06-21-2021, 02:54 PM | #2 |
1296
Rep 3,533
yeah with a custom tune for it. why would you want to run without the primary air metering source?
06-30-2021, 07:23 AM | #4 |
1296
Rep 3,533
talk ro your tuner, they will help.
06-30-2021, 09:57 AM | #5 |
Rep 190,804
You can run without it if your car is tuned
06-30-2021, 01:47 PM | #7 |
1296
Rep 3,533
any of the big named tuners.
07-01-2021, 01:46 AM | #8 |
Rep 2,357
Easier just to try it instead of discussing here. After a while you will get a CEL but car will drive like normal. Nothing need changing in the .bin. MAF has nothing to do with boost control, that is your MAP and TMAP.
If you want to run aftermarket intake - unplug MAF + code out the CEL Running factory - keep it
(A Dane in China) Last edited by harkes; 07-01-2021 at 02:06 AM.. |
07-01-2021, 07:19 AM | #9 | |
1296
Rep 3,533
07-01-2021, 03:40 PM | #11 |
1296
Rep 3,533
we are in agreement.. unless you have an intake that specifically is causing weird issues with your maf, in which case you should switch intakes... there is no reason to bypass the maf.
07-01-2021, 04:43 PM | #12 |
Rep 23
so if i keep Maf sensor. should i keep diameter of intake tube same as stock in place where maf is located ? or if i make bigger intake i can just put in sensor without modifying calibrations in bin ? i mean when i changed map sensor some offset number needed to be changed in bin to get correct readings. is same thing needed to be done in this case ?
07-01-2021, 04:54 PM | #13 | |
Rep 7,606
The map sensor is different because going from a 2.5 to 3.5 bar MAP sensor means the actual range of the sensor changes. Its still the same voltage range, but the actual pressure range is different. So if you don't calibrate this, when you read say 5v, the actual pressure the DME sees will be wrong. It would be difficult (and no one has done it to my knowledge), to try and recalibrate a MAF sensor for a different intake. This is why some intakes throw CEL, cause rough idle, etc. Backing up a bit, you don't even need to change the diameter of the intake tube... the stock one is fine... I can't explicitly say for a upgraded turbo application since i only tested stock turbo, but i expect any actual gains to be had by doing a larger/custom intake are negligible, especially if you run a load based tune. https://f30.bimmerpost.com/forums/sh....php?t=1765289 |
07-01-2021, 06:30 PM | #14 | |
1296
Rep 3,533
07-01-2021, 10:14 PM | #15 |
Rep 2,357
Just remembered I have a video running MAF-less and even removing the entire intake to see what happens FYI: Not much
(A Dane in China) |
07-28-2021, 05:43 PM | #16 | |
Rep 23
07-28-2021, 06:42 PM | #17 | ||
1296
Rep 3,533
07-28-2021, 10:55 PM | #18 | |
Rep 2,357
If you like to experiment with home-tuning then the bootmod3 is probably the best platform with its built in function.
(A Dane in China) |
07-29-2021, 12:39 AM | #19 |
Rep 517
What your looking for is called a Speed Density Tune.
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
07-29-2021, 02:46 AM | #20 |
Rep 23
one more question someone tried to contact member anjuna ? i am interested it just not answering PM's or it is just in my case not get heard from him few montn ?
07-29-2021, 08:16 PM | #22 |
Rep 4,917
Do you change elevation often?
