BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > N55 CATsim simulator?
Studio RSR
      07-19-2018, 07:00 PM   #89
maxio
maxio's Avatar
19
Drives: 2014 335i M Sport
UPDATE: Drive cycled twice today, P2271 CEL comes on as soon as the IM Readiness/monitors showing Ready.
Not sure what to do now - checked install to make sure it was correct, blue LED light is there...
Emailed Tiago at VRSF - hopefully he'll have a solution. Will update then.
      07-25-2018, 08:22 AM   #90
maxio
maxio's Avatar
19
Update: Tiago from VRSF was nice enough to send a 2nd unit for me to try again, to eliminate the possibility of a faulty first unit.
Unfortunately it was the same issue - blue LED stays lit, does not blink.
Cleared codes and proceeded to drive cycle the car - in both cycles the car threw a P013B and P2271 fault error code.
I think the downpipe fix has a high probability of working for N54 engines, but with N55 it's definitely a gamble. Based on my research through forums, it seems like most other F30 N55 owners are unable to make the fix work too.
Oh well - guess it's putting the factory catalytic back in to keep my off road drive CEL free then.
      07-25-2018, 12:47 PM   #91
JaredG_F30
JaredG_F30's Avatar
1106
Drives: 2014 335i, M-Sport, Manual
The CAT Sim isn't designed to be run all the time. It's supposed to be temporary for passing emissions. IF you are just trying to remove the CEL due to catless DP then get a tune like MHD or bm3.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI).
SPI Films Blog/DIY Vids
      07-25-2018, 03:02 PM   #92
maxio
maxio's Avatar
19
Oh for sure - I've been running JB4 for awhile, until the need to "go offroad" came up and I had to set JB4 to Map 0, hence the search for temporary solutions.
      07-25-2018, 03:47 PM   #93
Chef Blake
Drives: 2012 F30 335i MT
I'm using the Area 74 catsim. I had success with it last year, but now my CEL is still on after disconnecting my JB4, and connecting the catsim.
QUESTION: Is it possible there could be a loose/bad connection on one of the wires prohibiting the unit from functioning properly, but the light continue to come on and off like normal?
      07-25-2018, 05:53 PM   #94
maxio
maxio's Avatar
19
The catsim, being a literal black box, is anyone's guess. I think you might want to reach out to ****** to see what they say.
What fault / error codes are you now getting from the CEL?
      07-26-2018, 09:05 AM   #95
Chef Blake
The JB4 code is 139001, so I'm not sure what that translates to, but I'm assuming it's related to a failed cat in my downpipe since it's exactly what happened last year.
ALSO: I had the i02 catsim wired backwards earlier, so I wonder if that damaged it. I have a new VRSF catsim arriving in the mail today, so I'll hook it up and see if it works, and will post an update later.
      08-01-2018, 03:10 PM   #96
FVierra27
FVierra27's Avatar
It's been awhile for me but I wanted to report back. After fiddling for a long time trying to get it to work consistently, I gave up and threw it away. It doesn't work well on EWG cars for whatever reason..
M Performance mirrors, spoiler, and exhaust, BMS wheel spacers (10mm F 15mm R), ER kittyless DP.
Need a tune and intercooler
      08-03-2018, 09:08 AM   #97
Chef Blake
After driving with the VRSF catsim for about 60 miles, my CEL is still on. I'm probably going to go back to the stock DP and be done with this madness. What a drag.
      08-03-2018, 02:10 PM   #98
maxio
maxio's Avatar
19
For those who are drive cycling the car - it's not about the distance, but about the proper drive cycling steps.
https://www.instructables.com/id/How...or-Smog-Check/
The way I saved time drive cycling the catsim (or any other device/hardware) is to:
1) Start the car, let warm up.
2) Immediately get on a highway, in D gear, accelerate with 3/4 pedal to 55mph.
3) Set cruise control on and let cruise for 5 minutes.
It definitely helps if you have an OBDII scanner - you can monitor the monitors and see.
If your scanner doesn't throw any codes after 5 minutes of 55mph, you should be on your way to clearing other monitors.
      08-04-2018, 09:40 PM   #99
paolotonzini
Drives: 335i
I have a n55 with jb4 and mhd backend flash and I still get catless downpipe installed code I have to ear the code manually every day a cuple times depending on how much i drive, should I be able to keep the code cleared with mhd or jb4?
      08-06-2018, 09:59 AM   #100
maxio
maxio's Avatar
19
JB4 has a CEL delete on option #4 I believe, that should automatically clear the code for you. Not sure how MHD affects that option, let's wait for others to chime in.
      08-12-2018, 11:54 AM   #101
Chef Blake
So, I was just driving around waiting for the code to clear itself. But after reading a couple other comments/threads, I decided to plug my JB4 back in and clear the code (since I already had the O2 sim connected). I had been driving my car to and from work in such a way as to drive cycle my car.
I bought a $17 code reader on eBay, plugged it in, and scanned the car. No codes, and my emissions modules were all in ready status.
Passed my inspection, removed the 02 sim, and reconnected my JB4 and all is well again.
The best advice I could offer anyone who is currently running, or is thinking of running a catless DP (or potentially catless DP like mine), is buy a cheap code reader. And once you have an 02 simulator connected, with the light on intermittently, clear your CEL code and try to drive cycle the car.
E90705127.00
      08-12-2018, 12:26 PM   #102
E90705
E90705's Avatar
Drives: E90/F25 M-sport
https://www.instructables.com/id/How-to-Do-BMW-OBDII-Drive-Cycle-For-Smog-Check/
Perfect solution for pwg
      08-12-2018, 01:58 PM   #103
maxio
maxio's Avatar
19
So I guess the Catsim only works for PWG cars... Good for you! 0
      08-13-2018, 12:22 PM   #104
TerryGTX
Drives: 2014 Bmw 435xi M-sport
PWG -confirmed to be working
EWG- won't work whatever you do
To pass with catless, you have to drive it in a specific way for all monitor coming up and just before o2 sends CEL
      08-13-2018, 03:06 PM   #105
E90705
E90705's Avatar
Anyone know the time in between from when monitors turn to "ready" until a CEL is triggered ?
      08-13-2018, 04:21 PM   #106
maxio
maxio's Avatar
19
Hard to pinpoint, since there are a number of factors (depending on the monitor).
For me the CEL popped up as soon as the monitors turned "Ready".
      12-07-2018, 12:28 AM   #107
E90705
E90705's Avatar
[img]
View post on imgur.com
[/img]
My PWG gets cat monitor "ready" but I get CEL "oxygen sensor after catalytic converter slow response and delayed response code after. :
The blue led light blinks or is on so it seems to be working.
Have mhd uninstalled, stock tune. Kitty less dp.
      12-07-2018, 01:01 PM   #108
FastF30
FastF30's Avatar
521
From my understanding a cycle is a cold start and run until warmed up... repeat process total of 3 times...
      12-07-2018, 07:08 PM   #109
E90705
E90705's Avatar
I get the CEL the first drive cycle. Should I not clear the CEL? And give it a couple more drive cycles with the CEL?
      12-08-2018, 09:12 PM   #110
FastF30
FastF30's Avatar
521
I haven't been personally thru this experience... just from reading about it... unfortunately I can only say try it both ways if one doesn't work...
