05-28-2016, 09:47 PM | #1 |
Rep 987
Drives: 2022 X4 M Competition F98 LCI
Coding: Rear Light Bars Remapped For Turn Signals - Still Enabled for Tails
The thread about the Eyebrows remapped for turn signals over here - http://f30.bimmerpost.com/forums/sho....php?t=1264291 got me thinking...
Is it possible to remap an addition function for the Rear Light Bars to function as turn signals without removing the taillight function? The answer... YES! Simply remap the following: MAPPING_TAGFAHRL_H2_L_OUTPUT > sl_2_l MAPPING_TAGFAHRL_H2_L_FUNCTION > werte 06 MAPPING_TAGFAHRL_H2_R_OUTPUT > sl_2_r MAPPING_TAGFAHRL_H2_R_FUNCTION > werte 07 MAPPING_TAGFAHRL_H_L_OUTPUT > sl_l MAPPING_TAGFAHRL_H_L_FUNCTION > werte 06 MAPPING_TAGFAHRL_H_R_OUTPUT > sl-r MAPPING_TAGFAHRL_H_R_FUNCTION > werte 07 So in order for the light bars to be repurposed as turn signals (still function as taillights at night) - we're remapping the supposed DRL functions for the taillights to be used as turn signals instead. |
05-29-2016, 10:43 PM | #3 |
Rep 1,076
I just noticed that when I have my left indicator turned on, there is a click coming from the back right of the car.
I don't have any such indicator clicking noise from the back right or left other than the regular indicator clicking when I have the right indicator turned on. Any ideas what that could be? |
05-29-2016, 11:12 PM | #4 |
Rep 5,776
Interesting...might have to try this.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
05-31-2016, 08:18 AM | #6 |
Rep 987
05-31-2016, 08:52 AM | #8 |
Rep 1,436
06-04-2016, 09:55 AM | #10 |
Rep 524
code to turn off the blinker and just use the leds
I coded the led light bar to link with the turn signals but looks a little tacky with all 3 lights going off. Is there a way to turn off the regular turn signal so I can just use the lower led light bars as turn signals?
06-04-2016, 07:30 PM | #11 |
Rep 987
I'll look at it when I have time. But really you just have to turn off the mapping of the turn signals to the regular bulb.
06-05-2016, 06:25 AM | #12 |
Rep 524
06-09-2016, 04:12 PM | #13 |
Rep 1,076
MAPPING_TAGFAHRL_H2_L_FUNCTION > werte 06 MAPPING_TAGFAHRL_H2_R_OUTPUT > sl_2_r MAPPING_TAGFAHRL_H2_R_FUNCTION > werte 07 MAPPING_TAGFAHRL_H_L_OUTPUT > sl_l MAPPING_TAGFAHRL_H_L_FUNCTION > werte 06 MAPPING_TAGFAHRL_H_R_OUTPUT > sl-r MAPPING_TAGFAHRL_H_R_FUNCTION > werte 07 Do you remember what the original values were/are? I would like to go back to the original values. |
06-13-2016, 10:15 PM | #15 |
Rep 987
01-21-2017, 03:10 PM | #16 |
Rep 524
I'm getting an issue where the outer left bar blinks while the inner bars (closer to the middle of the trunk) in the left side don't blink when the car lights turn on. Otherwise when the headlights are off the function as expected. I've gone through and coded everything correctly so not sure what gives?
01-23-2017, 02:25 PM | #17 |
New BMW owner
139
Rep 622
Anyone got a proper video when working in day, link is down.
05-10-2017, 08:30 AM | #20 |
Rep 193
Yes here is mine
https://www.facebook.com/TheGarageEg...5287706544286/ It can be coded, and we can disable the yellow signals too. Just disable blinken values |
05-10-2017, 10:15 AM | #21 | |
Rep 60
