07-17-2018, 03:10 AM | #1 |
Rep 78
Buzzing from B pillar
Hi all, I previously had the dreaded door seal noises which I temporarily fixed with gummi pledge so I'm happy with that. However I now I have been experiencing buzzing noise coming from the B pillar right next to my head. It's difficult to say whether it's the trim or something else.
If there's a high pitched noise on the radio it'll crackle/buzz next to my head or even going over rough roads mainly motorway at higher speeds it'll appear then too. Please tell me someone else has had this and have found a fix? TIA |
07-17-2018, 03:24 AM | #2 |
Rep 3,066
I had a buzzy / rattle noise in mine which only happened occasionally and I tracked it down to the plastic door lock pin wher it pops up through the door trim.
Pin is hard plastic as is the surround and just rattles around at times, may not be the same as you're experiencing but worth a try to see. |
07-17-2018, 07:18 AM | #3 | |
Rep 699
See item 15. https://www.realoem.com/bmw/enUS/sho...diagId=51_8523 |
07-17-2018, 08:09 AM | #4 |
Rep 78
I believe I have located the issue..
Turned the radio on and turned it up real loud when people were talking and quite often when it was a higher pitched noise it would buzz just above the B pillar (above my head) I pressed against it with my hand and it stopped.. So it seems like it's the anthracite headliner possibly rubbing or vibrating against something. As for the radio being on and people talking I don't know? maybe there's more vibration when it's talking rather than music... but also makes sense as to why it happens when I'm driving on rougher roads at higher speeds of 70+ i.e. motorway. Going to jam some foam between the plastic trim and headliner tonight when I get home...lets see if that potentially eliminates the noise for good. |
07-18-2018, 02:46 AM | #5 |
Rep 78
So.. on my drive to work it seems the noise has returned. It's not all the time, but it's bloody annoying!
It seems like it's a type of static vibrating from behind the cluster area/centre console and the drivers and passenger side b pillars/doors. I have now applied gummi pflege (again) in hope that it may rectify the issue. However, I think this may be the cause of a much bigger problem? Someone previously mentioned it may be a loose wire behind the centre console? I don't think it's that type of static noise and I'm sure that would be a lot louder than what I am currently getting. Not sure what to do... I could take it to BMW but it would be a lot of hassle trying to prove the noise to them. |
07-18-2018, 06:18 PM | #6 |
Rep 70
I have this on my M3. As I did creaky door seals. That’s fixed now. This noise is Intermittent, but seems to happen when travelling at speed and radio is loud. Seems like it’s a speaker / static type noise just above my ear slightly behind me around the b pillar. Obviously there is no speaker there so it’s not! Like you can’t be arsed taking to BMW trying to show them etc .. frustrating .. as is my boot not closing / reopening on an adhoc basis and my I drive going nuts every now and again. Whenever I take to the dealer the faults don’t show themselves.... typical ....
07-23-2018, 08:46 AM | #7 |
Rep 78
So I took my door cards off and applied an extra piece of homemade foam washers I made from a foam block (literally square pieces of foam cut up) and that didn’t do the trick.
Took door cards off once again, applied sound deadening around the door trims and plastic window trim…sound didn’t go then. The sound was still appearing near the locking mechanism and the rattle would go away when I put my elbow on top of the door trim. So I applied a little bit of self adhesive tape on the metal clip allocated on the door itself and the noise has gone! The door card doesn’t sit 100% flush but it’s 99.9% good enough and at least the rattle has gone, or so I think it has! All in all, this has wasted around 12 hours of my life, over several days. |
07-24-2018, 12:21 AM | #8 | |
Rep 137
Thanks |
07-24-2018, 03:34 PM | #9 | |
Rep 78
I honestly think it may just be the whole door card and how it sits. I unclipped the top of the door card and just pressed it in again (not hard) but pushed enough to hear it clip in and I've been on 3 journeys so far and it's pretty quiet. |
07-24-2018, 04:38 PM | #10 |
Rep 797
Had this on my 330d. Occasionally tried bashing the offending area (a technique I learnt from my father) but it came and went.
I've owned much cheaper cars that had far fewer rattles and squeaks. Perhaps these are simply cars that are designed to be driven on billiard-table smooth German roads.
Current: 21 G21 330e | Portimao Blue | 791 M | M Sport Pro | Vis/Tech/Comfort Plus packs
Previously: 19 F20 M140i Shadow Edition | EB II || 16 F31 340i | EB II || 13 F31 330d Luxury | MG |
07-24-2018, 05:11 PM | #11 | |
Rep 78
07-25-2018, 02:25 AM | #12 |
Rep 2
Have the same issue. Its seems to be coming from the "metal look" trim which houses the LED ambient light strip on the door card. The light strip itself seems to rattle in the trim. If I push against the trim the noise stops.
Back to the dealer to sort this , door creaking and brake squeal (2018 335D F31) |
07-25-2018, 04:28 PM | #13 |
Rep 1,034
I have a similar problem, intermittent buzzing sound which seems to come from the A pillar. My 10 year E90 no had a single creak or noise. Looks like BMW quality is not what it used to be.
07-26-2018, 01:35 AM | #14 |
Rep 699
Look at my post above. I have had the noise twice on both front doors in both my F30's and it was cured each time by replacing the lock button surround trim piece.
07-26-2018, 03:46 AM | #15 | |
Rep 78
The door lock itself does move a bit but it doesn't rattle for me. |
