174
18x8.5 +32 front, 18x9.5 +45 rear
245/40/18 front, 265/40/18 rear
Pretty sure it's not too narrow. 265 is the recommended width for a 9.5".
      04-11-2019, 09:10 AM   #7
Eschmacher
Car Hypochondriac
174
The picture you attached is the normal conventional thinking regarding tire pressures and wear patterns, but the issue is (or was) that I run through the center of my tires with low pressure, not high.
      04-20-2019, 03:58 AM   #8
PabloK
PabloK's Avatar
Get them rebalanced new shop
2017 Alpina B6
2019 GMC AT4
