09-01-2020, 08:25 AM | #15533 | |
Rep 40,733
09-02-2020, 08:21 AM | #15534 |
Rep 59
auto mirror retrtact 2015 f83
trying to get side mirrors to auto-retract on comfort close f83. found the guidance in above post and cheat sheet:
"For activating ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN: PfExternalMirrorMaster_1_1_1 -> aktiv For activating ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN: PfExternalMirrorMaster_8_8_1 -> aktiv" i have done this but is does not retract with comfort lock. when i hold down the keyfob lock, it does close (but not when i press momentarily). Any guidance appreciated. |
09-02-2020, 08:42 AM | #15535 | |
Rep 40,733
KOMFORT_SCHLIESSEN = Werte=00
09-03-2020, 02:32 PM | #15536 |
Rep 59
f83 folding mirror coding
thank you Shawn. on f83 changing: KOMFORT_SCHLIESSEN = Werte=00
did reduce the time to close mirrors via key fob. however, when locking the car from the door handle (comfort), the mirrors do not close. if closed, when unlocking the car with the door handle comfort - the mirrors do open. i tried this same programming on 2012 f10, and it works (mirrors close when locking via comfort). maybe there is something wrong with my mirrors? |
09-03-2020, 06:35 PM | #15537 | |
Rep 40,733
All of these needed to be coded: ASP_BEIKLAPPEN ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN KOMFORTSCHLIESSUNG_FB KOMFORTSCHLIESSUNG_PA
09-14-2020, 05:35 PM | #15539 |
Rep 40,733
PM sent.
09-15-2020, 07:06 PM | #15541 |
Rep 40,733
PM sent.
09-17-2020, 10:35 AM | #15543 |
Rep 40,733
PM sent.
09-17-2020, 01:33 PM | #15544 |
Rep 126
Will this work by pressing/holding the lock button if you don't have the Comfort Entry option? Is there a good dedicated write-up/thread for this?
09-17-2020, 01:36 PM | #15545 |
Rep 40,733
If you don't have Comfort Access, its not going to work from the door handle, but should work from Fob, and Mirrors should fold if you have power folding mirrors.
09-18-2020, 01:23 PM | #15546 |
Rep 126
09-18-2020, 01:30 PM | #15547 |
Rep 40,733
Use codes I wrote above.
09-20-2020, 09:21 AM | #15548 |
Rep 1
Hi Shawn,
Could you send me please a PM with links to the lastest E-Sys and PSdZ data for an 2019 440i convertible? Thank you very much for your service! |
09-20-2020, 10:03 AM | #15549 |
Rep 40,733
PM sent.
09-21-2020, 01:47 PM | #15550 |
Rep 27
help someone please. car from the usa F25 2017.
I need a radio for Europe I also have a problem with the sound after changing these settings: RADIO_COUNTRY = ece FM_DEEMPHASIS = 50us ANZEIGE_FREQ = nicht_aktiv maybe I need to change or delete another parameter? (possibly in VO?) when changing the settings, everything turned out well. Just has no sound ... (( maybe this option: S645A RADIO-STEUERUNG US ? |
09-21-2020, 01:54 PM | #15551 | |
Rep 40,733
09-21-2020, 01:55 PM | #15552 |
Rep 27
and it also failed:
Close mirrors + windows + moon roof through key FOB: CAS 3003 FH MASTER KOMFORTSCHLIESSUNG_FB aktiv / Werte=01 nicht_aktiv / Werte=00 FRM 3020 ASP_BEIKLAPPEN_BEI_KOMFORTSC HLIESSEN aktiv / Werte=01 nicht_aktiv / Werte=00 |
09-21-2020, 02:00 PM | #15553 |
Rep 40,733
Failed how? You have error coding, or it just doesn't work?
