11-20-2020, 06:33 PM | #1 |
Rep 61
Spacers
Hi All,
Hope you are all well. So im planning on getting some spacers for my F30 running 442m wheels. I am thinking 15mm at the rear and 12mm at the front. Can you recommend any spacers at all? Has anyone ran 20mm spacers on a F30 with the 442m wheels on the rears? I've been looking at Bimmec and the Mtec ones... Last edited by Tazzy; 11-21-2020 at 02:59 AM.. |
11-21-2020, 01:59 AM | #2 |
Rep 181
Worth going with spacers from a reputable brand and make sure they're hubcentric.
I ran Bimmec spacers on my old e90, currently running Eibachs on my current F36, no problems with either.
Build thread for my F36 440i Gran Coupe HERE
11-21-2020, 04:33 AM | #3 | |
Rep 1,475
11-21-2020, 05:46 AM | #4 |
Rep 153
I went for the Bimmec ones on my F31
10mm front 12mm rear |
Guus keunen15.00 |
11-21-2020, 09:12 AM | #6 |
Rep 153
11-21-2020, 02:19 PM | #8 |
Rep 1,475
I had to get the extended bolts separately, these are the ones I got:
https://www.ebay.co.uk/itm/16-X-M14X...-/323251837200
11-21-2020, 02:53 PM | #9 |
Rep 1,487
I tried 15mm on the rear of my f36 and they stuck out way too much I thought. Ended up with 10mm front and 12mm rear which is perfect. Wouldn’t go any more than that
11-21-2020, 02:54 PM | #10 |
Rep 7,032
Drives: 335xd Msport +
Try Lorcan for the spacer kit
He did me a deal a while ago on Eibach spacers along with extended bolts plus a set of AC Schnitzer security bolts.
11-21-2020, 04:24 PM | #12 | |
Rep 153
11-21-2020, 05:11 PM | #13 |
Rep 98
I am also interested in spacers, but I am reading stories of spacers being stuck on hubs. Supposedly pry tabs help on removing them when they have seized on but only BMS spacers has these .
For the peeps who have run spacers and then removed them, are they easy to remove without pry tabs? ( assuming you copper slipped them when fitting) |
11-21-2020, 05:16 PM | #14 |
Rep 595
Having just removed my spacers I can tell you they are a nightmare if seized. I used copper grease when I installed them aswell. i ended up having to heat them up, hammer a socket into a hole and proceed to beat them senseless till they began to move. I've had spacers on plenty cars before but these were especially problematic. They were bimecc 15mm. With the new 10j rears they were massively overkill
11-21-2020, 05:56 PM | #15 |
Rep 173
I like the look spacers give with the tyres more flush to the body.
However forgive the beginners question, but do you get any more tyre or road noise from the wheels being moved outwards in the wheel well? If not I may look at this when the alloys go back on next year...
___________
F30 330e SE 2017 Previously Audi A3 S Line Cab, F30 320d Luxury, E90 318d SE |
11-21-2020, 08:47 PM | #16 | |
Rep 1,325
I have the Bimecc spacers 15mm rear 12mm front. Very reasonably priced and came with bolts got them from C M Wheels who did me a discount when I emailed them. Only slight 'issue' is the spacers are slight smaller is diameter than the hub/wheel so the wheel (403m) sits slightly wider than the mounting surface/spacer. Now I've had these since spring, done many miles and various speeds and never had a problem. The alternative is Eibach Pro which I understand are slightly wider diameter however were double the price which, personally, I feel is a bit of a rip off given what they are. However depends how much you want to spend and how comfortable you are |
11-22-2020, 08:52 AM | #17 |
Rep 1,475
Fitted today, eibach pro spacer, 12mm front, 15mm rear.
Edit: apologies for photos being sideways, I can't seem to get the app to load the correct orientation.
11-22-2020, 09:00 AM | #18 |
Rep 665
Shopping around I'm finding insurance companies HATE spacers! Am I the only one?
Remap, sports exhaust, coil overs - all fine. Spacers - "no sir we won't insure cars with them.." |
11-22-2020, 09:51 AM | #19 |
Rep 19,982
I tend to find that 15mm works better visually if the cars been lowered a bit, and you're running a bit more camber.
My old 335d on coilovers and 15mm rear spacers looked great, whereas my 340 on ACS sports suspension looked better with a 12mm rear to my eyes. And definitely put some copper grease on the spacer!
11-22-2020, 01:38 PM | #20 |
Rep 61
Thanks all!! Not planning on lowering mine to be honest because of all the speed bumps around where I live...does my head in!!
Has anyone had 20mm rears?? Would be interested to see a few pics |
11-23-2020, 03:45 AM | #21 |
Rep 3,037
I have 12mm all round is all I need 15mm rear would be too much for me.
I've said it before, depends on what tyres you have as well. If on runflats they will appear to stick out more as the tyres are generally wider than non runflats. (comparing Bridgestone to Michelin) |
11-23-2020, 08:36 AM | #22 |
Rep 1,475
Tazzy - extended wheels bolts for sale in the classifieds if you're interested - I've got the same ones, will work with 12mm and 15mm spacers.
https://f30.bimmerpost.com/forums/sh....php?t=1777148
